Cree xhp50
Hey everyone. I ordered some xhp50 emitters, and I was curious how many amps and volts the 6v version can take? I will be using the fx6 5amp driver, or direct drive off 2 18350’s. Whatdo you think? Thanks!
Hi Hannes,
This is from my test a year ago. The led was tested outside a flashlight, well cooled and on a power supply. The led was reflowed on a direct thermal pad MCPCB, without a DTP board results are significantly worse. In the graph are also test of The XHP70 and MT-G2, although the XHP70 tested better later when using a better MCPCB.
Hey mate it depends on the overall set up. 5 amps isn’t that much for a XHP50. The smaller cells will limit current if you use direct drive.
That’s freaking awesome, answered all my questions, right there. Thank you so much for that. I truly appreciate it. Amazing forum must say.
Hey mate! I made it to the forum haha, remember me lol ? Amazing place! Yeah, the cells do make a differance, I should be fine then, thanks!
Yea I just seen that you joined. Welcome and enjoy.
thank you! I surely will
One question, how do I upload pictures in posts here, just says url, but can’t pic any pictures up?
ah, thank you!
