With a Xtar 14500 protected , i read about 100 lumens less than using the Efest .
(For all batteries : )
Also , highest mode seems to be able to perform better , it is programmed in the 1st or 2nd level from the factory ( from the 3 output leves of the highest mode , see “Light has programmable output levels for every mode” section in the OP ) .
I have been on holiday travel spending time at various relatives houses the past 1.5 weeks with the UT01 and its been great. I have my modes set up for the two lowest modes and then the two highest modes. Perfect for me… CANDLE > LO > HI > TURBO. So I don’t really have a MED mode. Love the cream white, green-free tint. Of all my NW cree tints this one has the least yellow too… which is good. My cousins friend has a black lab and we went out on a night hike along one of the local creek-side trails, and the UT01 did a great job. I mostly had it on hi and used turbo for short bursts, where it doubled up as a hand warmer too. (win-win !!!)
Travel rig. Solid performer with eneloops too, particularly around the house and I don’t need that much light.
EDC, compact and lightweight with a 14500 cell.
Size comparison with other lights I brought with me, thorfire TG06, 4Sevens Quark AAT.
IMHO they should delete all those disco modes and isolate the battery status indicator by itself, so its out infront of the program mode. That way you can double tap to check the battery and double back out.
Just a quick comment on the UI programming aspect.
To enter programming mode just double tap from either on or off state.
The light will strobe, but just click past all the blinky modes and you will reach what appears to be the low-firefly mode. This is the programming mode however. The light will automatically cycle through:
Firefly - L/M/H (tap the output level you want for firefly)
Low - L/M/H (tap the output level you want for Low)
Med - L/M/H (tap the output level you want for Med)
Hi - L/M/H (tap the output level you want for your Hi)
It will go back to strobe, just double tap to get back out to the normal operating mode.
I bought 2 pairs of both (from KD, cause they ship free to GR). Didn’t see any noticable performance difference. These 14500 TFs must be good. Time (and use) will show.
What surprized me (as my eyes see it - don’t have any instruments to test/verify it), is that comparing with a couple of 2-3 y.o. (but unused) IKEA green-silver Ni batteries, UT01 provides about the same light with the above two Li batteries. Using the same batteries with a ThorFire TG06 and an Olight S15, there’s noticable light difference (in favour of the Li batteries ofcourse). Can’t explain/understand why I see no obvious light difference when using Li batteries in UT01… :question:
