Hi Ban,
Thanks for clarifying :+1:
It is just that I wondered about the specific bin, but Iām interested in buying it whatever bin it is. So if it is ok with you, I choose not to cancel the order
Hi djozz
Yes.
This is a serious problem to KD. But i can sure that this is 100% genuine CREE LED.
I want to make sure we get the right bin , tint from our distributor.
Thanks for your understanding.
Ban
ā¦PROBLEMā¦
I just ordered and payed for an XHP50.2 5A tint, thinking it is high CRI like the description says.
But it is coded āBā which means 70+ CRI.
Now i want to cancel my order.
Sorryā¦
ā¦SOLVED (i think).
cancelled via email.
I finally order it, pay, and now waiting two days with no answer, so Ban, why your website is not working as it should, Iād like to order try web interface like on all other sites, it is just easier instead I chase your support for orders and packingā¦
I will PM you about this order, and I like if you can to fix that bugs in website.
Any chance of getting some 80+ or better yet 90+ CRI xhp50.2?
I think I am going to get one of the 4000k versions but would love a high CRI option for next time.
I hope this is an okay place to post this
Does anyone know if the carlco 3 up optic can be used with a KD triple board? I inadvertantly destroyed the optic & emitters on the KD Nichia 219c x3 board :person_facepalming: on one of my builds.
Iām hoping to be able to reuse the salvaged board on another project. I happen to be ordering from a US vendor & can use the quick shipping to finish my project sooner(& hence only those carlco optic are available otherwise Iād definitely just buy a replacement optic from KD.) Thanks!
check post #406
Honestly get the Noctigon 3XP regardless, even if it did fit.
thx, I knew I saw that post somewhere.
& point taken on the Noctigonā¦
And if you are ordering from MtnE he will reflow any in stock emitters for free, bare or on another board. He does excellent work. I have tried and it gets frustrating to get the 3 emitters and jumpers done and done right. I will never do a Tpad quad again. 3XP are easier but stillā¦ it will be done right from Richard.
Maybe KD is interested in producing 20mm quad dtp boards? Tpad are :confounded:
Interested too , in more than 5 pieces . 20mm , quad , for Carclo 10621 / 10622 optics etc , 1.6-2mm board thickness , dtp , copper .
No etc.
Carclo compatible only.
Round milled board with 5 drilled holes.
I can help with design to avoid usual problems.
Will take 50-100pcs from first batch and more in future.
Production methods and self-cost is same too other noctigon-style KD boards, so target price is $3.5 per 2pcs.
With āetcā i meant frosted version of 10621 / 10622 like 10623 , 10624 .
Yep I agree T-Pads :confounded: ! Make a 32mm triple board in the KD Black! I would really like it if they made both, dedicated parallel boards also, dislike using jumpers! :+1:
Finnaly I can log in into my KD account on their site.
Same error like first time, add to cart, click checkhout with PP, go to PP, pay then automatic get back to their site with this error :
Any other of you have this problem ?
A simple Parallel design similar to Manker, Mateminco, or who ever it actually is. But Must fit Carclo and have the Negative on the outer edge. Yes, with some Meat on the board, Not thin. Pleaseā¦ :money_mouth_face:
iāll be interested in quad pad / Tpad 20mm diameter that fit Carlo optic too.
i will get 10- 20 depending on price
no no no
I will help with the design.
Problems with traces short-cutting to the body can be simly fixed other way.
I want to mod my S2+ with a 219c triple.
I bought the LEDĀ“s from Clemence. Now i need the other Parts.
Will this fit? Driver is a MTN FET + 7135 Driver
- http://www.kaidomain.com/p/S023167.3-in-1-20mm-Optical-Lens
- http://www.kaidomain.com/p/S024023.DIY-22mm-x-8_5mm-Brass-Driver-Pillar-Set-for-18650-Flashlights (will this pill fit if i add copper spacers?)
And i want to upgrade my UF-1504 with a new XP-L2 LED.
Which LED should i take for max output? Driver is a MTN FET + 7135 or a LD-2 with a 100K current resistor (= max 9A)
1: http://www.kaidomain.com/p/S026205.Cree-XP-L2-HD-White-6500K-LED-Emitter-with-KDLIGHT-3535-16-16mm-x-1_5mm-DTP-Copper-MCPCB
2: http://www.kaidomain.com/p/S026461.Cree-XP-L2-HD-Neutral-White-5000K-LED-Emitter-with-KDLIGHT-3535-16-16mm-x-1_5mm-DTP-Copper-MCPCB
I will use US18650VTC6 as powersource.
I just got in an assortment of the KD DTP copper stars a week agoā¦ I have to say, they are really nice. They are flat, black and dimensions are good. I will use more of these.
Thanks KD, now I will have to order more ledās.
Matt
