USB Rechargeable 18350 Convoy S6 Triple
Very impressive, how did you drill the holes in the light?
I always like modded lights from CRX but this one looks extra well done (if that is even possible.)
Such polished fit n finish on this light & it’s so practical too. This light needs to go into mass production.
Thanks, i just used a battery drill with 1.5mm bit, drilled three holes and filed out the slot with mini diamond files. The charging indicator is a single hole filled with UV setting glass glue.
Thanks very much mate :+1:
Nice mod, your hand-made work is impressive!
Still practicing, but getting better :slight_smile: Thanks.
I’m amazed you did not break many bits and could drill 3 holes close enough together to bridge them with a mini file
Me too! :laughing: That was the scariest part of the build and went much better than i had anticipated.
The aluminium is really quite soft once you get through the ano. I tried a new trick and cut a small line with a junior hacksaw on this one first.
Interesting, interesting, i had a thread about the soft aluminum a few years back, i’ll see if i can find it
CRX,
Well Done, Love It.
Liked the Lateral Thinking with disconnecting the circuit to reveal the charging port.
Cheers,
S-L :slight_smile:
Yeah nice mod
But seriously an Eagle Eye X2R might be a simple solution
Thank you :beer:
Thanks, but i fear you are missing the point :wink:
I have an Eagle Eye X2R on order, should be an interesting light.
Very cool mod, CRX!
Nice
I have been planning a similar mod for a while but haven’t gotten there yet. I laid out a charginging circuit with the components of a commonly available circuit. I have the parts on hand but haven’t worked out how to order the boards.
Wow well done! :wink: :+1: Your skilz and builds are amazing! :beer: You must have been a watch maker in a previous life!! :smiley:
Clever build :slight_smile:
Ingeniously done!
(The pictures are kind of dark. A bit of lighting will make the details more visible i think.)
Very nice work again, you clearly spend serious time tinkering what should be possible and have most of the build thought out before even starting.
Inspiring stuff! I might well make something like this myself based on this build, thanks for sharing.
Thanks for the inspiring comments gentlemen :beer:
Added a couple new pics to OP.
Very nice build, I’m really impressed!
