Although I am not sure where they can be used. I wonder if the old MAG 2C incan will fit a pair of these? Probably not since they are longer then the 65mm length.
I was looking for 22500 for 3x AAA lights, but i gave up the search.
These 20700 newcomers will be better quality anyway, but will only fit if the 3x AAA carrier is a tall one with a top button.
Otherwise you have a 20mm sized problem…
I’ve been able to use the Sanyo 20700 batteries in several 26650 lights and they fit in all my recent chargers. So one can play with them a bit without resorting to custom stuff right away.
This thread is about the 21700, or 21-70 as Tesla has decided to designate it. Yes Tesla has already said they are moving to 21-70, they are already making them in their Gigafactory.
I think the 20700 by Sanyo is essentially being cleared out. It’s a guess but it appears the industry will standardize on 21700; Tesla, LG, Samsung are all there. Panasonic is a strategic partner with Tesla and provided all the machines to make their batteries. I think their testing is over, 21700 is the future for eBikes, Electric Cars, and more EV products. Eventually other industrial uses will probably appear. Given this I can see Sanyo and Panasonic having 21700 cells (even if they are just reclassified 20700) cells ) There is no doubt that the 21700 (Tesla 21-70) cells are a new standard cell in the EV Industry, and they are bound to expand into other industries.
Sanyo could be just trying to get out as many samples as possible to potential customers and hence they are showing up at smaller retailers. It also helps their name get recognition, because a few places can get you a Samsung SDI 21700 or LG 21700 unless you are a pretty big player then you can get smaller quantities as engineering samples. Although I hope some smaller wholesalers will have access to 21700 from more manufacturers, I’m very happy we can get our hands on the Sanyo 20700 for now. Still in any case there are obviously excess capacity which I believe is because they already have 21700 (or upgraded 20700) cells they are selling to the big boys.
This is very very cool. 26650 I have always found too big/bulky, even the smallest light designs. 18650 is a GREAT carry size IMHO… but its nice having another option. More choices can never be a bad thing.
I am curious to see how quality levels will vary on these new 21700 cells, since they come from the same factory (at least initially). Unlike ANY other battery… with GREATLY varying quality levels across each size from a half dozen reputable manufacturers and perhaps dozens more less reputable. Being an automotive standard I would assume 21700 would have to comply to very strict minimum standards for capacity and performance. IE… very minimal chance of getting a “dud” cell.
I would be very interested in hearing from our coveted flashlight brands and OEMs who are participating on BLF:
- What is your opinion on the new form factor?
Do you believe the 21700 cell would be a big enough factor for you to design/engineer and market a new generation of flashlights? Can a battery alone be a factor to change form factors in your processes? Or will the new cell potentially just co-exist next to all other sizes and flashlights?
I am assuming that previous/existing flashlights are engineered around batteries, so if 21700 will become commonplace as the next standard, change will be inevitable?
Pretty sure most are waiting to see just how popular the 21700 will become, same as we the buyers are doing at this point.
You can rest assured that there will be lights released before long to support this size, the first ones to do so will sell quite a few if they are quality as well.
At this point I would not expect much more then the selection you get of 26650 lights.
That said if the 21700 does what I think it will and becomes the new standard I am 100% in favor of it. I think it will be far better for all but the subcompact lights, which can always use a 18350 or 18650.
For one thing it will give a more balanced look to lights like the C8 and the grip size will feel nicer in the hand. Not to mention the extra power.
If it does become the new standard, it would be nice if the size was actually standardized itself also. With strict range of minimum & maximum measurements governing it.
I know that is a pipe dream, because manufacture compliance would be optional…. but might as well dream.
I went with 26650 formats on a few lights. I wanted single cell lights with a bit more than the 18650 could do. 20700/21700 will replace it nicely. I’ll get output and duration far better than 18650. The Panasonic-Sanyo NCR20700A 3100 mah, 30amp perfect for turbo nuke modes. NCR20700B 4250 mah, 15amp for the rest of us.
That’s what makes this case interesting. The automotive industry supply chain is FIRMLY rooted in standardization… EVERYTHING either has a standard or has standards being developed / refined. There are standards for standards even, which sounds crazy but that’s what it is. If your part does not meet spec its scrap and can not ship. So I would be surprised if the 20700 cell length specs were as lose as 18650 and 26650. Especially with Tesla so deeply rooted in 20700 development. We will see though.
Very good points ‘kramer5150’, I had not even thought of that.
And your exactly right, every certifying agency right down to the ASTM will have standards for a ‘21700’ to adhere to in order to be classified a ‘21700’.
It probably will get interesting as we see how it impacts our chose addiction… err, hobby.
Edit to fix typo…. 20700 changed to 21700
Another nice thing about the automotive world driving these cells is that they have needs very similar to ours, the need for both high drain AND high capacity batteries and/or with a good balance of both. Thus it should press forward the higher drain version of cells.
I don’t see the 21700 replacing smaller cells, but if it’s performance comes close to or exceeds the 26650, then that may signal the closing of that chapter in LiIon cells. Bigger is only useful if it’s also better
What I’m most curious about is whether the first crop of 21700 lights will be expanded body 18650’s, shrunken body 26650’s, or an entirely new size of light with a balanced design to match. Interesting times are ahead however it happens :sunglasses:
Why would you need a new charger?, as long as it fits, if the voltage is supported by the charger, and the needed charging algorithm is not too different, it should work.
Yep, all lithium 3.7V cells use the same 4.2V charge cutout and that is all that matters for charging (well and they you don’t try to charge too quick but few chargers could do that anyways).
