HKJ
(HKJ)
December 28, 2016, 5:08pm
1
Keeppower IMR18650 NH1830 3000mAh (Black) 2016
Official specifications:
Nominal capacity: 3000mAh
Minimum capacity: 2900mAh
Nominal voltage: 3.70V
Charge voltage: 4.20V 0/-0.05V
Standard discharge cut-off: 2.50V
Standard charge current: 1000mA
Charge current cut-off: 50mA
Max. Constant discharge current: 20A
Max. Pulse discharge current: 35A
A high current and high capacity 18650 cell from Keeppower.
The two cells tracks perfectly.
At 15A the cells gets warm.
At 20A they get hot enough that I had to terminate the discharge just before the cell is empty.
At 30A the temperature reach 87°C after I terminated.
Conclusion
This is very good high current cells, but watch out for the temperature when running at 20A+.
Notes and links
The batteries was supplied by Keeppower for review.
Compare to 18650 and other batteries
will34
(will34)
December 28, 2016, 5:32pm
2
Thanks for the test!
Looks like a 30Q but comparing the two it seems like this keeppower has better performance.
Hikelite
(Hikelite)
December 29, 2016, 2:01pm
4
Nope, on the better performance part.
Here is the graph comparison from HKJ’s comparator. (If you don’t see the image you may post that you don’t see it.)
It matches 30Q.
Speed4goal
(Speed4goal)
December 28, 2016, 6:51pm
5
Looks like the new batches of hg2 mooch has been talking about. He rates this last year of hg2 as a 18-19 amp cell. Says they overheat at 20amps now when they didn’t when they first came out.
The discharge curves look much more like 30Q than HG2.
Speed4goal
(Speed4goal)
December 29, 2016, 1:57pm
7
Your one of the battery experts wolf. So 30q it is
Thanks for one more great review HKJ. :+1:
Seeing HKJ’s battery test comparator I thought it was a disguised 30Q, but after 15A looks like the Keeppower has better performance. Impressive high drain 18650, I hope for some promo prices in the near future…
