Jetbeam JET-UV T excited for the little baby.
in the mail right now !
Olight sr mini 2 intimidator full kit
mecarmy pt16
mecarmy illuminex 2 alluminium finish to put on my key chain
astrolux s1 blue short version tint 3D+black extension tube
a cheap china stuff flashlight ‘’as seen on tv’’ 2000lumens HAHA to compare with my 3 others =) and probably great to afraid rubbers :person_facepalming:
one samsung 30q 18650 and other cells for my mecarmy
Can’t wait to receive !, I was really used to cheap stuff from the local market soI can’t wait to see the difference with good quality lights =)
if you have idea for a good flashlight small sized Im a newbie to this word and I think its different and cool =)
Math, there are so many! The best thing to do is to just read the various sections of the forum. After finding a light you’re interested in Google is your friend. Most manufacturers give dimensions. It’s more difficult to figure out how bright a light is, and not all beam shots show what the beam is like as seen by the eye.
OK, you want a suggestion for a good and small light. What is small and what do you want it to do? I think a small light would be the Manker E11 or the GranVela K18, but small could also mean a C8. Many folks would consider the small lights I mentioned as being tiny. All of those lights I mentioned are good, but there are others as well. Since the word small is relative even a L6 could be seen as small as compared to other lights and personal experience.
A friend recently asked me to suggest a general purpose light that with cells and charger that would come in at around $30. We went over by a little, but I suggested good cells and a C8. The C8 is a classic light and a decent entry level light with good performance. In size it would be something like a 2 C cell light.
I really like the tube shape that fit in the hand, Im curious to compare the astrolux s1(blf a6) to the astrolux s41 there are about the same lumens and size but one have 4 led and the other have only one, I wanted the mecarmy because I like a good flood lightning and bought the astrolux s1 to have a more strait light of course no usb charging but still powerful enough
Id like to have a light that fit a 18650 or smaller battery with 1000-3000 lumens hehe
Iv seen good reviews on the convoy s2+ also
Astrolux s2 finally gave in for under 22 bucks shipped… :person_facepalming: Hey it’s not my fault nobody asked me what I wanted for Christmas! Got a Lg MJ1 that didn’t have a home.
- Astrolux A01 Nichia 219B *3pcs
- Convoy S2+ (grey)
- Zanflare F1
- Nitecore Tube (black)
- ThorFire TG06
- Lumintop Tool AAA *2pcs (2 tails each, clicky + magnet)
- Warsun Penlight (Zoom-8) *6pcs (2*3 colors, bought only $1.84/pc @11/11)
- The reds were crap (max 10 Lm output - refunded immediately by AE), greys and blacks acceptable (partial refund by AE).
- Warsun T6 3 Modes (C8)
- Warsun Anti-wolf Charging (CT9T) *2pcs
- Warsun T6 Zoomable (X50) *2pcs
- Olight S1 BATON
- Utorch UT01 (CW)
- SingFire SF348
- Nitecore TIP Winter *2pcs
- KLARUS Mi7 *4pcs
- CRX-1000p (arrived, but I won't delete it )
- Astrolux S3
- Nitecore Tube *6pcs (2*3 colors, ~$3/pc @yoshop w/code: 143GHIN1 blue - 143GHIN2 transparent - 143GHIN3 black)
Tool AAA Copper, had to order another after I inadvertently gave away my first one :person_facepalming:
Utorch UT01, figured I didn’t have enough AA lights…
There are NO more lights in the mail anymore.
But in the past 2 weeks I received:
Lumintop Tool XP-G2 alu
Fenix CL05 Liplight blue
Thorfire VG10
Convoy C8 grey
Thorfire PF01S (for review)
Crelant E3 pink
Obvious most lights are AAA.
All in all it did cost me less than $40.
The Convoy C8 was on sale at Dankung Outdoors.
The grey is so light colored that if you would call it a clear coat, I also would believe it.
I just got the Blf a6 non-ano version. A shitton of a light for less than $20.
In the mail is a clear convoy L6, 2 Keeppower 26650s, the Imalent DN70, and last but not least is the mean green Ultratac K18!
Only one right now!
- Ultratac K18 black (AAA/10440)
Have someone on here build you a x6 triple. One 18650 cell 3500ish lumens usually varies with LEDs chosen. Probably have about 5 mins before it gets really hot. You can build a s2+ triple same lumens but you have about a minute before it gets really hot. X6 has a good bit more mass. And if I use my x6 when its 30-40 degrees outside doesn’t get to hot
Back to the thread I have a vg10 on the way. It will get a xpl2 or a nichia 219c 5000k The past week 3 lights came back in from being modded up. X6 dedomed xml2 u4 1c 1450 lumens on turbo a6 driver no turbo timer
Sk98 a6 driver xml2 u4 1c dome on. Beryllium copper driver spring. Mini omten switch in tail. Hunk of copper to fill space. DD lumens unknown.
Astrolux s2 spring bypasses, original manker mcpcb and driver reused xpl2 w2 2b I believe 1850 lumens at 6 amps no turbo timer
Crelant V4A
2 1/2 months in the mail so far :rage:
Another 2-3 weeks expected, customs delay of over 1 month thanks to Canada Post :person_facepalming:
Sold Olight SR Mini Intimidator II but still have 4 18650 and no lights that use them.
Convoy c8 in the mail….and if I keep being bored maybe a Klarus rs30 or Rofis tr20
I just recently discovered this forum and realised that I have to improve my flashlight collection.
Lumintop Tool
Convoy C8 silver
Utorch UT01 ×2
Cheap USB rechargeable keychain for 0.99$ x2
Sipik sk68 clone
Imalent hr20
Cheap headlamp from ebay
Nitecore tube
Convoy L6 (NS-3A)
Convoy X3 (T4-7A)
Convoy C8 (U4-7A)
Convoy S2+ (T4-7A)
Utorch UT02 (3D)
several Orbtronic batteries
silicone grease
I was just in the mood, I suppose :person_facepalming:
Imalent DN70
Imalent DN35
4 Soshine 5500mah batteries
BLF 7/4 driver
Convoy C8 AR coated lens
2 PANASONIC NCR18650B 3400mAh
https://world.tmall.com/item/541946980862.htm?spm=a312a.7700714.0.0.hygDOP
this light, chose it because of micro usb charging at the theard lock( better water proof)
Imalent DN70
Convoy mini(2)
10440(4)
Lumintop SD4A(DOA)
Utorch UT01
Red Convoy S2+ host
XP16 and 3XP Noctigons, in preparation for the high CRI 219Cs.
Sh!t man
you’re an addict and i think you need help.
to cure this problem you need to send those lights to me
