Ultrafire DV-S9 diving light?
105 posts / 0 new
Lightbringer
Lightbringer's picture
Last seen: 1 hour 24 min ago
Just got one, beautiful little light, wondering if anyone has one and “dived” (haha) into it yet.
Takes a 26650, or 18650 with the included tube, has a switchless tailcap that covers 3 O-rings. Everything else seems to be put in through the front lens side, ‘though I haven’t opened that up yet. Tempted not to (and risk ruining any seals).
There’s a magnetic switch, a little captive slider with magnet, no opening, slot, nothing. Inside looks like a Hall-effect sensor that reads relatively-speaking how close the slider is, and sets the light brightness accordingly.
There’s a slight “jump” from off to its lowest setting, and v/v. Also, once you get pretty bright, there’s also a slight jump to full-tilt. Nothing objectionable, at least not to me.
Obviously, this critter is always “on”, at least as far as sensing the switch, so there’s some parasitic drain. The threads aren’t fully anodised to the point where you can do a tailcap lockout on it. In fact, with the slider set to “on”, just putting the cap in place makes the connection before even getting the threads to engage. So that means not keeping the cell in the light 24/7.
Gotta say, though, the color is a beautiful shade of indigo, and pix don’t really do it justice. The red trim is a nice touch, too.
So… anyone else have one? Played around with it any? Solved how to keep the cell from draining when not in use? Big Smile
edit: added pic below
Edited by: Lightbringer on 07/09/2017 - 14:47
Lightbringer
Did some poking and prodding, and with cheapo meter-leads, it draws a hair over 2A when running wide-open. Imagine with a direct connection (or thicker leads), it’d be more, maybe even the specced 3A+.
It also has a parasitic drain of pretty much exactly 10mA for the Hall-effect sensor. Not too bad, probably as much as a lighted tailcap.
And it does have a TCLO! Only an eighth-turn or so is enough to lock it out, so if you’re going to be keeping the cell inside, make sure you lock it out first.
Only negative I can mention is that the LED tint is a little bit on the greenish side. Not nearly as bad as my Quark 2AA-X, which is really noticeable, but still tinged enough for me to notice (Mr Tint-Snob).
Really nice light, all in all… think I’m going to get another one while the getting’s good! Big Smile
Splott-Light
Splott-Light's picture
Last seen: 4 weeks 15 hours ago
Hi. Lightbringer,
Thanks for your review.
Any links to the light?
Cheers,
S-L Smile
Ouchyfoot to a New Member: Welcome CJ. Now you have to learn about buying an inexpensive flashlight and modifying it until it either blows up, or starts small fires on the moon…………
Hugh Johnson:
I, too, once lived a tragic and empty life. Then I found [portable] light.
You forgot to mention clothes. I sold most of my clothes to fund my light collection. This is actually fine, since I only go out after dark, and most people can’t see me.
Finally, I got my priorities straight.
Lightbringer
https://www.fasttech.com/products/0/10015804/6550300-ultrafire-dv-s9-led...
http://www.gearbest.com/led-flashlights/pp_469449.html
http://www.ultrafire.com/index.php?route=product/product&product_id=8428
and just in general
https://www.google.com/search?q=dv-s9+flashlight&ie=utf-8&oe=utf-8
right from the horse’s mouth.
Pretty pix, better’n I can take in a pinch. Big Smile
Few if any reviews, though.
Splott-Light
Lightbringer,
Many Thanks for the links.
FT seems to have the best price for me.
All China on Holiday in a Day or two, so will probably look at this again in February sometime.
Did you find this has visible PWM on the lower end of the variable mode?
Cheers,
S-L Smile
P.S. I have modded lights with PTFE plumbers tape on the rear threads to be able to lock out similar lights, may be of help to you?
Hugh Johnson:
Lightbringer
No worries.
Even better with code “BLF” (comes out to <16bux). Big Smile
Yeah, hope my order snuck through in time…
Didn’t notice any, and I think this might even be linear, because to me the slight greenish tint seems more pronounced at its lowest setting. Seems brighter almost NW on full.
Tried the jiggle test and didn’t notice anything, but nothing with a camera.
PWM doesn’t seem to bug me that much, or be that noticeable, so don’t rely on what I just said. Big Smile
Naw, it’s got a pretty good TCLO, less than a quarter-turn, almost an eighth. Just seemed to go on too quickly when first screwing on the cap, but was probably just shorting the battery to case with the spring or something. In fact, really need to snug up the tailcap to make sure it makes solid contact.
— edit —
Naw, it’s PWM. Took a lot of jiggling on its lowest possible output (before snuffing out completely), and I can see it only when doing a rather energetic jiggle side-to-side, and looking askance at the emitter.
Still, to me, it’s hardly noticeable. Ordered a 2nd one just for s&g. Big Smile
texas shooter
Last seen: 5 days 15 hours ago
I would stay away from diving with this light or any other that runs current though the body.
On ships they place aluminum or magnesium plates on the hull to corrode before the steel hull does. Run a current from tail to head and your light will dissolve away.
shrick
shrick's picture
Texas Shooter… what would you recommend as the best budget diving light? I’m trying hard to figure this out… at the moment the Solarstorm DX4s is at the top of my list…
Terry White
Terry White's picture
I got my certification way back in the late 80's amd again in mid 90's. I've let ot all expire but when I did dive it was only with Pelican lights
 Excellent dive lights, a bit costly but worth it.
Terry White
Skype terrywhite1@live.com
shrick
shrick's picture
Terry White wrote:
I got my certification way back in the late 80’s amd again in mid 90’s. I’ve let ot all expire but when I did dive it was only with Pelican lights
Thanks for the recommendation. Had a quick look at their 3 diving lights. The output of their lights are really low, like 150-200 lumens. The plastic body is also not good for modifications… The light I buy must be a good candidate for modifications..
Terry White
Here is one that I have used many times. https://www.adorama.com/pl4300by.html?gclid=CJb-i7Hx19ECFU86gQodvgIF0w
Also remember the lumen rating under water in almost total darkness will be different that dry lights. Water also magnifies light as well..
There are many great dive lights, more now than ever. I am sure better than the Pelican. The one thing I always liked most about a Pelican is none of them have ever failed. And they are guaranteed for life.
Sorry I clicked to the wrong URL when I copied it.. This is the correct one, good to 500 feet.
Terry White
shrick
shrick's picture
Terry White wrote:
Here is one that I have used many times. https://www.google.com/shopping/product/8007433991956771958?q=pelican+dive+lights&rlz=1C1NHXL_enUS728US728&espv=2&biw=1366&bih=638&bav=on.2,or.r_cp.&bvm=bv.144224172,d.eWE&ion=1&tch=1&ech=1&psi=jMCFWPiXEcGcmwGQ3ZjgAw.1485160589555.5&sa=X&ved=0ahUKEwjHm6Xo7tfRAhXJYiYKHXI-AVQQqA0IISgB
Thanks. Is that a diving light? They don’t specify it as being a diving light, maybe I’m missing some details?
Terry White
Thanks. Is that a diving light? They don't specify it as being a diving light, maybe I'm missing some details?
Nope you are right, I was in too much of a hurry and clicked on the wrong URL and copied it... My mistake.. Here is the correct URL and I corrected in my original post . https://www.adorama.com/pl4300by.html?gclid=CJb-i7Hx19ECFU86gQodvgIF0w
Good to 500 feet,
Terry White
shrick
shrick's picture
Nope you are right, I was in too much of a hurry and clicked on the wrong URL and copied it… My mistake.. Here is the correct URL and I corrected in my original post . https://www.adorama.com/pl4300by.html?gclid=CJb-i7Hx19ECFU86gQodvgIF0w
Good to 500 feet,
Thanks. Not that expensive though, but yes, old technology for sure. I hope to find the current best option for the Budget, Moddable (FET based driver replacement) Diving Light.
Terry White
Good to 500 feet,
You are totally right it is old technology. Thing to keep in mind is that high current along with extreme heat, along with conductive metal in the water is a very hard thing to get just right. One of the reasons those Pelicans are still one of the best sellers.
On the other hand I am meeting some of the best and brightest here and next week you could be a millionaire from modding a dive light. I look forward to following your progress. I do not dive anymore, need to go get certified again I do miss it. But seeing your progress will be very interesting..
Terry White
shrick
shrick's picture
Terry, thanks for your feedback.
I’m a total newbie when it comes to diving lights – I know very little about the ‘gotchas’. You’re mentioning issues that I was not aware of yet. My first perception was that modding a diving light should be Awesome because one can push it too the limits without overheating problems – everything stays nice and cool in the water! I’m not yet sure how heat + high current + water causes trouble, I need to get this clarified. The other problem is the variable output switches in many of these lights. We normally cater for clicky & eswitches in the high performance drivers, so, I presume I need to pick a light that does not have a variable output switch, just a magnetic switch, which I believe reacts like an eswitch – I’m not even 100% sure about this, I need to get it confirmed.
As you can see, still lots to learn for me, I’m walking in the dark for now. But, I’m still interested to find out, as soon as possible, which budget diving lights are popular and reliable? From these, I can try to get a feel for which are mod-friendly. Thats very much what its about for me, to build an above average quality, value for money, high performance flashlight, that will last for some time to come.
Strongly doubt if I’ll become a millionaire from modding diving lights… Smile
texas shooter
This one only runs the current through two contacts isolated in the head http://www.candlepowerforums.com/vb/showthread.php?424358-Review-Acebeam...(XHP70-3×18650) http://www.candlepowerforums.com/vb/showthread.php?421092-Acebeam-D45vn-... The slightly older D400 is still available and viable. Both heavy enough for land and water use on the D400 I’d put a rubber washer on the bottom side to insulate any current. They may be pricey, but add salt water and everything changes.
Lightbringer
Yeh, goggle “sacrificial anode”. Even in car coolant systems, just dangle a hunk o’ Mg on a chain and it’ll get et before more critical goodies.
The critter should be insulated (anodised, ie, passivated), so ideally that should protect the body. And there should at least be some potential common to both metals, the protected one and the sacrificial one. The light itself should be a closed loop.
Maybe if the light has a bunch of starter scratches and dings, that’s where it’ll start to corrode first (like paint bubbling on a car where water gets under pinholes in the paint job).
Anyway, I ain’t gonna be using it for diving, as I don’t dive. I just got it because it looks purty, has the “infinitely adjustable” mag-switch, and is nominally at least more waterproof than the usual bunch of lights.
For actual diving, I’d imagine something sealed in plastic or rubber would be best. Also grippier when wet.
Lightbringer
Why do you need to get “certified” to dive? Can’t just plop on all the accoutrements and fall into the water?
Or is this as a dive instructor or something?
texas shooter
In fresh water mostly. In salt water the heaviest anodizing won’t stop the corrosion especially when you place a current through the body. As a fancy toy light she looks good. She’ll also have much better waterproofing than most others. What I like about landlocked dive lights is that a bit more went into making them. They tend to have thicker host and heads. This is a modders dream for heat sinking.
Lightbringer
Yep, this is a nice solid donk.
Ordered a set of 4 LK 26550s from GB to go with (and my L2, maybe, as these LKs are flattops).
This would be a nice critter to keep in the car (barring weather/temperature extremes) for those Just In Case scenarios. 5AH beats 3.4AH or even 3.6AH, and you won’t mind it rolling around in the mud as you’re changing a tire. Big Smile
Well, I wouldn’t keep it in the car, at least not all the time. Got a small Craftsman toolbag (almost always “on sale”, and well worth it) that I switch from car to car. Phone charger, flashlight, spare bulbs/fuses, other crap I would keep in each car but got tired of “maintaining” different versions, so now it’s in one bag that I bring into whichever car I’m taking.
Gotta say again, the color’s fantastic, more of a deep indigo than generic blue as listed. Just like the XTAR WK50 which looked like a pale Barbie Pink in the ads, yet is a nicer satiny “hot pink” in person. Same with this. More than anything, I think that’s why I ordered a 2nd one. Big Smile
teacher
teacher's picture
Good review Lightbringer, thanks for the heads up on this one. Thumbs Up
raynman
Last seen: 2 weeks 1 day ago
Just ordered one of these Ultrafire DV-S9 dive lights, but who am I kidding, I don’t even swim! However, I do like the 26650 size lights, and Lightbringer makes it sound nice – I am sure it will find a use in my collection.
I can confirm that FastTech discounts 5% with the code BLF in case anyone else is shopping…
thanks, Lightbringer, for pointing this one out
Lightbringer
And the “funny” (not really) thing is, I’m STILL waiting for those LKs I ordered!!
I’m still using that old DE-whatever 26650 I got from Rat Shack…
Enjoy, all y’all!
Oh, another addendum is that I love the “waterproofness” of the light if you do keep it with your car (changing a tire in the rain, etc.), and just for the sheer yummy goodness of that ‘S9, for ~15bux?!? Can’t beat that price.
As I mentioned in the other thread, this critter really surpassed all my expectations. I’d consider this my buy of 2016/2017.
teacher
teacher's picture
Dang, that light needed one of these shaft zincs clamped around the battery tube……… Big Smile
Rufusbduck
Rufusbduck's picture
Last seen: 10 months 2 weeks ago
Certification covers the knowledge you need dive safely. Breathing at depth causes nitrogen (70% of each breath) to dissolve into the blood and accumulate in soft tissues and repetitive diving increases accumulation. Coming to the surface too rapidly or getting on a plane too soon can literally make you fizz and die. Deep dives can cause nitrogen narcosis(a sort of drinker disorientation). Knowing how to monitor your nitrogen(or O2 if using Nitrox) along with hand signals covering different situations, proper use of boyancy control and breathing, what to do in an emergency, these all take some practice to become second nature and certification is a means of verifying you have it down pat. Not to mention you need to show proof to get tanks filled. Check your weight belt and turn on your air. Certification doesn’t expire but if you haven’t done it for awhile then a refresher is a good idea. New technology and changes in boat diving practices can take getting used to.
Scott
texas shooter
As long as current is past through the body it wouldn’t help. Current has to be isolated from all external parts. At 8.4 volts 3 amps you could probable see gas bubbles forming if done in still water like a fish tank. Simply having both contacts at the head and none of this would happen.
Lightbringer
Rufusbduck wrote:
Certification covers the knowledge you need dive safely. […]
Kewl, tnx!
mikeyx
Last seen: 1 week 4 days ago
Looks similar to the Starry Light DXM.
Mike
Lightbringer
Ha… twins! Big Smile
I was wondering if there were any “relatives” of this light floating around out there. Now I know!
Pete7874
Pete7874's picture
Last seen: 1 hour 43 min ago
From Ultrafire’s website for this DV-S9 light:
Quote:
Power Supply: 1*18650
Current: 3800mA
Runtime: 4 Hours
Hmm…. something does not add up here. Smile
Anyway, do you have any beam shots?
