22mm / 24mm / 26mm Contact Board - OSHpark project
22 posts / 0 new
HarleyQuin
HarleyQuin's picture
Last seen: 1 year 6 months ago
Larger contact boards are a rare item. Thankfully several members here had designed some contact boards and published them as OSHpark projects. I took the liberty to make a line of boards to my latest needs and I’m quite happy with the result.
22mm contact board
24mm contact board
26mm contact board
This is how the 22mm version came out.
The design derives from the well known 20mm board and has the following mentionable features:
  • 11.4mm plus pad allowing large springs
  • 5mm center hole, so the Nanjg 105c spring fits perfectly
  • Center hole as via and additional Plus vias
  • Ground vias have 0.9mm drill size and are arranged on a 15mm circle so that any version of Nanjg driver can be piggybacked with wire (3x, 4x and 8x Nanjgs have different ground via positions).
  • 3 different sizes to choose from, so filing and cost are kept to the necessary. They’re costly enough for a contact board, but much easier than copper rigging the 20mm board as I used to do earlier.
Comparison shot with the 20mm board.
With some Nanjg boards.
Here’s the 22mm version in use on an Ultrafire F10 build.
Feel free to use.
Enjoy.
Oshpark Boards:
HQ ProgKey: Universal Driver Programming Key . Boost: HQ 15mm/17mm programmable boost driver with ATtiny13A
46mm Triple-Channel: BLF SRK FET v3 . 17mm Linear: HQ10D / HQ4D / HQ4S . Contact Boards: 22/24/26mm
Edited by: HarleyQuin on 05/14/2016 - 20:43
MRsDNF
MRsDNF's picture
Last seen: 1 hour 19 min ago
Thanks HQ. You will have to get a link put in the Oshpark thread.
HarleyQuin
I did post a short message there too Smile
Oshpark Boards:
wight
Looks pretty sweet to me. I’m looking at the picture with the Nanjg boards: is there any issue with components touching the large exposed copper area on top of the adapter? Are you just using kapton tape or is that not a problem?
Good work.
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
TheGloriousTachikoma
Last seen: 4 years 3 months ago
So it would be about $15 for three of each board then? Am I reading their pricing policy correct?
Also, thank you for designing these, I can think of uses for these already. Particularly for my BTU Shocker, which has a jury-rigged 20mm contact board right now, a 22mm would work perfectly.
HarleyQuin
The contact board sits on the 4 AMC7135, which are the highest parts of the Nanjg 105c on the spring side. But admittedly the difference in height is small. If you solder the board askew, you might touch the stock capacitor. You really wouldn’t want to do that Smile
Goodness, no.
When you click on ‘order’ for the 22mm boards it shows:
“Your design will cost $3.75 per set of three.”
That includes shipping. So it’s 1.25 apiece. That’s way more than the 20mm boards from Fasttech, but it’s still reasonable, at least for me.
Oshpark Boards:
Goodness, no.
I saw that after registering. It’s very reasonable for a custom printed contact board, but I don’t like how one can’t create a composite order [no ‘add to cart’ button]. Also, what’s their average turnaround time for making an order?
Cereal_killer
Cereal_killer's picture
Last seen: 5 months 5 days ago
If you upload the files yourself boards usually ship in about 10 days, ordering other people’s uploads are slightly lower priority, usually they ship within 14days. Nothing is set in stone tho.
Boards look good HQ, I have a 26mm contact board I’ve heard from a few people work great. I have mine most masked but you can scrape the mask to expose he copper pours underneath.
Edit: here’s mine
I like watching everyone’s eagle skills progress, seems most of us start out with something like this (this was my first shared project and look at me now). Keep it up HQ.
HarleyQuin
Hi Cereal_killer,
these Eagle/OSHpark combination is a hoot – and is getting addictive.
It’s fun to see how many already contibuted to the OSHpark projects thread, if only by making boards for their needs, and in that way helping and inspiring others.
Will do.
I made these boards some time ago. It took a while for them to get made, being sent to Europe, surviving customs and getting in use by me.
I was quite busy in the meantime, learned a lot. H)
Had good help. Beer
Oshpark Boards:
wight
My mistake! I should have known that without looking – I’ve relied on the height of those 7135’s myself. When I looked at the picture I saw something shiny touching the contact board. The shiny thing I saw was the copper you used to sew the two PCBs together through the vias (nice!).
wight
FYI if you order several things in a row they almost always ship to you together. They have a system which combines orders for shipping as long as the orders are produced on the same panel. Generally only about 1 panel of boards is produced per day. It’s not the same as having a cart, but it’s something.
WarHawk-AVG
WarHawk-AVG's picture
Awesome..thanks!
Run this by Rufusbduck the OSHPark thread OP, so he can add there (if he hasn’t already)
Tom E
Tom E's picture
Last seen: 6 hours 31 min ago
Dang these look awesome! Gotta order some 22's - that was an impossible size to find before this. Closest was 21mm I believe from IOS, and other sources.
Splott-Light
Splott-Light's picture
Last seen: 1 month 2 days ago
Hi. HarleyQuin,
Just ordered some of these, my 1st order on OSH Park!
Got about 10 Ultrafire F13’s with this size board that the Late Great Old Lumens did a Special Price on with one of the Chinese suppliers.
Been meaning to get around to Modding the awful driver (has High, Not So High and Medium Modes with good HIGH PWM, plus blinkies) before gifting, but only managed one 17mm Nanjg swap in so far due to the odd 22mm size.
Many Thanks.
S-L Smile
Ouchyfoot to a New Member: Welcome CJ. Now you have to learn about buying an inexpensive flashlight and modifying it until it either blows up, or starts small fires on the moon…………
Hugh Johnson:
I, too, once lived a tragic and empty life. Then I found [portable] light.
You forgot to mention clothes. I sold most of my clothes to fund my light collection. This is actually fine, since I only go out after dark, and most people can’t see me.
Finally, I got my priorities straight.
HarleyQuin
Hi Splott-Light,
thx, it’s nice to see these boards can be of use.
When your boards arrive, I’d be interested to know:
Does the center hole (a via) still come plated?
Which Nanjg do you use and does it’s spring still fit through the hole?
Happy modding
HQ
Oshpark Boards:
Splott-Light
Hi,
I’ll let you know when they arrive.
Cheers,
S-L Smile
Hugh Johnson:
Splott-Light
Hi. HarleyQuin,
Arrived today.
Via in centre Is Plated.
Using a 17mm Q-Lite 8 × 7135 Rev.A and spring is just about a perfect fit, slightly moving a fraction of a Millimetre, but not a problem as via plated.
Hope the above helped.
I just realised I forgot to order wire for the 0.9mm holes to put the boards together!
Any advice on width to buy, or recommendations for a source, I’m in the U.K.?
Cheers,
S-L Smile
Hugh Johnson:
HarleyQuin
No source for you, I’m continental.
It’s called bell wire here and small but solid copper wire.
Oshpark Boards:
Rufusbduck
Rufusbduck's picture
Multi conductor for irrigation control is solid single strand like bell wire. A foot or so of scrap wire in a variety of sizes goes a long way.
Scott
Splott-Light
@ HarleyQuin,
Many Thanks for the info.
Cheers,
S-L Smile
Hugh Johnson:
Splott-Light
@ Rufusbduck,
Thanks for your help.
Cheers,
S-L Smile
Hugh Johnson:
idontunderstand
Hi guys. Where can I purchase a 26mm adapter from?
