[SALE] High CRI 90+ Nichias (ENDED)
No 9080 available for all 219C CCT. If you really want it then go with 219B. Not much demand for 9080 even for high end retail display. 9050 seems the best compromise for now.
Where can I buy them (219B R9080)?
As mentioned to you, your leds have been send out last week.
I can supply that 219B 9080 if anyone interested. 100 pcs minimum order. You can combine it in my January purchase.
I thought so too, but i wasn’t sure since they have not arrived yet.
Okay.
That would be good!
The 219B V1 has the same low Vf as the 219C as tested by djozz, so not much difference between the two (219B V1 vs 219C).
If the bins available for the 219B V1 are higher than the 219C then by all means go for the 219B V1!
So far I’ve only heard three person interested in this NVSL219B V1 9080: You, Badhakker, and Chouster (NCSW219B V1). Not enough demand….
Actually… I would be interested too, depending on price and available colour temperatures.
Each additional CCT requires 100 pcs minimum order quantity. So….you guys better decide the CCT you want to get.
And FYI, 9080 will be a tad more expensive than 9050. Nichia also make it in lesser quantity, will have to check it first.
- Clemence
I have interest
Clemence, maybe open a separate ‘feeler-topic’ for 219B V1 9080?
NVSW219B-V1 9080 max bin is D180 (sw27); D200 (sw30-sw35); D220 (sw40-sw45)
NVSW219C-E 9050 max. bin is D220 (sm27x-sm35x); D240 (sm35x-sm40x)
So, no 219B 9080 has higher bin than 219C 9050. And 219B 9080 only available in warm white (2700K - 4500K), coller CCT’s are max at 9050.
This narrows down the CCT options to only sw27 - sw45. I believe more people are likely to choose either sw40 and sw45.
- Clemence
I vote for R9080 sw45k. Would be happy with both NVSW or NCSW.
sw45k is special, because it’s only available with the R9080 versions.
I am interested in 9080 sw40 , but sw45 is good too.
R9080 sw40 & sw45
I have interest for R9080 sw40
I’d buy some 219b v1 r9080 in either sw40 or sw45.
Mee too
My vote goes for the 219B V1 sw40 R9080
I’d be in for 4, and crossing my fingers for D220 bin!
I wonder if the R9080 are just Macadams Step 7 but hitting red Cree area binning (4A, 4D, 5A1, 5A4, 5D1, 5D4)
Lol, maybe you can just ask Nichia for some Cree bins (4A, 4D, 5A1, 5A4, 5D1, 5D4) in Macadams step 7 R9050? :stuck_out_tongue:
I forgot to mention:
The leds of TheOnlyDoc, chouster, BoringlyUnique, MikeC, badhakker, prisma, Mitko, ZFL-M60, Jerommel, cula, maukka and X3 were shipped last wednesday or thursday December 21/22.
I assume that delivery times will suffer from being in the middle of the christmas mail, but I hope that everything will arrive in good order.
I would appreciate it if you report in this thread or via PM when the leds arrive.
