Yup, and I love it in a trip. I used 20 awg wires and removed tail bypass to get it down to 11.55 amps. It started at over 16, to much for a titanium host.
Waiting for drivers here, but will soon do a triple 219C 4000K in a Convoy S2+
I’ll be using 16x 7135.
Well, I went for 16x AMC7135 now. But I don’t know if I’ll leave it that way, this drivers gets freaking hot. No wonder though, about 5W or more getting dissipated. Have to do some more testing. Not a good idea to use high drain 18650’s, obviously…
Where are you getting the high 7135 count drivers? Mountain Electronics?
I stacked a Nanjg 105D with 8 additional chips.
They need their cooling too.
But when the battery lowers towards Vf of the LED (s) they won’t get hot anymore.
yup, I tested with fully charged LG HE4, not what I’ll be using in the finished light. Will use a protected 3500mAh cell, so the excess voltage won’t be that high.
Hmm… then the battery will get warmer due to its internal resistance…
So what’s worse?
The modern 3500mAh cells should have no problem with that current. I think it’s better the whole cell gets warm a bit from within than having the driver in front of it running hot over 90°C.
Thanks for the comparison chart!
Just to clarify, this is a D240 bin against the D320?
Chart mentions D240 but Thread title says D260?
I assume it’s the D240 as that is what clemence had gotten. :+1:
EDIT: according to the output numbers at 1A and 1.5A the D320 acts more like a D300 bin.
I am not sure which one the 90CRI are binned as technically to be honest.
Seeing as the D320 came up very close to spec (slightly under 320 lumens at 700ma) and the 90cri came up closer to D260 (a bit over 260 lumens @ 700ma), I am thinking they are either D260 or very high binned D240’s.
IIRC Ray said his 4000k 90CRI emitters were D260 so they do exist.
Just ordered 2 219C 80CRI leds from mountain electronics.
Are these 90CRI versions available somewhere?
Rey (WWEFANS) had a full reel of 90CRI 4000K 219C leds and sold them via PM, but I believe he is sold out atm. Then there is a sale thread by clemence for several types of 90 CRI 219C’s, round 1 and round 2 is finished, but there will be a new round (and new thread) one of these days.
I tried to buy some more of them from Rey a couple days ago and got the bad news (sold out). :cry:
They’re really nice and I want to put them in everything it seems…
Why not order from KD
http://www.kaidomain.com/p/S026299.Nichia-NVSL219C-R9050-D240-4000k-CRI92-LED-Emitter
On triple they are cheaper
http://www.kaidomain.com/p/S026302.Triple-Nichia-219C-Neutral-White-4000K-CRI92-LED-Emitter-with-20mm-x-1mm-DTP-Copper-MCPCB-w-optics
I think now that I should have asked before I made order since for 10USD of LEDs there was about 14USD of shipping.
Asked for cancel and naturally after 10min of sending the mail got confirmation of “shipped” :student:
ANYWAY:
They are 80+ and 5000K which I think I like more than 4000K but cannot say for sure yet, so I´m ordering couple from Kai also
Many people. It’s one of the options for the mtnelectronics triples when they’re in stock. Here’s mine with the 80 CRI 5000K D280 and a mtnelectronics FET+1 driver. It can run on max for about 90 seconds before it’s too hot to hold and powers on at over 3000 lumens according to my integrating shoebox and smartphone lux meter.
That’s not my only direct-drive 219C. I put one from the first batch of 90 CRI 4000K D240 in an Astrolux E02. This light is definitely direct-drive, but it uses much smaller FETs than the mtnelectronics drivers. The integrating shoebox reads 1100lm for this one.
I like that idea, a shoebox. I suppose you could get decent results from any sufficiently reflective and spherical-ish cavity once calibrated. I think I want to build an integrating yard frog, I just need to find the right product to mod.
In the meantime I need to get some of these Nichias. They sound most awesome as is, but does anyone know if a R9080 version is available anywhere yet? I’m a deep-red-rich-LED-junkie tint snob.
Thanks!
Can someone enlighten me on what the Dxxx means on the nichia leds mean? I checked the datasheet and I didn’t get much out of it. Apologies for such a noob question
