Finding a pen-light nichia
My brother is going to be a doctor, and he needs a penlight for his work
A 2 aaa pen-light with the tint as close as sunlight
Lumintop yn365 is my suggestion, but he thinks 125 lumen is quite low, if only it is 200lumen
So, please suggest me a suitable light
Thanks
Manker PL10 ?
BLF review of Manker PL10 here
120lumen and 10180, well, i dont think itā€™s suitable
My brother needs 150+ lumen nichia 2 aaa pen light
Lumintop yn365 is a very good option from the flashlights currently in production.
^ any other options, i mean, nothing is best, right?
I really like my acebeam pt10, my brother does, too, but itā€™s using xpl led, not nichia, sadly
Oops :blush: . Sorry for the bad suggestion. Merry Christmas.
BLF 348 has a Nichia 219 led, but itā€™s a one AAA only flashlight.
The BLF-348 is a great light with Nichia 219B and cheap too.
Unfortunately the (measured) output is only 50-60 lumens with a AAA.
Stronger cells can be used, but isnā€™t really recommended since the light quickly overheats with them.
A Manker E21 should do the trick though:
Your Brother is going to find out 200 lumen is way too bright when looking close up into someoneā€™s ear, nose, or checking pupil dilation. 125lm might even be too bright. Iā€™d be surprised if he needs anymore than 50lm. I would guess the BLF 348 nichia single AAA would be about perfect. Might be too bright with a 10180
^well, he already have olight i3e silver(110 lumen) and he wants a lightā€ little brighter and more likeā€sunlightā€
So i guess 150 lumen is enough
I dont think he will only uses it to look at someone, but also use as EDC light
+1
My wife is a doctor and uses an IYP365 (Nichia), she usually uses it in medium and sometimes in low.
She uses sometimes also 348 (Nichia) with AAA, she have several. Also she gave several to her colleagues, they are all very happy with themā€¦
Yeah, iyp365, but any other options
Btw: is the glass of iyp365 Ar coated
In some review, they didnt mention it
The Nextorch Dr.K3 is high CRI and designed for pupil and similar examination but not so much for EDC use.
The Lumintop is probably better for both examination and general use. I think he will find the medium setting of ~25 lumens more than adequate for examination work and the low setting of 1.5 lumens is probably a good output for pupil responses. I canā€™t see 200 lumens being needed at all in a medical setting and at that output, battery life is quite short.
The features for the IYP365 on Lumintopā€™s website state that the glass is double-side AR coated.
I might be repeating myself, but:
A Manker E21 should do the trick:
Mine was just inches away so I checked for you on low -> the lens gives a slight purple tint under illumination so yes I believe so. But donā€™t hold me to it (Maybe my eyes have started to see purple or something?)
well. i think i will buy him iyp365, maybe 125 lumen is enough, i hope so
thanks for any suggesting, i appreciate all of them
> Nextorch
I found an explanation of this:
I know opthalmologists now filter the bright light used to examine the retina to reduce the blue light hazard.
This ā€œRG0 ratingā€ means ā€œRisk Group Zeroā€
ā€™Oogled: blue light hazard RG0 - Google Search
Briefly from the Osram page found by that search:
Those old lights to examine the Eye can use HID bulbs so a filtering is needed
A tungsten light should be OK
It is more harmful to look in the sun driving at evening than in an LED flashlight
Blue light is not too bad, 365 are really dangerous
285nm LED are absolutely deadly at very low uW levels to sterilise water for example
that is a Cool White ~6000k Color Temperature LEDā€¦ I ā€œhateā€ them now that Ive learned about Nichia (and became a tint snob)
I agree with all of that, very well said.
I think the iyp is an excellent choice. fwiw it has a Neutral White ~4500K Color Temperature
here is the difference
The advantage of the Nichia (on the right in next pic) is that it shows reds that the XP-G2 cannot.
an IYP w Nichia will be warmer than his i3e, but also opens up a whole new world of color, totally separate and unrelated to raw blue white brightness
to get 200 lumens from a Nichia, requires larger batteries than the IYPā€¦ and a heavier light than would fit comfortably in a shirt pocket
Probably a bit late for the OP now, but the Nitecore MT06MD should meet all your criteria. It has a high mode of 180 lumens and Nichia 219b.
