Three Oslons tested: 1) latest gen. Oslon Black Flat 2) SSL80 4000K 92CRI latest gen. 3) SSL80 4500K 96CRI 1 gen. before latest
I emailed MTN electronics, he said he will look into it, try to get a few for himself first and then see if he will sell them.
Hopefully he will :slight_smile:
Very good news, thanks!
Great! Thank you, Enderman.
You’re welcome :slight_smile:
Hey, interesting emitter!
Just requested a quote from RS (UK) for 5 pieces of Black Flat v1.2 5500K, but i read Djozz is waiting for v1.3 high CRI?
Either way, subbed to this thread… :slight_smile:
What does “v1.2” mean?
Ehm, not sure what you mean, Jerommel. AFAIK the current Black Flat is the latest one, it only comes in one tint and there is not a new version announced.
I am waiting for the high CRI 3rd generation Oslon Square (is out now but no one sells it in small quantities yet), if that is what you refer to?
Ah, yes, that must have been it…
I sometimes mix up the types, names and numbers in my head with all these emitters…
LUW HWQP is the 2nd version of the Black Flat, “version 1.2” as they call it in the data sheet.
LUW H9QP is version 1.1
So even though digikey has a 2000 minimum order I found it on mouser for $5 a piece.
http://ca.mouser.com/ProductDetail/OSRAM-Opto-Semiconductors/LUW-HWQP-8M7N-EBVF46FCBB46-8E8H/?qs=sGAEpiMZZMt82OzCyDsLFM%252b7yORtb%2FhA55GIye8lCf8%3D
It doesn’t look like you can order a specific bin.
MTN electronics hasn’t updated with any info about stocking these yet , so if anyone wants to reflow it on their own and test it out go ahead :slight_smile:
You never asked for a link, I could have told you that.
Osram almost never sells specific Bins. This explains the high variance between the LEDs.
It’s been a while, I have recently ordered 10 of the Black Flats for my next project.
Mountain Electronics doesn’t seem to want to stock them, so I will have to reflow them myself.
I’m going to use Noctigon XP-32 because of the thickness and area, it will help with thermal transfer from the MCPCB to the heatsink.
Depending on how easy they are to reflow, I might test two, or all 10 of the LEDs I get. I didn’t have enough money to buy 10 of the MCPCBs and reflow them all at once.
Not sure yet if I want to use a 240mm liquid cooler or a regular air CPU heatsink to do my testing.
The air cooler is what will be used in the final build, but at the same time I’m going to be doing my testing with regular thermal paste instead of liquid metal so maybe using the liquid cooler will balance that out a bit.
I probably won’t be measuring lumens unless I get access to the integration spheres at my university, but if they are easy to reflow I will be binning all 10 to find the best performing one for my build.
It would be nice if you post the results of your binning process. I would test each LED at maybe a low current and a high current (4-4.5A). Additionally you could also check what each LEDs maximum brightness is and at what current.
Yeah, it won’t be super useful without lumens but it could tell us where the peak current is with better cooling.
If I do all 10 we should be able to see the difference between flux bins.
Do you have a spare (small) smooth reflector? You could measure the luminous intensity and we could calulate the luminance and approximate the lumens from that.
No not really, just lenses.
If I have time this coming year then I’ll ask if I can use an integrating sphere, will be much more accurate than anything else.
Looking forward for this test.
Djozz recently build another flat black in Supwildfire reflector and he got 350kcd while I with old xp-g2 s4 2b(previous throw king) in my best Supwildfire build got around 300kcd (when I calculate lux meter difference data that I was given from Djozz). But I probably did not had the best xpg2s42b here.
BTW where did you bought them? Can you share us a link? Maybe I would like to give it a try in a smaller aspheric and of course with precoolimator.
Pretty sure mouser.com has them too if you’re in the US.
HWQP is the one you want, and no place sells individual bins, they’re all a group from 8M to 7N so to get the most out of the LED you need to buy a lot and bin it yourself :frowning:
Thanks Mr. Enderman.
“They’re all a group from 8M to 7N so to get the most out of the LED you need to buy a lot and bin it yourself ”
Yes this is certainly disadvantage… Especially for guys like myself that are selling their mods.
I know Osram has great stuff like 4715AS emitter(with that emitter they listened to customers and made superior product to previous 4715S) , and if they will further develop this led and maybe even enlarge it will be a winner.
