Review request for HKJ [USB Power Devices]
May I ask how to donate equipment to you? I’d be interested in your opinion of the Belkin F7U005bt04-BLK illustrated here. (Comment split from BlitzWolf BW-C4 thread.)
Or I can ask Jen Warren (Global Director of PR, Belkin) to send you a sample. I presume they have their own warehouses nearby, and would appreciate a counter-point to my initial criticism of this charger when used with the Google Pixel (Sailfish model).
https://plus.google.com/102612254593917101378/posts/dgqeFSM19bd
Please let me know what option is best with you, and I will endeavor to get it to you!
May I ask a review of the Xiaomi Dual USB car charger with Bluetooth? Xiaomi Roidmi 2S http://m.banggood.com/Original-Xiaomi-ROIDMI-2S-Dual-USB-3_8A-Dual-Mode-Bluetooth-4_2-Hands-free-Calls-Car-Charger-p-1042119.html
I wonder if they have correct overload protection.
I will add it to my queue.
Thanks! I have an older version and the Xiaomi car charger seems quite nice. I hope the inside is also good.
Hi, if you could please review this charger:
Xiaomi charger
Hello HKJ,
please consider the TOMO T4. Would be very interesting, since it allows the use of own cells.
http://www.tomopowerbank.com/shop/tomo-t4/
https://www.amazon.com/V8-4-Portable-Display-Battery-Charger/product-reviews/B013G6M4A8/
https://www.amazon.com/Aurabuy-External-Battery-Charger-Display/product-reviews/B00IM3NZ86/
It’s similar to the Soshine E3S.
http://www.gearbest.com/chargers/pp_493560.html
I wouldn't call it similar, i'd call it a clone/oem/made to order model :)
Tmart has it too, under their TLIFE brand. I did a video on one recently.
I have just posted a review of the TMart model: Test/review of TLife Power bank TC-01
Thanks!
I found this USB charger, which is unusual/rare because of the horizontal orientated ports. This makes it useful for USB Voltmeters on each port :slight_smile:
just-mobile.eu/alucharge-eu.html
Link is already adjusted for Denmark :wink:
Well, this Satechi Type-C Power Meter seems to be making the rounds on some of the techsites I read :
But the $30 dollar pricetag seems a little high for a UPM without any form of logging or analysis like the YZXStudio's.
Banggood sells a combination USB-charger with wall outlet. I doubt they are good, but a test would be interesting.
http://m.banggood.com/5V-2A-Dual-USB-Port-Wall-Charger-Adapter-EU-Plug-Socket-Power-Outlet-Panel-p-1107847.html
I would buy a certified socket from a respected retailer in your country so you know it has passed all the safety tests.
I bought 4x UK USB sockets from china, I found that the earth connection did not make contact with the plugs earth pin at all on any of the 4, I contacted the seller and got a full refund and binned the possibly lethal sockets.
Buy quality when you are working with mains ac voltage.
John.
Well for that price you have almost ever issues. I don’t know if a good one exists, the thing from Busch & Jaeger has below 1A and for the price of this http://www.amazon.de/dp/B018KM3QVE
you get two x6 Anker USB charger.
@HKJ
If you consider these, please very thoroughly test
- heat development (especially with one cell discharge)
- unbalanced charge termination and
  • low discharge protection.
My Soshine E5 (aka TOMO V8-3) has serious issues in all these departements.
Gravest one: 2 cells in parallel went down to ~2.15V over night; I then tested with a single cell (just left in the case, nothing attached) and halted the test at 1.86V resting. Pretty scary.
I like the design of that one, but I do not like the price. It is a bit expensive to buy and just open up.
At the current time I cannot test advanced usb-c, i.e. I cannot test this. I might return to it when I have a setup that can handle the testing.
I already have this one in queue.
I will probably also take a look at this one.
I have already published the review of the TLife version, it did not have all these problem.
Registering for the newsletter brings a 15% coupon.
http://www.just-mobile.eu/newsletter-subscribe/
22% off for valentines day with code JM201702 (valid 08.02 - 14.02.).
Also i’d find a sketch of the layout of the JustMobile AluCharge.
The layout may not be safe, but these drawing are usual not very precise (Problem may be spacing between high/low volt at the transistor and rectifier). Some yellow tape will fix this (There will probably also be some around the transformer also).
What they have illustrated is fuse, two (probably) common mode coils, safety capacitor, switcher controller and transistor. The rectifier diode looks a bit strange with too many pins.
Bridge rectifier and opto coupler is probably on the other side.
With the discount it was “only” €56
I’m still not sure what I can buy to “play” with my usb-c devices. Any suggestions?
Seems there are many USB dummy loads and current meters but when you go USB c they get sparse.
fsp-group.com.tw/index.php?do=pressinfo&id=255
newertech.com/products/nupower-usb-c-power-adapter/
trust.com/en/product/21478-moda-universal-60w-usb-c-charger
trust.com/en/21478/leaflet/en-GB
google.com/search?q=8713439214789&tbm=shop
satechi.net/index.php/satechi-type-c-power-meter
