Nope, I took the main battery out and swapped it for a LG to do some LUX testing
I took the switch out and it looks normal. The electrical smell comes from the head of the light.
Yea it defiantly shorted some how. What cell did you put in?
Well it cut out on the klarus cell. I was running a Sanyo NCR18650GA before then after.
I had tested my XT11GT tailcap spring for 184mV drop at 5A, so 1W heat on normal operation, if it was too hot to touch there must have been a shortcut of the cell
On long cells the spring resistance gets lower as parts of it get bridged
Weird i can not see any possible way it would short unless there is a problem with the charging circuit.
The charging circuit is seperated from the diode driver, the driver can fry and the charge often works fine
I did disassemble a XT11GT which should be almost identical, just another charge port
You can see the tube for the toggle switch must be seperated from battery minus, maybe it shorts the driver when the battery gets contact to it?
I haven’t got a clue how to get inside the top half. I don’t really wish to either.
I’ll check what happens when I offer it the magnetic charging connector
A question for other owners of the XT12GT, does yours “whistle” when its on different modes. It sounds like the driver is ramping down power and whistling like a cheap chinese power supply. Mine has done it from day one but not all the time.
I finally added the video a week late! lol I think i need a bigger hard drive and some editing skillz would help!
mine came defective from banggood. light shuts off after 10 seconds running on turbo. need to press again the switch twice to turn in on again. sometimes it wont even turn on. i hope that this is just an isolated case and not experienced by other xt12gt users. :person_facepalming:
Have you tried a different battery? Does it get really hot?
I hope they send you a new one quickly mate! Its more common for boost driver flashlight to have issues i think.
Nice review & great pics and video. :+1:
Mine has not arrived yet, it will be a few more days. I’m hoping for the best with mine, but the reports from a couple of you guys are not inspiring confidence.
Time will tell though………
Thanks mate i think its not just the XT12GT its other XHP35 lights also you are boosting the voltage up a lot. That may be part of the issue.
okay will try to try 30q and some protected battery. thank you for the tip, now another problem pop up. the main tail switch is malfuctioning, it can not turn on the light consistently, sometimes it work sometimes it does not. only paddle switch works fine :person_facepalming:
I already contacted swi, and he asked me for videos. will give him two video links instead for the tail switch problem and the light turning off after a while.
Thank you for the big help!
Your welcome my friend. :+1:
That might very well be it, either way; I’ll know more in a few days when mine arrives.
I tried 30q and no difference in light output though at least on my observation. .
I can’t wait until mine arrives. I went from choosing the NiteCore P30 to the UTorch UT02 to the Klarus XT12GT; I was sold on the magnetic charger cable and included battery. I hope this satisfies my wish for a 1x18650 with 300m+ throw.
I’m looking forward to mine getting here also. I have a P30 and am very impressed with it. :+1:
I’m anxious to see how the XT12GT is gonna stack up against it. I might just sell the loser………
Well, the beam profile is that the klarus is pure thrower with almost no spill, very tight hotspot
Its about the same as a C8? Its not super throw heavy.
