How To Make Tritium Nuclear Battery
I stumble across this clip and though it is very interesting but does it work?
Or you can charge a capacitor and really light up an led
It works but the costs are high and you get only a few hundred nA of current
Even small lithium cells like 10180 contain more energy like a nuclear battery can produce in weeks
Or just put the cells in daylight will produce 1000 times more energy
Imagine there’s nuclear winter and there are no sun or power sources to charge a cell.
That’s what nuclear battery is designed for! :slight_smile:
Not really
Thermal nuclear batteries were used in military and deep space probes powers from a few watts to several thousand watts were produced
They powered military radars and other stuff in remote locations for years
For example on the Moon by Apollo 14, a similar battery was lost in reentry of Apollo 13 in the ocean
that’s a RITEG
If you put those solar cells in the middle of the night with moon you get most likely same or more current than with 2 tritium vials
Lexel, that’s nuclear winter! No Sun, no Moon, no stars! Heeeeeeeelp! :smiley:
Your nuclear winter will be so bad everything glows from radiation
Ahaha
