As the resistor mod using an R050 gets similar readings than Manker U21, and I fear it may be dangerous for the driver, I made this mod using an R100 from Fasttech.
I’m running one of my UT02’s with 3 R10’s stacked for 4.8amps at the tail cap, no idea what it is at the LED and it’s running fine so far, driver seems to be alright, but only time will tell!
The other UT02 I modded with a MT-G2 on a 26mm Noctigon and a FETDDLDO standard E-switch firmware 6 level driver, and got rid of the stock switch and swapped in a Courui D01 switch using the stock boot and plastic cover, making the click more robust and sharper feeling to me. Had to make a copper driver adapter for the 26mm to 30mm driver pocket out of copper crush washer rings, which spaced the battery tube out, and allowed more room for the (2) 26350’s
At only 6amps at the tail cap, this light handles the heat very well, the beam is super nice, creamy/rosy tint, plenty of beautiful flood and decent throw, lights up the neighbors garage across the street like daylight even thru the street lights glare. In total darkness this thing ought to rock!
My UT02 I received yesterday and it is great.
As it turned out, the flashlight, as in U21 are undocumented modes. To access them: from off hold down the button for 10 seconds. After 10 sec. flashlight blink 2 times for maximum brightness
and turns off. Now we are in a hidden level. In this state, the group Strobe / Breath Flash / SOS added Turbo + (no step down) / Beacon / Constantly glowing blue button.
What’s the last mode I do not understand (solid blue light). With a discharged battery changes color from blue to purple. (Battery indicator?)
Turbo + no step-down: working at room temperature until automatically shuts down due to overheating (when the head temperature reaches 50 ° C).
Also, if the mode is enabled Beacon and we will do two-click a flashlight off. After one click enters in which you can adjust the brightness in Low mode.
It has 21 degrees of brightness and adjusts from minimum to maximum (each click changes the brightness). To store the desired light intensity, a flashlight must be switched off.
Visually Low mode, you can do an equal brightness mode Med1, ie from 15 to 100 lumens.
To exit the hidden group acts the same way: when the light is turned off hold down the button for 10 seconds.
After 10 sec. blink 1 time for maximum brightness and turn off which means dropping the hidden level.
Have fun!
I just received my UT02. What is the “breath flash” suppose to do? It is found after the strobe and all I see is the indicator light changing from red to purple. Does it do something else? Does it have any meaning?
I tried one of mine very briefly and it worked. The only 26650 that I couldn’t get to work was the Klarus battery that comes with the G20 (button top). I also had trouble with a button top protected Keeppower 18650. Everything else worked, which were flat top or semi-flat tops.
