Get you some 1.5 or 2 mm DYNEEMA and call it a day.
Just don’t wrap it around your wrist if there is a chance it or your light might get hung up on an object large enough to drag you. Cause it will rip your hand off before it will break.
Thanks Teacher, you just cost me $40!
Marlow D12 Max 78 at 3mm is a black cord with a 3300 lb breaking load! Yes, a 1/8” cord with a ton and half capability! Rip your hand off, yup! Got some coming, now I have to learn to splice cord. lol
This sailing supply site likes the high end shipping options. I started not to buy because of that then realized even at some $2.00 a foot final cost it’d be some really cheap lanyards that would hold up exceptionally well. We’ll see how that plays out. I bought 20’ of this one. A 10mm cord could be used to tow a car for pete’s sake! (over 20,000 lb bursting strength on the D12 with SK75 Dyneema. Astonishing! Higher grades are much stronger of course.)
No problem my friend… anything to help further our collective obsessions.
Yeah ‘DB’ that stuff is very expensive but it is amazing, to say the least.
Check out some of the breaking strengths on this Chart of Mooring Lines made of DYNEEMA by Samson Rope. Unreal!!!
You can probably pick up some “splicing tips” on the Samson site too.
Check out the video Why Splice first off.
And yeah, this is not something you would want tightly wrapped around your wrist in the form of a lanyard or use as a necklace unless it had a breakaway release. Otherwise you would be an injured or dead duck in a ‘hangup situation’.
Of course that probably applies to other products as well.
Which brings us full circle, back to the OP’s “issue”. Could it be that they intentionally use the small loop at the end of the lanyard as a safety release of sorts? Purposely sized down so it will break before too much damage is done to the user in a hang-up situation?
Very possibly so. :+1:
Kinda off subject, but several years ago in my town there was a city worker that was riding in the back of a truck with a flat dump with sides on it. They stopped to pick up some stuff on the side of the road and when he jumped out his wedding band caught on the siding and he hit and broke his neck. Killed him instantly.
A freak accident, but it goes to show that things can happen fast and unexpectedly.
I worked at a lumber yard and made deliveries to building sites for many years, drove a 20’ flat bed truck with a dump bed. There were stake slots and a protective band around the entire bed. Once I had a large load on the truck with various building materials, I’d gotten on top of the load to secure chimney flues and fire brick and in jumping off my toes caught in that protective steel band around the side of the bed. I pivoted down and did manage to get my hands up to catch myself but still broke a front tooth out, chipped my glasses, and broke my right elbow. It was like lightning, so instantaneous. So yeah, I know how fast things happen.
Maybe a 3000 lb strong lanyard isn’t the best of ideas, I have some 50 lb test Spiderwire I can tie the lanyard onto the light with, that should give a measure of breakaway while still being rot, chemical and abrasion resistant.
I helped out a buddy of mine who wanted a small light to EDC at his job as a ride mechanic at a popular theme park .
I ended up getting him a Thrunite T10 . I put a stainless split ring through the lanyard hole and made a short lanyard out of elastic cord . He was able to adjust the lanyard until the cord gripped his wrist just enough to keep it safely fastened while on the job . It also allowed him to grab it and use it quickly .
I have given him several feet of the elastic cord and he told me he has replaced the lanyard a couple of times in the past couple of years .
So for a small , lightweight flashlight , elastic cord is another option .
You gonna give us some paracord tying lessons Jack?
If ever there was a Master
With cord or string or rope
It’d be Jack the Clipper
To give us all some hope
With snakes and leashes and lanyards
All made by sleight of hand
The most popular way to carry a light
Is a custom from Jack the Man!
Sign me up for the 101
On Tying up a wild lumen beastie
The last thing I need is to see a fav smash
When the cord fails from being all yeasty. (ewwww!)
Um , thanks for the tribute , Dale .
I wonder how many of the lanyards I made and gave away here are still in use ….
I’ve never trusted those thin buggers- they’re certainly not up to being used as a carry strap; perhaps they’re more a safety-strap if you lose your grip on a light And if you’re dropping your light that much then shame on you!
Phil
as a kid growing up, I knew several working men who were missing their ring fingers. Same problem.
Yep, same here. Many workplaces require the removal of rings and jewelry now a days.
A ring that has been mashed out of round on a finger can represent a problem also. … Ouch………
Like SawMaster, I depend on the lanyard as a safety net. I don’t carry it by the lanyard if I can help it but instead rely on it to catch the light should I drop it.
Similarly, I use a smaller light with a pocket clip by carrying the light inside a pocket, clip on the outside. I’m not going to trust the clip to keep my light for me, if it fails I want the light to fall into my pocket, not on the ground. I gave a modified Eagle Eye X6 to my Son-in-Law who is a Pizza delivery guy in a rural area, he uses the light every day. He carries it with the light on the outside. He’s dropped it numerous times and it’s getting pretty beat up looking, still working though.
u are correct, and why shouldnt a lanyard last longer for a light of this price? facepalm dude… my cheap lights ive been using for years havent break down or any other for that matter thats why i made the thread…
Let me make sure I have this correct………
- Is this the light you are referring to?
- And the lanyard attaches on the tactical ring?
- And this is what your lanyard looked like when it “broke” after 6 months use?
- And you think it is Olight’s fault?
.Surely you jest………… :person_facepalming:
Uh ofc its their fault, if u would read i said the hole on the bottom is kinda sharpish, they didnt smooth it out so its really not my fault for using the supplied lanyard to my olight flashlight like any other normal person that would have bought the same flashlight would do. a thicker wire where it snapped would not break down like that thats a fact. But its pointless blabbering about this i already have new ones on the way.
I read exactly what you wrote and said ‘mortuus’…. more than once, to verify my disbelief was indeed real.
And I agree with you on this point, all the blabbering is pointless. :+1:
Hope your new lanyards work out well for you.
Whoa, Jack! I just realized… that’s a FOY picture!!! I’llbeforeverdanged!
Yep . It’s only been a little over a year since we saw the last of Foy .
REPOST
There’s a guy on this board that’s named Foy
When posting he doesn’t play coy
He says what he sees
All the rest will agree
He’s a Solarforce shill , that’s his ploy
Well flashlights are his favorite toy
And his neighbors he’ll sometimes annoy
While they’re trying to sleep
He’s up shining lights deep
Into backyards and alleys with joy
Lots of energy he does employ
and his spare time he’ll sometimes destroy
When he buys a flashlight
He will stay up all night
To make sure it’s the Real McCoy
Shock cord is fantastic & makes an extremely versatile lanyard.
Some old timers might remember this…
I got some of the 3mm Dyneema cord in today, SK98 I think, some 3000 lbs strength rating. Spent some time this morning learning to tie a knot that looks like a ball, fitted several favorite lights with this nice looking black braid cord so I won’t have to worry about em hitting the ground.
Edit: Ah, sorry, I got the Marlow EXCEL D12 MAX 78 3mm Black which has a 3322 lb breaking strength. Crazy! The stuff is pretty cool, a bit tough to tie paracord knots in but then, I’m watching YouTube’s to learn how so it’s probably me as much as anything.
