Hobby chargers are very universal, but that also means they are not optimized for a round cells.
This means more trouble connecting batteries, often you can only do one battery at a time and you need more button presses compared to a dedicated round cell charger.
The best round cell charger that can do anything a hobby charger can do with round cells and handles four cells at a time is the SkyRC MC3000, but it is considerable more expensive than a hobby charger and it also has a learning curve.
Maybe getting a cheaper hobby charger and a Opus BT-C3100 or LiitoKala Lii-500 round cell charger would be the optimal solution.
round cell holders are sold cheap online for pretty much any cell, single or multiple, but chargers that are made for round cells can not charge or balance cells in series. for now op does not do that, but you never know what he’ll be up to latter.
i build lights with build in none removable batteries, i use cb radio multipin connections to balance\charge cells in those lights, i use hitek x4 charger, very happy with it, it has 4 separate channels, i can charge\discharge…. 4 cells or packs at the same time, but it was $239 plus tax. at the hobby store.
Correct, but a hobby charger is rather slow if you want to check a pile of salvaged cells. Testing in series is a bad idea in that case, i.e. you can only test one cell at a time.
yes, unless it is x4 you have to do 1 cell at the time
testing cells in series is sure a bad idea.
actually if his budget was up to 100 i’d recommend skyrc mc3000 since he is interested in round cells. it can do pretty much everything hobby charger can except work with packs.
b6 are around 50, however since they are very popular, there are many fakes around, i have seen a thread either here or on cpf on fake b6’s and how to tell them apart.
Didn’t I see a 4-cell analyzing charger talked about somewhere around here? Maybe star? It had the ability to plug in a series pack as well. If I remember right.
I got this one [too?] soon after I discovered the flashlight world and cannot use it because there’s nowhere to put the batteries… A lot of searching revealed that it’s ready for lipo packs (which I had never heard about) and not for the cylindrical cells used in flashlights So much for being a newbie…
Is there a holder/adapter that will connect to the imax B6, allowing for different cell sizes if at all possible? Cabling for doing balanced charging like the lipo packs would be ideal but is not essential.
tons of them available online, for regular size cells you can get holders at radio shack, however those holders come either with wires, or snap in, (9v) type connector, or simply solder connection, i’m not sure about b6 but mine x4 came with wire that had banana plug on one side, (to plug into the charger) and alligator clips on the other, so you can clip it to pretty much anything.
lipo packs already come with balance tail\wires attached, so you wont need any extra wires.
there is mh-c9000 analyzing 4 bay charger, but it does not work with packs nor with li ion cells, nicd\nimh only. i’m not aware of any other 4bay analyzing charger that works with packs and li ion cells, maybe someone else knows about such charger
The opus and liitokala both seem to have shortcomings and they are not able to charge to 4.3V. I have been looking into the MC3000 and it does most of the things I need it to do but I do not like the sound of “tinkering with flattop cells” as most of my cells are flattop. And
Are these issues fixed with the upgrades? I mean your test was done in 2015 so the should be fixed by now no?
Which hobby charger would you recommend, I need a reliable one if I’m gonna charge my 18V packs and lead acid batteries with it as these things are really expensive. I’m talking about at least $75 for an18V pack and my lead acid batteries are way more than that.
Pfff the more I look intoit the more desperate and confused I get. No such thing as a perfect charger I guess.
Yes and it has a few extra functions compared to the software I tested.
But you still need to mount some flattop batteries a bit high. I mostly uses GA cells and they do not have any connection problems.
I will not recommend any hobby charges, I do have a few but do not use them much. If you need information from people that uses hobby chargers, try a RC forum.
I use magnets or 18650 holders. bought them on 11/11 at AE for a few pennies. electronics are my hobby so I had them anyway/can use more of these holders. I also build my own lithium battery packs for other devices like development boards.
edit: the main reason why I bought the imax is I can set a higher charge rate. have plenty of dedicated LiIon chargers and the max they do is 1A for 2 bays. also needed something that works at home, in my car, anywhere really.
you can charge 18v pack with hobby charger, as well as lead acid, i charged my 18v dewalt battery few times with x4, no issues, same with small sla from emergency lights. if you plan to charge car battery, it can do that too, but it’ll take few days or a week even, if battery is big.
I use a DPS5015 and a iSDT sc608, you don’t need the DPS but it does add flexibility. I did a video here playing around with the units but only watch if your considering as tbh it’s a bit long and boring otherwise. Link: YouTube sc-608 at the end I get round to doing a large SLA on the unit.
I also have a few battery holders on route and a dc load, much better than the discharge avalible from most hobby chargers that take forever and discharge nowhere near the rate modern LEDs consume power.
It all takes a lot of parts, effort and time but ultimately you do end up with a far greater range of options.
