Read the thread from the beginning then decide for yourself.
I did read the topic as it went along, but i’m still wondering what to do too…
I think i’ll wait for the problems to be solved, but that would mean the old stock has to be sold first…
I just received my clear C8 last Friday and it has the problem driver. It took 5 or 6 attempts to get to the configuration mode but from there, mode selection was straightforward and now it’s setup as I like it and works perfectly. I doubt I’ll change between modes often so I’m happy with it.
Just for clarification, is this a firmware issue or hardware issue or both?
From the research I did on 5 sample drivers, it's the programming of the fuses that was done incorrectly. So the main problem is not hardware or firmware, but how manufacturing programmed the fuses, which in turn effects the firmware.
They used these values: http://www.engbedded.com ATtiny13A LOW = 0x7A HIGH = 0xFF
But they should have used: http://www.engbedded.com ATtiny13A LOW = 0x75 HIGH = 0xFF
If you can follow those linked pages, the difference is doubling of the clock rate of the ATtiny13A for what they used at 9.6 Mhz, while the rate should be 4.8 Mhz.
Going back through this thread, many find the current double speed version still very functional, useful, and better than others out there. Sure, would be nice if they were programmed at the correct speed, then the configuration will be easier, strobes and blinks operate as intended, etc., but it's still a pretty powerful, nice UI as-is.
I read the entire thread before I posted anything. I think it’s pretty sad that they are still asking full price for all those lights on the shelves with defective hardware. No warning, no disclaimer, nothing.
I think I’ll look at Convoy a little different from now on.
People keep saying they are defective yet I have only seen reports of what, 4 maybe 5 people with a truly defective driver that didn’t work?
The rest are running faster then planned but otherwise work fine. The only issue that most would notice if it was not pointed out to them is that programming requires much more precise timing then it should.
If not programming the driver though then you will not notice any issues for the most part.
If you happen to get a truly defective driver Simon has sent out free replacements to all the ones that have reported such as issue that I know of.
I honestly don’t know why people even worry about this unless they plan to reprogram it on a regular basis? I personally set it and forget it on my lights.
Yeah its not working as it was designed, but it does still work. The world is full of products that don’t quite meet the specs as designed, but are still a good product. And yes, I’ve got one of the lights. I’m really not sure I would’ve even known there was an issue if this thread hadn’t been here. Its a good light, as-is.
emakd - that is true, and it’s also what makes this website great. With all the cheap Chinese junk that is being produced and sold, it’s great that there is a forum like this one to help sort out the true bargains from the garbage.
It’s also great that there are some manufacturers that have risen to the top of the budget flashlight world that can be trusted based on reputation alone.
Maybe I am judging Convoy a little too harshly about this small matter, or maybe I expect excellence too often. Either way, I’m only one person and I’ll surely get over it. Lots of choices out there.
Well, one solution is to swap your driver. MTN offers a few with different UI like Bistro and Guppydrv. It would only cost $5 or so.
Or for $5 get yourself a USB flashing kit and reflash the driver with the correct fuses and enjoy it and any other lights you may want later.
That’s all it costs? Tell me more.
Yeah, depends on where you shop but right around $5 is what I paid.
This thread outlines the process and items you need.
I got the USBASP off ebay for $2.xx, the soic8 clip for another 2.xx off ebay. Then the ribbon cable I won for like $.50 cents at auction on ebay.
Then all you need in a computer with a USB port (heck might even be able to do it on an andorid phone now days, although I have no idea if that is actually possible).
To flash a pre-built hex file such as the bistro files for the Texas Avengers drivers or TK’s biscoti hex you simply run AVRdude and don’t even have to install anything.
Now if you want to edit the firmware that gets a bit more complex but still not super hard. Although it will take more then novice level computer skills.
Naw, I paid a bit more for mine (socket and the usb part), but that was supposed to be for DIYing. Like I said, and people’ll probably think I’m just bitching over nothing, but I just wanted one off-the-rack light to work the way I want, without having to strip down and rebuild.
I got a bunch of 105Ds (with the annoying blink-on-low to switch 3/5 mode-groups) that I was going to reflash to 100% only, but with LVP and maybe stepdown. I don’t intend to ever let the battery get that low, but then again, just yesterday my S2+ did just that, and I don’t recall using it all that much, let alone on high.
But then I’m back to DIYing…
I really want a clear C8… but I want one that operates as designed. I know I can replace the driver, but when will I be able to purchase a properly working clear C8?
order on simons shop ask for 15% BLF discount before payment and ask ifits the driver with right firmware
Please define what you mean by not working properly with the drivers as they are.
Like was said, the only thing “not working” is the programming is a bit quicker then planned but besides the programming menu the light works exactly as expected.
I am just not sure I understand what people are calling defective, sure programming may be a bit harder then expected but you only do that once for the most part.
The whole light is ruined because of a minor issue that only effects things 1 time in the life of the flashlight?
If TK had not posted about the issue none of us would even know it WAS as issue.
Your request for clarification:
Answered in your very next sentence:
Thanks!
I disagree. If you were simply told that it was working as intended then it would just be a hard to program driver and ya’ll would ask for a firmware update to make it easier to program.
This is exactly what was said before TK said it was not how she intended. Then it suddenly went from a great driver that is kind of hard to program to a defective driver that doesn’t work?
Obviously it is a difference of opinion but if someone has to tell me that something is not working as it should for me to know it, then it is not defective IMO.
The light turns on, the modes switch, the mode groups function.
What exactly doesn’t work that you would know without someone telling you otherwise? I know of nothing that doesn’t work with these drivers. Only things that are faster then planned, those are very different things.
TA, you are right. You have convinced me. I’ll order one as is and not wait for a driver that isn’t more difficult to program than necessary.
Or if the programming bothers me too much, I’ll use it as an opportunity to learn how to flash firmware as was discussed above. I’ve been wanting to figure out how to do that anyway.
