New Osram Oslon Square, testing a 4000K 92CRI typ. emitter
I just want to put one or two (or three) in AAA lights for fun and upgrade my 2 Watt goose neck lights at home with high CRI.
So they’ll find a job. :slight_smile:
For 4000K i have a bunch of 219C.
I also got a 4000K 95CRI 30Watt COB from them, plus 100 pieces of 0.5 Watt 5630 4000K 95CRI for a head lamp idea (not all 100 of them obviously…)
I just put some more 219C’s in the mail for you.
:+1: :+1: :+1:
Awesome!
The Osram Square Gen2 with 95CRI is now available in smaller quantities in some places. I just got some today. I can’t say much more than that right now.
Thanks for the heads up. I bought a few 4000K ones at led1.de. They have placeholders for 90CRI 3rd gen. Squares too, but nothing in stock, like the rest.
FWIW, those Oslon Square gen.1 2700K i bought from ebay are probably ‘9080’ as they call it, lots of red, more than 219C 3000K.
Looks really ‘incan’ :slight_smile:
Chouster sent me a high CRI Oslon (GW CSSRM1.BM-MPMR-XX55-1) for testing since he doubted it was the real deal with all the green. Yes, it’s horrible in tint, one of the worst (tint dev. almost 0.01) but does exceed CRI 90.
Here it is stuffed into a Thrunite TC12 V2 on max mode.
Maukka, thanks for the detailed test. Could you also post the test done with the light in low or mid mode? The R9 ist noticeably higher at lower currents.
Yep, here’s mid. And you’re right, the CRI (R9) gets higher with lower currents. I got 90 on moon.
Thanks maukka, you answered a question that I had for a while.
So why does Osram make these tints and Nichia the other tints? Some thoughts.
  1. a matter of preference, there is a market for the ‘Osram Green’ :wink: , as there is one for the ‘Nichia Rose’.
  2. it is the most energy efficient way to obtain 90 CRI (?) , and customers just go for the claim, not for the actual tint.
  3. with the set of phosfors that Osram is using (they develop their own phosfors, right?) this is what you get.
I think 3) is not true, I have a few flashlights with old gen. SSL80 4000K 96CRI leds that have the most wonderful tint, slightly rosy with no green.
@Chouster: Hahahaha finally you sent the little hulk to Maukka. I remember you said how green this Oslon is. :smiley:
Now I really doubts any claims about ultra High 90+ CRI until I see it myself or spectra tested. :expressionless: . Seems they can play with the numbers to get high CRI on paper. Digital camera and monitor aren’t trusty either for sharing….only film camera available at the moment.
I almost buy the CRI95/R9:90 Oslon earlier, this test has saved my wallet. I must test all of my Nichias right away :frowning: (worry mode: on).
@maukka, again, thank you very much for testing.
@clemence, yes, I was very curious about the results…
@all
The first emitter I had installed in a P60 drop-in was hooked up to a dual channel driver, so that the low modes are pulsed at 350mA, that’s were the tint is the worst to my eyes. It does get better moving to PWM @ 1400mA, but I clearly prefer the 219C R9050 sm403 from clemence at any current.
I really hate the fact that this Oslon only comes up to its CRI specs (R9 especially) at very low currents. In fact, according to the datasheet you shouldn’t even drive them at that low currents (not below 200mA). Their specs are typical R9 value of 90 at 700mA, and that basically means nothing as we see here. It’s so far off from 90, that got me thinking I’ll give a $#@§ about typical values from now on.
I’d love to speak to someone from Osram about this. The LEDs have a little code on them so they could give some more information or confirm if these are really “GW CSSRM1.BM”, if they wanted.
Try 50X loupe, just in case there’s a barcode or something near the lens. I can see some tiny numbers in Nichias
Edit: I see that you already saw the code.
I ordered and received some of the 2nd gen. Oslon Square leds that maukka tested above (96CRI typ. R9:90), and put one in a small EDC.
I can confirm that the colour reproduction is really good with great reds, and I can also confirm that the tint is amazingly unattractive.
Btw, I compared the beam next to the beam of a flashlight with the Square led of the OP (which is ‘just’ 92CRI typ.), and next to that one, the tint looks way better, less green.
I’m in for some 219b V1 SW453 R9080 leds from clemence’s group buy, that clemence finds too rosy, perhaps a quad with a 2x2 mix of these two leds will just have the ideal tint?
That sounds like a good idea!
just wondering why this LEDs don’t get used much
possible the lack of a proper DTP star
  • that people on BLF tend to like rosy tints, while most (including this one) Osram leds are towards yellow and green.
All newer, neutral-white high-cri Osrams seem to have yellow or green tints.
Spotted these recently, along with many others, from eBay seller jwhpargos. Many warm and high CRI emitters. :THUMBS-UP:
I have a couple of Kaidomain's triple DTP individual boards. The footprint of the central thermal pad could be more width and on center accurate, though anode/cathode pad distance is precise at 2mm. I do wonder how difficult would it be for me to successfully place them over the pads correctly without any sort of bridging.
Cheers ^:)
Originally posted on Sat, 11/18/2017 - 22:12. Edited for a lil correction.
I’ve reflowed one on a single XP copper board, it’s a bit tricky but definitely doable with some tweezers and patience.
It now lives in an S30R javelot and gives some warm light with a bit of throw. Yellowish, comparing to Nichia but still good tint.
I also did a reflow on a triple board from KD but did not use it yet
