I have only lost 1 package from gearbest from quite a lot untracked orders . Shipping without tracking isnât actually slower . Only in Christmas there was a bit of delayâŚ
I can imagine a good number of export house employees delaying or cutting short their Chinese new year celebrations to get product out the door after yesterdayâs speech and their own countryâs warnings to prepare for the worst.
Mine finally arrived yesterday, works but seems to be the same brightness no matter what kind of battery I use. Also the pocket clip kind of sucks. Other than that, nice little light.
Iâve been following your pictures and text and Iâm getting a tad lost. My UT01 has a switch which is also ever so slight off-centre to the right, just like yours. Iâm trying to dismantle it but having very little luck. I cant see to get the driver out, nor from the mcpcb led side. Also, now that Iâve out it back together, I have to leave it screwed on slightly loose or the light wonât work - most odd.
Did you have any more luck getting inside your light?
I donât have the UT01 in hand yet, but from what I have read you are supposed to be able to rotate the switch pad button left or right with tweezers etc. to center it. Then reinstall boot. At least thatâs the way I understand it to be.
Hm, thatâs what I understood but neither the boot (the boot being the silver ring?) or the button on the board are budgingâŚand Iâm not being too gentle either. Iâm probably doing this wrong. Iâll keep on at it.
I had the same problem you mention but in the Klarus Mi7. Lithium batteries were no brighter than NIMH or AA primaries. Turned out to be a defective driver. Klarus USA sent me a replacement headâŚthen there was brightness.
