Awesome, very cool. I’m jealous. They did the titanium S1’s last year and my personalized gift is also sitting unused because I don’t want to scratch it up. I didn’t review for them this year so I missed out. A personalized copper light would be awesome with some patina on it though.
Wow so Olight USA makes some Christmas gifts to their reviewers ?
I’m a bit jealous there :cry:
That’s a nice move on Olights part, nice card, nice gift. Well done all around I’d say…
Nice of them, still damn shame this lights dont have a magnetic tailcap otherwise i would have bought one ugh…
My GF ordered the rainbow Ti. for me, for Christmas and I got it this past Friday. It’s a nifty little light and I do mean little. My ET D25C Ti. clicky dwarfs it and forget about my SWM M11R and V11R.
It’s got the four modes, but once you click out of ML, you’re going to have to reacquire it by turning the light off and holding the button for 2 seconds. If you turn off the light in ML, it will come back on in ML.
Locking out the switch is a 3 second press from off position and the 10Hz strobe is a few rapid presses on the button.
I’m not worried about the lvp, as I check my sells often.
I like the gaudy color scheme.
Chris
I found the rainbow Ti on a good sale and grabbed one. It doesn’t have the engraving I wanted, and the randomized colors ended up with more yellow than I had hoped, but it’s still a nice little light. I usually have it or the copper model clipped to me. I generally only want moon or low mode, with occasional medium, and it’s very good at that. Plus, it’s small enough it isn’t really noticeable when I’m not using it.
Mine was $63ish on Ebay, but there was a ‘make an offer’ option, so I offered $55 shipped and it was accepted. $55 is a lot less than the copper, rose gold and black versions go for, so I was happy.
I carry a lot of stuff in my pockets, so I generally EDC smaller lipstick type lights and this fits the bill like my others that I reference just above.
Chris
Is anyone else having an issue running the olight orb-163P03 rcr123a battery with this? Mine immediately shuts off as soon as I enter turbo mode. Thanks!
How old is your Olight 16340 (3.6v/3.7v?) and how many cycles do you have on it?
You might have an older, more tired cell on your hands. I’m strictly running IMR chemistries, either from AWT, AW or Efest in my lipstick lights. I don’t care about runtime, but some of these lights hit close to 3A on high/turbo and I just feel more comfortable with the manganese based cells.
In the case of Ven’s S2+ Triple Convoy that he got me, with LD-2 driver board that hits 6A on direct drive high, so ICR type chemistries aren’t going to work.
Heck, most IMRs won’t work in that particular application. Look for some of the names I mention: AW, AWT and Efest, depending on where you live.
Good luck.
Chris
Sorry man. I’m really new to the light/battery world. The batteries are new. I bought it with the nitecore d2 charger. It says it charges up to about 4.3v but it has 3.7 on the label. Does this help?
I know the D2 and we all started out as beginners, so welcome to the hobby.
4.30v coming hot off the charger is a tad high, but should settle down to around 4.20v (+/- .05v) after say 20 minutes. You should probably buy a digital multi meter for checking things, if you’re going to be playing with this stuff. Trust, but verify and all of that noise.
3.6v/3.7v is just the nominal voltage for lithium-ion cells that we use in most lights. These cells come hot off the charger at ~4.20v. Some chemistries are 3.8v (4.35v hot off the charger) and still yet, some are 3.2v (3.60v hot off the charger,) so things can get confusing.
What you have, I refer to as a ‘16340’ 3.7v cell, which varies in voltage from the dimensionally similar RCR123, which covers the 3.2v offerings (equivalent to the CR123A primary lithium cells for cameras/lights.)
Anyhow, getting back to your cell crapping out on ‘turbo.’ Maybe it’s just a bad cell, as it seems to be cutting off immediately and not lasting say 5 minutes?
I’d still look for the IMR chemistry 16340s and try an Efest, AW or AWT, whatever quality IMR cell you can find and see if it isn’t the light that is at issue?
You have to start ruling things out.
Chris
Wow. You are awesome. Thanks so much for the help. The light either turns off immediately or steps down after about 3 seconds. I’ll grab an imr cell. I’ll keep you posted on how it goes. Thanks again for your help!
FWIW, I run my S-mini with a Trustfire IMR 16340 from FastTech (the red ones) and never had any shut off of the light.
With the Olight 16340 however…even my S1 trips the protection of the Olight batts !
Those are pretty cool looking.
On my S-Mini, it will refuse to go into turbo if the cell voltage isn’t high enough. The cell type generally makes a lot of difference for this sort of thing, since they typically come in either high-capacity or high-amperage varieties. The high-capacity ones get a lot more voltage sag, so they stop being able to do turbo sooner.
Smini brass received without sealed pack. When olight will produce polished and sandblasted stainless steel smini? It will the best EDC.
they should do a new version of the sbaton/mini, felt that the s mini was pointless more or less it didnt do anything better then older s1 baton did and wihout magnetic clip kinda pointless to justify buy.
Still love my bb ti. Small, nice looking and the interface is still one of the best.
I love my Smini Sus…but please… Olight!!! when the Smini in aluminium?
Yes, this !
What I love from my S-mini : the size obviously, the UI (much faster and usable than the S1), the brightness
What I don’t like : The clip that is not adjustable, no magnet (but you can use the S1 tailcap), the lack of an alu version
