You can dramatically improve the fluorescence by filtering any visible light with a ZWB2 glass.
I filed down a 20mm glass from Simon’s store and installed it in my Jet UV.
The result is as good as my liteON 3535 SF348 with ZWB2 !
The tricky part is to be really careful while grinding the glass because, eh, it’s glass
Bulkier, also. But yeah, way more powerful !
I did a shorty S2+ with 3*7135 and that is the sweet spot to have both high output and prevent over-heating of the LED. I reflowed the LED on a Noctigon though.
Chris, a tip for taking pictures of 365nm fluorescence: the camera picks up deeper into UV than our eyes do. To make the pictures more like what you really see you can take the pictures with safety googles in front of the camera, it filters out much of the UV under 400nm, so you do not see the purple glare on the pictures (that you also do not see with your eyes).
I made a 12mm and a 10mm with my Dremel equipped with a thin cutting disc (standard) and then a grinding Wheel.
Took some patience, but was about 1 hour of work for both.
The key is to make a straight cut at the surface with th disc, then trying to cut deeper. The glass will crack following the line.
You then make about 5or 6 more straight lines to make a rough round shape.
Once you have a round shape, you can finish with the grinding wheel. The key is to remove material slowly, and not over heating.
There still is some small chips on the edge, but once installed in the flashlight there are hidden by the bezel anyway.
ZWB2 filters are extremely cheap to make, you can find manufacturers on alibaba that offer all kinds of sizes. But the demand is virtually zero, so the few sellers that do offer them on Aliexpress can ask what they like, there is no competion taking place. And there’s Simon from Convoy who has ordered a batch directly from a manufacturer (20.5mm diameter), and Gearbest ordered 20mm ones. So those are cheap.
I agree. I have both and the security strip on older Benjamins don’t even show up with the Tube-UV. With the JETBeam, you can at least make them out. On newer bills the security strip is easy to make out with the JETBeam. Does a decent job on dog piss too. My daughter just got a new puppy. :rage:
I have a WF502b UV (395 nm, I believe). The JETBeam clearly outperforms it. Not quite as good as my UV Convoy S2+ though. Considering the power source and package size, I’m pretty impressed.
Any idea what the UV output of the 1.5v Jet-UV AAA is, compared to the 3.7v 18650 Convoy?
Im guessing about 60% less, so
IF a Convoy outputs 780mw from a 3.7v source, the Jet-UV from a 1.5v source would proportionally produce 316mw. Sound Reasonable?
and in that case the 365nm AA Jaxman E3 UV should have similar UV output power as the Jet-UV, but longer runtime, yes?
I’m clearly no expert, but I think you also have to consider current output. I don’t know enough to know whether or not the max output of each cell is going to affect overall power output, but since watts = volts x amps, I’d think it would have to, assuming the LED could handle more power than the cell could provide. Even in the case of the Jaxman, perhaps instead of only longer run times, you have a combination of increased run time and power output?
Hopefully someone more knowledgeable will chime in?
Oh and thanks. Now I have another light I may have to buy.
It’s not linear on the voltage. You can’t even run a red LED with 1.5v, much less an UV led. You need to increase the voltage to the Vf of the led, about 3.8V, to obtain any usable output, so any uv flashlight with a single AA/AAA battery uses a boost driver for that. The current will depend on the driver and how much load the battery can handle. For example on a thrunite ti3 XP-G2 the high mode is 120 Lumens (high for a 1xAAA light), looking at the Cree Product Characterization Tool we can see that for a XP-G2 (S2 bin) such output is consistent with 250 mA with a Vf of 2.86V. The 135 Lm output of the Jetbeam mk1 is consistent with 280mA at 2.87V
A similar driver to the Mk1 may give to an UV led 0.28 A * 2.87 V / 3.8 V = about 210 mA at 3.8V. The higher the voltage difference of a boost driver, the lower the efficiency will be , so the current input to the led may be lower, say 90% of that, 190mA. If the 276A emits 780mW of UV at 500mA and 25ºC (per specs), we can assume linearly that 190mA gives 190/500 * 780 = about 300 mW. We need to increase that value somewhat because leds are more efficient at lower current and decrease it again because the temperature is higher than 25ºC, so 300mW would be a good estimate if the led was an nichia NCSU276A.
However the led on the jetbeam is not a 276A but a cheaper led, so we can expect that the efficiency would be lower, therefore the uv output would be lower for the same current.
18650 are much more than 4x as ‘powerful’ as AAA, but the limiting factor for 18650 UV flashlights is heat dissipation at the led (even more for the 276A). For visible light you can use much higher currents than 700mA without problems. For a AAA flashlight the limiting factors would be the ability of the small boost driver to handle high currents and the voltage drop of the batteries, as well as the need of a reasonable runtime.
Thank, you, yes, I agree.
Im just putting together some general estimates of what to expect when comparing a Jet-U to a Convoy S2
both will light up a redline on a US $100
but the convoy will do it from further away, and will spot Scorpions from further away
The Jet-U won’t have as long a runtime either, which is a trade off because the AAA battery weights 33% as much as an 18650… plus the body weight differences…
the whether to choose a Jet-UV or an S2-UV, depends on how heavy a light one wants to carry, based on how far away the target is, and runtime. Same considerations as regular lights, it comes down to a choice of battery, personal preference, based on the primary application or intended use.
