One ābeefā: This is more a āLight Pipeā than a sphere I did a lot of reading-up about these creatures some time back and Iām a stickler for nomenclature accuracy I like both the electrical tape ātuningā and the ābaffleā; neither is conventional but both are brilliantly simple solutions. The only potential failure point I can see is the electrical tape which could lift, shift, or curl in time but that is easy to check.
We tend to over-think things sometimes and that can mislead by inducing ātunnel-visionā which often leads to dead-end paths we get stuck on. The only thing here which really matters is the results- if they are accurate and consistent who can complain (and can the complainer do better themselves?). Iād like to see a few more details such as the highest and lowest lumens and the largest and smallest head diameters youāve tested- that would complete this āreviewā very well.
Itās a given that our home-made measuring devices will never be lab-grade in every aspect but that isnāt really necessary for our uses. To get within a few percent is totally adequate and a major achievement. I always say that if something is doing what itās supposed to do there canāt be much wrong with it; and it seems youāve got a winner here :+1:
Yeah, the idea and execution is quite simple indeed. It was the months of testing to figure out what worked and what didnāt that was hard. I overthought it a lot at first but turns out that the simplest option is the best one as well.
It is quite sturdy, PVC pipe is pretty tuff stuff. If you meant stable then it is actually surprisingly stable as well. I have never had it even attempt to tip forward. I lay my heatsink/LED test rig on top of the inlet port and it holds up just fine.
I used 3ā PVC for this sphere because at the time I was too cheap to spend the extra $8 for 4ā and the extra space would make it more of a nuisance on the desk. You could easily build this with 4ā or even 5ā PVC to fit any light you could want though.
The black electrical tape is my āmultiple fine tuning adjustmentā. Basically by sizing the tape just right and leaving it in the sphere it absorbs a fixed amount of light photos before they reach the light meter.
This in turn lowers the reading on the meter and allows me to have the meter output the lumens directly on the readout and not need an external multiplier. It makes taking readings much more pleasant since what you see is what you get.
Yes, the meter is on auto and in this case it was indeed reading 123 lumens. When the lumens go over 2000 it adds in a 10x multiplier on the meter but that is easy enough to figure out, if it has the 10x sign in the corner then you know that it would for example be 1230 lumens.
The name could be argued, IMHO sphere is anything that integrates the light to the point of beam profile/shape/angle not drastically effecting the readings. A light pipe classically does not do this so I feel it is closer to a sphere then a light pipe. Although the largest reason for calling it a sphere is that is what everyone else calls these devices and thus what they would search for.
Yeah, the first several prototypes of this setup were very overthought, didnāt work that well and were hard to use. When I finally said to heck with it and decided I didnāt care I went simple and to my surprised worked way better that way.
The real eye opening moment for me was when I realized the difference between a mathematically calibrated sphere and a standard calibrated sphere. DIY spheres are always standard calibrated. In this case there are only 2 things that matter, consistency and linearity. This checks both boxes so it is then just a matter of calibrating it to a good standard.
On a mathematically calibrated sphere (such as an ANSI certified sphere) things get way harder and that why they cost $10,000.
The electrical tape for tuning was another eye opening moment. I tested extensively to see if it would effect the constancy but it turned out that if the light was truly āintegratedā it had no effect other then reducing the meter reading. As far as it peeling or currling, I have not had an issue yet but I also keep that fenix light nearby and check the readings from time to time. It always comes out within 2-3 lumens.
The largest issue I have is actually dust. I left the centering rings off of it at first when not is use and after awhile the dust started to effect the readings slightly. I blew it out and it was back to normal. So now I leave the smallest hole centering ring on it at all times to keep the dust out.
As far as the lumen measurement range, the min lumens it will detect is around ~5 or so, generally doesnāt detect moon modes and under 5 lumens I am not convinced of the accuracy.
The highest it has seen so far is a bit over 10k lumens from an 8X SRK.
For head sizes, it depends on the size of the PVC you use. 3ā that I used Is cheap but the price goes up quickly as you go bigger so I decided to pass on that. You can get PVC upward of 6ā though so max head size is not really an issue, just a matter of cost and how much space you want to take up.
I personally have measured from a BLF-348 up to a D01 myself, those are the smallest and largest lights I own at the moment, no issues with either at all.
I totally agree on being āgood enoughā, consistency is way more important then accuracy, as long as it is consistent then it is comparable.
Thanks for your posts, it helped me learn a lot. I especially like the way you modified the device so you can read values directly off the meter without a need for conversion factors.
Inspired by your work, I did a quick test, using a vitamin jar cap as a diffuser. I had to add 1 piece of white envelope paper, and one piece of kleenex, under the cap, to ācalibrateā it.
I used my new Integrating Cap to test two Lumintop lights.
On the left a ReyLight Tool w Nichia, ReyLight modes are mfg spec to be 1-16-80
On the right a Lumintop Tool w Nichia head, on a Maratac body, Tool modes are mfg spec to be 18-3-80
you can see in the beamshot that the ReyLight obviously has a lower Low
it just helps to be able to quantify the differences, here is the ReyLight Low calibrated to read 1 lumen
and this is how that calibration reads the Tool head on Low
here are the beams on High side by side, and their readings (these are both N219b lights, you can see they use different batches of CCT)
ReyLight High
Tool head High
I then tested an L11c w Nichia, claimed high is 140 lumensā¦ surprisingly it is only about 5 lumens brighter than the Tool on High.
Very interesting idea, I never considered going that small. That is thinking outside the box, good going!
I also tried many items like plastic and such for the integrating disc but nothing was just right. I didnāt think about 3D printing it until I already had the stryfoam done.
You also did remind me of one of the big reasons that I did this in the first place and realized it would work fine. The light sensors we use already have a diffuser/integrating dome over the sensor that it is calibrated to. So why would another one effect anything any differently?
A larger āintegrating spaceā does help even out variations from beam pattern which is real important once you start dealing with different sized lights with vastly different beam patterns.
That is a tricky set-up, jon! To have a fixed calibration for all kinds of flashlight sizes and types, your set-up depends on a luxmeter that correctly reads light coming from any direction, hitting the detector at any postion (and as I understand, that is not an easy requirement to match for a luxmeter).
But the proof of the pudding is again in the eating, if in a series of tests, the calibration of this set-up proves correct enough in various types of flashlights, all is good.
I have no idea if my tests would be relevant with anything other than an AAA light with similar reflector, but it does let me compare similar heads at least. I dont trust the ~85 lumen reading on the AA L11c. Maybe my plastic cap is not consistent when the LED is closer to the plastic vitamin cap on the AAA head, and further away on the AA head.
great fun though, Ive compared a bunch of AAA maratacs and Tools with various drivers, LMH and HML modes, each in both N219b and with 3000k XPG swaps.
I can tell you a reylight with a 3000k XPG reads .6, and a reylight with a 4500k N219b reads 1 on my integrating cap (note that the drop in lumens is in proportion to the drop in CCT):
I also have an Olight i3s, whose stock 6000k XP-G low is mfg spec of 0.5 lumens, modded to a 3000k XPL it reads .2 on my meter:
The real hard part with this type of thing beyond the sphere setup is getting a good calibration. This was my limting factor for my sphere. I simply didnāt have any better lights from which to use as a standard.
If I had a 100% known lumen output light calibration would have been 100x easier, the issue when all you have is modded lights or lights without trustworthy lumen ratings is picking which one to use as your standard.
In my case I settled on a midrange point between all the halfway trustworthy lights and then compared that to the Cree data sheets with a few LED tests.
I have no idea if it is accurate or not but it lines up with the ansi ratings on the few lights I have that came with them and it also lines up with cree data sheets and lastly it is in line with the numbers I see posted on here. So I am happy with the calibration.
true
at the very least though, you can determine which of your lights are the dimmest, and in what order
fwiw, I redid the L11c test with a hot off the charger Eneloop and got an extra 20 lumens compared to my earlier test, but still 35 lumen below spec
I still agree a larger diffusion area would do a better job of comparing lights that are not using the same heads
my Dinky Integrator is just AAA size for nowā¦ thanks for helping me get some cheap thrills
I still think you made a major contribution to the Integration Tool concept, by calibrating to your meter. That seems to work. I dont see any particular challenges in regard to consistency of the reading at Low vs High levels (in the narrow range Im testing anyway.) I think you concept is sound, and it made my whole setup really practical. Im very grateful for your contributions to my entertainmentā¦
Just wanted to say thank you TA for creating this thread. I've been playing around with improving my light tube using the ideas you published in the OP. Really has helped a lot. It has also got me trying other materials and designs. So far, nothing has done better than your model in the OP, but it's interesting to explore this aspect of the hobby. In the past, I've been frustrated and discouraged by how much my measurements could vary by just the slightest change in flashlight depth into the tube and such.
I call mine a PVC light box . I'm a little surprised the round spheres haven't taken off more so than the PVC light box designs. I think I read of some issues with the spheres, but haven't followed it closely. I haven't had time to look in adapting mine to how yours is set up here, but looks like it has definite benefits. For me, I'd probably want to build up a 2nd one, rather than losing my only means of lumens measurement while I build, tweak and test, then also I'd have something to compare with.
Thanks, glad others are finding it useful. It is by no means a perfect sphere but it does work far better then my prior designs without the āintegrating layerā.
I do think a thinner layer would be better though. Maybe something like DC fix. 2 separate layers would be even better I think.
The other major change I would make if I did it again would be to make the inside of the PVC a matte finish. Either by sanding it (quick and simple) or with a high quality flat paint. The flatter the finish the better.
Yeah, it is more of a light box really but no one searches for light box.
The issue with the round ones is mostly availability and cost. The styrofoam versions work great for low powered lights but once you get to ~1000 lumens or so they start to divagate due to so much light making it through the foam. Plus they are big and bulky which is the biggest reason I prefer the PVC setup, it is much easier to deal with on the desk.
Yeah, build a second one for sure so that you can use the first one to calibrate the second. Calibration is the hardest part in any sphere build. I am still not that confident in mine, it is simply the best I have been able to come up with using the flashlights and LEDās I have access to.
In my LED tests my readings are generally within the margin of error for the datasheet specs, so that would say I am not too far off.
Nice. The crazy angles matter though, not just "realistic" conditions. The crazy angles matter because the whole point of an integrating sphere is not how consistently it can give the same value for the same light, you don't need any kind of sphere or box for that, just a meter stick. The point is how well it can account for angular distributions of different lights.
The main point here is many bounces average out. I wonder about using a jar of some granular cloudy material. Beads? Salt? etc. I also though like EASYB's method, just measure brightness at several angles, and... integrate. Of course it's not as comfortable.
This is not true, loss of integration from light loss through the wall is with the average wall thickness of styrofoam balls (over here 2cm) negligable, and is completely independent of the light power of the measured source. The limit of my integrating spheres are solely determined by the range of the luxmeter that is used, which can be extended to wish by either a neutral density filter or the use of a satellite sphere. My most used sphere measures up to 15,000 lumen, if I need to measure higher, a small adaptation can extend that range.
Is the bad availability of suitable styrofoam balls the only reason for people to not build integrating spheres? (which despite the love of flashoholics for tube-systems are according to all literature of light measuring and measurements in practical use the way to go for good integrated light flux measuring). It is not that it is difficult, via my sigline people will find 4 IS build threads, of which one is simpler, cheaper, faster to build, and better integrating than any tube-system that is in use by CPF and BLF members.
I donāt know what your sphere consists of but I know that the JoshK sphere that I have will deviate by 5% or 10% (forgot which, been a year since I messed with it) per 1000 lumens due to losses.
So basically I have to adjust the multiplier by adding an additional 5-10% per 1000 lumens as the lumens go up in order to get an accurate result.
I tested this by testing three S2+ās separately and then putting them all together and taking a reading and the readings did not match up like they should. I used a few other lights in the same way with the same results. I also compared it to my PVC sphere. The PCV did not deviate to a statistically significant extent where the foam ball did.
I ran these tests due to over time the readings I was getting on high output lights was just not adding up compared to the low output.
All of the data is posted in the joshK thread.
I was 100% in favor of the sphere when I started all of this, which is why I was so excited to get the josh sphere and give it a try. The move away from it was not easy and only happened because I got significantly better and more consistent results on the PVC sphere.
I have positively nothing to prove in this case, I would love a proper sphere but the cost to build one would be way too much to justify the result based on my experiences so far. It would also be a lot of work as it would need to be coated with something to keep the light from making it through the foam.
Which is a point, light makes it through the foam super easy, even moon can be seen just making it glow in a dark room. It is quite possible that denser foam would not have this issue.
Measuring light has little to do with light loss but all with keeping the loss constant, the fact that a small fraction (in the order of a few %) of the light goes through the wall of the styrofoam is of no concern for either integration or accuracy.
About Joshkās spheres:
I stopped reading and posting in Joshkās thread after he refused to take on any advice from me (two years of building spheres and numerous tests on the performance), and was being rude to Texlite who was giving very good input at the time. Then he went completely his own way with some clear misconceptions about measuring light and produced and sold a number of spheres without any proper test data on their performance.
He would not even know what kind of tests to perform, not even sure if he really understands what light integration is. Which is all perfectly alright but not if you are into integration sphere making and distributing.
Not having followed his thread any further I would not know why his spheres do not perform, it is certainly not the concept of the integrating sphere, which has been proven worldwide by every light lab.
Just measured two flashlights (that I know have a good constant output) in my integrating sphere, first separately, then together next to each other in the entrance hole. I did not correct for entrance hole effects on the multiplier (but that effect is limited in my large sphere)
First light: 71 lumen
Second light: 115 lumen
Together: 185 lumen
