Review: Ultrafire WF-502B with XP-G R5 drop-in
37 posts / 0 new
brted
brted's picture
Last seen: 3 weeks 1 day ago
UltraFire WF-502B with 1-mode XP-G R5 drop-in
Reviewer's Overall Rating:  ★★★★★
Ultrafire WF-502B with 1-mode Cree XP-G R5
Summary:
Battery:  18650/2xCR123A
Switch:  Reverse clicky
Modes:  1
LED Type:  Cree XP-G R5
Lens:  Glass
Tailstands:  No
Price Payed:  $17.24
Pros:
  • Bright
  • Cheap
  • Good battery life
  • Looks good
Cons:
  • Rough threads
  • Not much heatsinking
Features / Value:  ★★★★★
I have been looking for a light using a Cree XP-G for a while. I was able to resist the first round of XP-G lights from KaiDomain which turned out to have some problems with the LED set too far below the reflector. And I was able to resist the first round of DealExtreme lights including the Skyray and Uniquefire L2's (the L2 looks just like my Ultrafire WF-504B). But then DealExtreme introduced some older P60 hosts with XP-G drop-ins, including this 502B for only $17.24 which was less than $4 more than the drop-in by itself at $13.59. The drop-in was available in a 5-mode (with strobe and SOS and usually memory) as well as a 1-mode. The 502B with the 5-mode drop-in is $18.93, so I decided it would be a better value to get the 1-mode and order a 3-mode driver separately. From reviews posted so far the 5-mode driver has some problems.
Ultrafire WF-502B tail and clip
I like that it comes with a clip instead of a lanyard. I don't know that the clip is that useful to me, but otherwise there is nothing to keep this light from rolling. Plus it looks good. However if you want a lanyard, there are no holes in the tail so it would probably have to be attached to the clip. The clip is mounted to the tube with screws so if you remove the clip the light won't be watertight.
502B head, reflector, and LED
The light does not tail stand, but it is nice that it doesn't have any sharp edges at the back either. The crenelated head works out fine. Not too aggressive to tear pockets, but it allows light to escape if it is head down.
Build Quality: ★☆☆
The 502B is only my second P60 host. My 504B is silver and I was very impressed with it. I ordered the 502B in black (partly because I don't like the glossy black that the 504B is offered in). It was smaller than I thought it would be, but it looks quite nice. The anodizing doesn't seem to have any flaws. The clip on the side is very sturdy, being held in place with two phillips head screws. I'm not sure if tapping those screws makes the light less water resistant or not, but they do go all the way through, including the top screw whose hole goes into the threads (but not the screw itself).
The reverse clicky switch is firm but the rubber boot itself is smooth instead of textured. It feels like it has been worn down. I like the textured one of the 504B better.
Ultrafire WF-502B parts
The body comes in 4 main pieces: the tail, body tube, throat, and head. There are o-rings in each location. The threads and o-rings came lubed, but they are rough. As I was cleaning off the lube and rubbing a rag along the threads with my thumbnail, the rag would tear. After working the threads taking the light apart over and over again, the threads were okay, but this was disappointing especially compared to the 504B which had very good threads right out of the bubblewrap. The o-rings themselves aren't all that tight against whatever screws in over them, but I don't doubt the light is watertight.
The lens seems well secured by an internal bezel (the 504B's is external) with an o-ring in front of the lens. The lens itself had a little dirt on it which was easy enough to remove once I unscrewed the internal bezel.
One of the biggest problems with this design is the throat is quite a bit larger than the P60 drop-in itself. The drop-in is about 22mm and the internal diameter of the throat is about 24mm, so there is a 1mm gap all around and the only way to transfer heat is where the reflector bears on the top of the throat. With the 504B the throat is only 22.5mm and I was able to cut out some strips from a soda can and get a snug fit. I wound up using 4 layers of strips in the 504B. But in this one, I needed more like 8 (I doubt the heat transfers as well with so many layers but I scrubbed most of the paint off the aluminum to help, and the light did get warm during the runtime test). Another possible solution would be to get some 1mm wire and wrap it around the drop-in, but I don't have any wire the right size (it would need to be 19 gauge wire which isn't a common size; on a trip to Home Depot I couldn't even find any 20 gauge wire that was solid copper). With the 8 strips, the fit was tight enough that I had to remove the Super Bright R5 label from the drop-in to slide it in place.
Heatsinking aluminum strips
The drop-in itself seems pretty reasonable. There is a textured OP reflector and the opening in the reflector seems to be correctly sized for the XP-G LED instead of an XR-E which would have a bigger hole. A piece of thick paper is stuck over the emitter mounting board with a square hole for the XP-G shape. This is good as it allows the LED to get up into the reflector as far as possible. I didn't notice a speck of dirt on the dome until I was taking pictures and it brushed off no problem. Taking off the paper shield, the LED seems securely mounted to the pill, though you should be careful if you try this because the paper is very sticky and it seems to have been applied before the adhesive around the LED could set up.
Bottom of XP-G drop-in
The driver seems pretty decent as far as I can tell. It is on a red circuit board with a red ring on the bottom, which some people say indicates a better design than one that had a lot of failures. After writing the review, I replaced the board with a 3-mode, so here is a picture of the driver:
Ultrafire WF-502B 1-mode XP-G R5 driver
There were a few thin shards of metal in the head of the light, probably from the threads, that I removed. They were tiny, but they shouldn't have been there at all.
Overall, I can't complain too much about the quality of a $4 host.
Battery Life:  ★★★★★
For the amount of light, the battery life is impressive. Maybe this is as it should be since the XR-E R2 has an efficacy of 104 lumens per watt while the XP-G R5 is 132 lumens per watt (based on Cree literature). So even though you are getting a lot more light, the LED is more efficient. The 1-mode driver is drawing more current, but it doesn't shorten life by that much, giving 90 minutes instead of the 105 minutes I got with the 5-mode R2 using the same battery. Based on the declining current draw, the light doesn't seem well-regulated and is probably direct driven (to some extent, because the light can take 2xCR123A, there must be some way of bucking the voltage).
Here's a group shot of the Fenix L1D, AKOray K-106, Ultrafire WF-504B, Ultrafire WF-502B, and Brinkmann 2xAA Minimag:
Fenix L1D, AKOray K-106, 504B, 502B, minimag
Time Volts Current (mA)
0:00 4.21 1480
0:15 4.00 1250
0:30 3.88 1150
0:45 3.81 1030
1:00 3.74 950
1:15 3.66 870
1:30 3.60 810
With the aluminum strips in the head, the light gets warm, but definitely not hot at all. After 20 minutes it is less warm. It should probably be getting hotter.
After writing this I did a more elaborate test of driver effficiency. I ran batteries down to 4 different voltages and then took a voltage and current measurement at the battery and then at the LED. Multiplying voltage and current gives power which I then used to calculate efficiency with some impressive results. It almost makes me think the light is in direct drive (there is a LOT of solder on the positive and negative pads and it looks like it spills to some other pads, which may not have been intentional; you can see this on the right edge of the driver in the picture above) except that I accidentally put the reflector in the light without an isolator disk over the LED and the light was in direct drive, drawing over 2 amps and only one mode. So if it were direct drive, the draw would be much higher.
At rest battery voltage 3.56 3.81 4.04 4.12
Battery voltage with load 3.46 3.72 3.89 3.97
Current draw at battery (mA) 610 840 1080 1100
Power in (watts) 2.11 3.12 4.20 4.37
Voltage drop across LED 3.04 3.09 3.11 3.11
Current drawn by LED (mA)
600 870 1110 1130
Power at LED (watts) 1.82 2.69 3.45 3.51
Efficiency Pout/Pin 86% 86% 82% 80%
The efficiency is very high. Another multi-mode driver I tested at the same time with this LED was in the 60's. The current to the LED is actually higher going in to the LED than what is drawn at the battery. But look how the power at the LED drops off sharply between 3.81 and 4.04 volts.
Light Output:  ★★★★★
Finally! This light is quite bright, significantly brighter than the XR-E R2 drop-in I have. The R5 should give off about 22% more light than a R2, but the driver seems to be driving the LED pretty hard as well with the draw of 1.4A to start with (the R2 driver draws 1.2A). Some of the measurements on CPF indicate 300 lumens for the first few seconds before dropping off to around 270 lumens. That seems about right.
The tint is quite nice. The hot spot is very white, but the spill is a little bluish. The R2 has more of a violet or gray looking tint whereas this is just bright white.
After about 50 minutes it is less bright, but still brighter than my R2. Even at the end, with the battery at 3.6 volts and drawing 0.8A, the light is as bright as the R2 on a fresh battery. That's impressive.
The beam quality itself seems very good with a tight hotspot and a decent amount of spill. I was expecting the hotspot to be bigger and more washed out than the R2, but actually the intensity is quite good. Given the lack of rings, I wonder if a smooth reflector wouldn't do this LED more justice.
XP-G on the left, XR-E on the right at 1/25th second:
502B vs 504B 1/25 sec
at 1/200th second
502B vs 504B 1/200 sec
at 1/1600th second. The P60 reflector does a nice job of focusing the hotspot, but you can see it is still bigger and it also seems more intense.
502B vs 504B 1/1600 sec
The last picture is at 1/200th second with the 502B on a low battery (3.63V) and the 504B on a fresh battery (4.20V). They light is about the same, but the 502B might have the edge since it has a bigger hotspot.
502B low batt vs. 504B high batt 1/200th second
Out on the backyard range, the 502B outperforms again. For comparison, here is the 504B with the XR-E R2. This light throws its little hotspot pretty far, so notice how the fence posts are illuminated. They are about 120' away. The stick in the ground is 25' away. This is a 4 second exposure:
Ultrafire WF-504B R2 outdoors
Now here is the 502B. You can see there is more flood, but the throw is also better. There's just a lot more light:
Ultrafire WF-502B XP-G R5 outdoors
Now for one more comparison, here is my Ultrafire MCU WF-1200L with P7 emitter, running off of 2x18650 batteries. This light has a big reflector for better throw and puts out at least 400 lumens:
Ultrafire MCU WF-1200L P7 outdoors
To compare the throw, here is a zoom-in of the fence posts for all three (504B R2, 502B R5, and 1200L P7):
Fence 504B R2 Fence 502B XP-G R5 Fence WF-1200L P7 LED
Summary:  ★★★★★
This is a pretty solid light and a very good value. If you want a 1-mode light, this one is great (though the Seraph clones or Uniquefire L2 hosts are better quality for only a few dollars more). But because the light is so bright, I do think lower modes are needed. Then the problem is finding a good driver for it. I will try the NANJG AK47 driver and see how that goes. I may also try to measure the current to the LED at some point.
 502B in hand
Edited by: sb56637 on 08/26/2014 - 17:22 Reason: sb56637 replaced budgetlightforum.cz.cc with budgetlightforum.com via Scanner Search and Replace module.
Don
Don's picture
Last seen: 3 years 2 months ago
I didn't realise the XP-Gs were that efficient though I'd guess that was at a much lower drive current than 1.4A - they usually seem to measure the efficiency at 350mA or less. Not that I'll ever know as you'd need to spend tens of thousands on lab gear to test this properly. I seem to remember around 80-90 lumens/watt when hard driven but my memory may well be at fault like when trying to remember which Cree LEDs have the ring.:) Smile :smile:" class="smiley-class smileysProcessed">
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
brted
brted's picture
Those efficacies are at 350mA (only 139 lumens at the emitter for the R5) so they would be less at anything useful like 1000mA. The new XM series is supposed to be 160 lumens per watt and Cree has a press release saying they have attained 200 lumens/watt in their lab with non-production LED's.
Don
Don's picture
Especially as the XMs can be driven at 2A for silly lumens. Just happily awaiting my 23 minute runtime (With 5000mAh cells) SST-90 light now estimated as up to 3K lumens. Efficient no, bright definitely. At the theoretical maximum this would be a 12,000 lumen light!
The theoretical limit is about 400 lumens/watt so hopefully we'll be seeing a lot more light for the same current for some years yet. I believe Nichia has some 5mm LEDs that can do over 200 lumens/watt but then they only use fractions of a watt at best so aren't the sort of things I'm looking for - they aren't about to give me the sun in my hands.
alfreddajero
alfreddajero's picture
Last seen: 2 years 6 months ago
Awesome review, that sucker is bright.  As for the tailcap is it the standard size like all the other lights we have.....if you need some i can send you a couple of black and orange textured ones.
With Darkness, there will always be Light.
Nil Einne
Last seen: 10 months 2 weeks ago
If you're interested in light output at high currents, you can calculate the theoretical lumen output at various currents for most of the LEDs from the spec sheets. Someone at DX did it http://www.dealextreme.com/forums/Forums.dx/Forum.-209~threadid.530221
I tried a few myself and results seem the same.
BTW the XM-L is is supposed to put out 750 lumens at 2A! (Yes this isn't that far from the highest binned MC-E or P7 at the max spec 2.8A.) Although I would take a guess this is the top bound of the highest bin at release, i.e. the actual bin will be something like 680-750 lumens at 2A (still 2A for 680-750 lumens vs 2.8A for 800-900/753-858 lumens). If you haven't seen it there's now also a slide from Cree's presentation at Light Fair on the XM-L that may be of interest http://ledinside.com/News_cree_LED_20100513
alfreddajero
Thanks for posting that, made a good read def.Cool
Don
Don's picture
It sounds like the XM LEDs won't really be suitable for flashlight use. Pity...
sb56637
sb56637's picture
Last seen: 9 hours 58 min ago
Oooops, this review escaped me until now.  Sorry about that brted!  Wonderful high-quality review as usual.  Now frontpage'd and sticky'd.  I also played with physics and changed the date you published the review so that it goes to the top of the frontpage.  Wink
brted
brted's picture
Thanks for making it a sticky!
As a follow-up, I did replace the driver with the NANJG AK47, which I reviewed here:
http://budgetlightforum.cz.cc/node/310
The bottom line is that the new driver doesn't ever draw 1.4A like the original did (sometimes), but it is much better regulated and maintains that 1.05A draw down to about 3.8V. Also I like the 3 modes. I also replaced the smooth black tailcap with an orange one with some texture. So it was pretty easy and cheap to get rid of a few of the cons about this light and it is still very bright.
agenthex
agenthex's picture
Last seen: 6 years 8 months ago
I got the 5 mode version of this from KD. There's only 1 board inside with what looks to be 1 mcu chip, and the current draw (>2a at start) implies it's just direct drive with a mode circuit. The soldering is also pretty crap (driver fell out), and the thermal compound never vulcanized properly or something so the emitter pcb falls out too if you take the reflector off. The 502b is pretty nice, though.
So.... get the 1 mode from dx and avoid the 5 mode KD if you really want to take the chance.
Reading this makes you smarter: http://lesswrong.com/
brted
brted's picture
Sorry to hear about yours. I hope you were able to get your fixed up (or return it). After KD's early R5 drop-ins seemed to have the LED well behind the bottom of the reflector, I was afraid to get one from them. Is/was your LED partially blocked by the reflector?
I still really like my 502B with the 3-mode NANJG AK-47 driver in it. I also replaced the smooth black switch cover with a textured orange one and I think it looks great.
agenthex
agenthex's picture
It kind of looks like it, but not really. It's a proper xp-* reflector. The spot is well formed so that's hardly the problem with it....
I do quite like the 502. Kind of has that industrial feel of socialism to it Smile
kabicy
Last seen: 7 years 11 months ago
Great deal for ultrafire WF-502B
http://budgetlightforum.cz.cc/node/1228
Cool
lcbgdboy
Last seen: 8 years 9 months ago
Ultrafire WF-502B Cree XM-L U2 And UltraFire WF-502B Cree XM-L T6 ,
so than Cree XP-G R5. what better.
jaxon
jaxon's picture
Last seen: 7 years 9 months ago
I imagine the 5 mode drill is same as my WF501s. Don’t have my 502 yet, but I don’t think I like clips. Maybe just remove it and replace the screws with a little CA to seal. Shorten the screws? Otherwise the light looks good for 11 bucks with a long delivery wait.
Jaxon
Jaxon
robbynaish
Last seen: 5 years 6 months ago
Hi Guys,
do u know if this Light is original or no? The price is good
http://www.banggood.com/Wholesale-Ultrafire-Cree-Xm-l-Xml-T6-Led-502-502...
Many thanks
Ale
raccoon city
raccoon city's picture
Last seen: 8 min 48 sec ago
Have a pleasant time here at this friendly forum, robbynaish!
Best0270
robbynaish1robbynaish2
JaffoAZ
Last seen: 4 years 4 months ago
robbynaish wrote:
Hi Guys,
Many thanks
Ale
Looks just like mine. Also looks like a good deal!
JAFFO
robbynaish
@raccoon city
Thans for your welcome message
@JaffoAZ
Thanks, i will buy in that shop.. hoping yr comparison is right Smile
Alex
Boaz
Boaz's picture
Last seen: 1 day 21 hours ago
My opinion of banggood is it's a spammish POS foul looking ebay type trash site . Everything they sell is same old same old ebay trash ..If you want to know what are the worst lights ever made they are showcased Right here on Banggoods 4  flashlight pages .Every single one of them should be avoided and would probably yeild a nice purplish bad binned emitter,bad heatsinks ,nasty PWM,cheap andozationetc....  it's obvious that they are just scraping the bottom of the barrel ..A shop purely price driven .I see nothing they sell as redeeming in any way .I'd avoid them at all costs and assume everything they sell is a fake / a second  or something being dumped .
Spam site
robbynaish
Hi Poaz,
im sad read so…. at least in hobby models thing their products are very good, and even if something is failed, they change without they ask u send it back (t happened to me), i had to send them a small video showing smt was no ok.
On NG http://www.rcgroups.com many users bought from banggood many different models and are originals.
So u suggest to buy from manafont?
Many thanks
Ale
scaru
scaru's picture
Last seen: 3 years 6 months ago
Yep, manafont is reputable.
Boaz
Boaz's picture
I'm personally not much of a manafont believer either but they actually sell  much better  lights .. the selection from banggood is like I said a bad smattering of what ebay sellers who don't know and don't care puke out ..They do it only for one reason ....price ..good or bad they don't know or care . It would be presumptous  of me to say it's all pure garbage because lots of these lights obviously sell pretty well..But look at the batteries and chargers they last as well ..Fake ultrafire reds and junk chargers are the spotlighted /featured add -on
If this isn't spam ... it ought to be
Manafont /DX /Dino/KD/Focal  etc... Any or all would be preferable to what I'm seeing from the banger
Having said that ..I'm assuming that buying a 502B xml from banggood is about the same as buying one from almost anyone else ..i'm not sure there are any real ones . the trustfires501/502/504 etc...are pretty much what they are ...they are what they are ... Manafont sells fake 501's too  And so does dino ..Until I bought a really old 501b from dino really cheaply did i ever see a real trustfire light  in  the 501/502/504 series lights .. I think they are just so copied again and again ..99% of the people out there will never see a real one ////That said it still isn't that much better ..It simply had a better anodize,a better thread and metal... You could postulate that someone made a mistake and just made a copy too good .:P
 I don't think anyone needs to be scaring you away from a 502Bxml for 12$ . I assume bangood will deliver for you ..
I just overall question their entire choice of flashlights and their business model ...like I said it would be like randomly buying from a Chinese  ebayer .. not worth freaking out about
jaxon
jaxon's picture
Glad this thread is alive again.
Seems my 502s mode memory is not the same as my 501s. It does not remember the last on press but thinks there is a half press and goes to the next mode. Just me or is it defective? I’ve got another coming from a good deal to see if it’s better.
Any thoughts?
Jaxon
Jaxon
Boaz
Boaz's picture
 Since it's just  a drop in  from such a vast myrid of makers, it would be surprising if they ever acted the same as another . My assumption is all of these parts are from multiple sources .heads tails ,tubes,reflectors ,driver-pill-emitter. So the fact they don't have the same driver isn't surprising
ChiggerPepi
ChiggerPepi's picture
Last seen: 4 days 7 hours ago
I have very quickly decided that if I want a light to have a driver with modes I know I like, I’ll put my own driver in it. Nanjg 105c
Or buy a light that you know has one in it: XinTD
E1320
E1320's picture
Last seen: 2 years 10 months ago
KD has the 502B with the new U2 XML 5 mode for $13.50 and they are very reputable and banggood sounds like a girl I used to date.
http://kaidomain.com/product/details.S009983
I am already visualizing the duct tape over your mouth.
robbynaish
Thanks… this site look like banggood Smile When i opened i thought i was in banggood Smile
What is better in this new 502b?
Thnks
Ale
robbynaish
Here too i find a good offer, SS is abt 3 usd
http://www.lightmalls.com/ultrafire-502b-cree-xml-u2-1300-lumen-5-mode-l...
Here ask wich reflector choose :quest:
thnks
Ale
jaxon
jaxon's picture
Second one from ‘linkoutdoor’ works perfectly, and even has a serrated button. And the Logo is not backa$$wards.
Jaxon
Jaxon
