no it does not, but we’ll see. How about a direct drive, straight from battery, would lose all modes,but ?
if I used 2 18350 10amp high drains, keeppower?
direct drive will work fine, but all the risk handling is transferred to the user (no low voltage protection, no reverse battery protection: led will blow instantly when battery is inserted the wrong way), and there’s just one mode.
I have made flashlights like that but in practice they see no use, I use lower modes way more often than full blast.
maybe I like it dangerous, haha, It would just be for a short amount of time, I like to run higher modes usually. I already have made some direct drive ones with single modes and they work fine.
I believe the BLF driver can be modified to operate at two cell. LDO + resistor mod. Someone correct me if I’m wrong. I’ve only done it with amc7135 drivers.
how would I do that though? It has a fet and one 7135, how do I add the resistor and where? What’s ldo a diode?
That is coincidently what I tried a week ago, but not with a LDO but with a zener diode: the so-called ‘zener-mod’ on a BLF-A6 driver. It did work in the sense that it did drive an XHP70 led in 2S configuration without killing the MCU, but the user interface and timings were completely messed-up so it was un-usable.
A zener mod on a 105C driver works well, with the user interface un-altered, but the low voltage protection kicks in at a too high voltage, at about half drainage of the cells.
just found an ld3 driver here on blf, and it’s in eu whohoo, this will be awesome.
You are right, forgot about the LD3 (and I even tested it :person_facepalming: ) , that is a great option too! Don’t forget to order it in 2S configuration.
can you run it of a single hg2
An XHP50 runs on 6V, a single li-ion is half of that. A driver that will do that is a so-called boost-driver. The LD3 is not a boost driver, so the battery voltage needs to be a bit higher than the led voltage.
Btw, single cell boost drivers for 6V leds usually have a limited current, you will not get the output of a lineair/direct driver in a 2S configuration.
allright, thank younso much!
Hmm… The LD3 is 3 or 6 amperes…
Can it do 4.5 Amperes?
If you read the LD3 info thread, you will find that a new feature in the LD3 is that there is a user configurable adjustment of the maxium output current, down to 2A off the listed current. So the 6V version can be configured down to 4A.
I saw the same on ebay, and apperently it has options of
3A,6,9,12A, and you can change it in the ui.
2-3A, 4-6A, 7-9A 8-12A
Yeah, i just read that… :person_facepalming:
Thanks. :+1:
No worries!
what would be a good output for the xhp50 then, considering I’ll be putting it in an s2+ or thorfire vg-10, maybe eagle eye x6, one of those? Maybe the 4-6 amps? sure you wouldn’t want to push up towards 12 amps?
I just did a single cell MTG2 on my S2+… The boost driver is 20mm and outputs 3A (stated on the site but i dont have meter to test it) which i believe is more than enough for a small light. I cant find any 1 to do custom pill for me so what i did was sanding off 1mm from the original pill, cover the components using wire tape (because the pill internal diameter is a bit small so i had to protect the component from contacting the wall) n let it sit on top of the pill. Still hope someone here can custom made a pill for me and it will be perfect.
nice! Does it get hot at all I ordered some copper plate to make my heatmanagement better.
