Is the charging port micro-usb waterproof as in photo`s i have seen it does not have a cover and is covered in water spray in some photo`s
John.
John.
it might be ok in a bit of very light rain as long as it never went into the charging port but if I’m honest I agree with you on that, cant see how they can claim this
that light has very obvious PWM, imo the TIP or LAD are possibly better options (they do not have obvious PWM)
I have a Manker LAD with Nichia 219c. I like it and would buy it again. Im testing before giving to a college student that is not into flashlights or battery managemet. The LAD is IMPOSSIBLE to activate by accident, no lockout needed. It starts on a useful first mode with a single click.
The red light mode works fine for a trip to the bathroom in the middle of the night. I set red as a mode memory at bedtime.
LAD has strobe modes if you can figure out how to double click fast enough, (I find it almost impossible).
The LAD works great as a simple keychain light, and comes with the charging cord (Tip does not)
here is a video about the LAD (not mine). the link goes to the discussion about accidental activation… something the TIP has a problem with (requiring the use of lockout)
LAD, no Accidental Activation
imo, the TIP 2 button interface is more complex than the 1 button LAD
I chose not to buy the TIP due to the 2 protruding buttons that are notorious for false activation. There are even reports of accidental unlocking. imo the TIP has a lot of nice features, its just not a good match for a pocket full of keys…
The LAD has a charging port cover, it is flimsy and I broke it in the first hour, which left a large hole, in addition to the charging port, that would surely let water in if I was to drop the light in a glass of water. I have no plans to use the lad under water.
The LAD is way more compact, and much less noticeable in the watch pocket of my jeans, than my AAA light
sorry whats PWM??
thanks for the info will check them out
don’t seem to be for sale in the uk?
PWM means the light is turning on and off really quickly. Most people dont notice, some people are sensitive to it (its a kind of strobe).
here is an example in video (the vertical “scan” lines)
https://youtu.be/ffSm8NnOf38
another much more obvious example:
waving the light shows dots on a PWM source
oh right I never knew that cheers
How hard would it be to swap the LAD’s red tophat emitters for a different color?
I’m a big fan of amber/orange, which ought to take the same voltage/current as red emitters.
Anyone got a disassembly discussion for that?
Sorry for digging up an older thread, but am I reading it correctly that this excessive parasitic drain in lock-out mode has been fixed in the current crop of Nitecore Tip lights being sold by GearBest and the like?
The short answer is yes.
I have the Nitecore TIP CRI 2017 edition (Nichia). It doesn’t appear to have a lockout mode.
When I arrived the package a few days ago, it was totally dead, won’t power on. I thought it was a DoA, but then I charged it and it appears to work. I notice that it seems to drain quite fast. So I did a more controlled test.
Yesterday morning, I fully charged it (took about 2 hours to full charge). Tested the battery-check mode, and it has 3 flashes. It can light up in Turbo. Didn’t use it the whole time (except did a few battery checks) About 12 hours later, in the evening, the battery check mode now comes up with 2 flashes. And another few hours later, I notice the TIP CR 2017 was flashing once by itself — doing a battery check mode indicates 1 flash. I left it at that prior to sleeping. On waking up this morning, I checked it and it’s totally dead, won’t turn on at all.
That’s some severe parasitic drain… Not sure how to go about reporting this to Gearbest. (send pictures? videos? how does one send a short meaningful video of a parasitic drain issue?)
At least report the problem ASAP to Gearbest because of DOA warranty period. I would consult with them how to show the problem.
‘oogle “nitecore parasitic drain’ and you’ll find it much discussed, including here at BLF in the past
Interesting: NITECORE TIP Parasitic Drain Thread …
budgetlightforum.com ’ Forums ’ LED Flashlights ’ LED Flashlights – General Info
Sep 17, 2016 - 31 posts - 9 authors
That was the initial batch of TIP lights that had bad parasitic drain. The problem was solved long time ago, and it’s the first time I read about parasitic drain issues with the 2017 TIP (with clip).
Exactly hIKARInoob…… :+1: …. The info posted above is extremely out of date. It has nothing at all to do with the latest model of ‘Clips’.
d_t_a…. I would say yours has some kind of technical problem. I have a couple of the new ones that have been sitting around at least a couple of months and they still blink 3 times when tested.
Basically no parasitic drain…… that would be of any concern whatsoever… to me anyway.
Personally… I never had any issues with the first ones either, well over a year ago.
First they were bad, then they were good, and now … time will tell.
I agree that the first batch of Tips had a battery drain problem, only when on LOCKOUT
then they got a new batch that did not have the parasitic drain on LOCKOUT
so my question is, are the new batch with Parasitic Drain, doing it only while on LOCKOUT?
If I’m not mistaken, there is no lockout on the 2017 TIP (with clip).
this may not be accurate, but, it does say there is lockout
http://flashlight.nitecore.com/ILLUMINATION/T/TIP/
otoh, the above may be for the earlier Tip
you might be right that there is no lockout in the 2017 model, I can’t find it mentioned here
http://flashlight.nitecore.com/ILLUMINATION/T/TIP2017/
they only mention “standby mode”… I don’t know what that is
They never were “”bad”” in the first place. That perception was just created by a few pi$$ed off people posting on the ‘interweb’…… And then others sharing it to spread the mis information.
Time has already told…. they are & have been…… “good”.
Get you some if you don’t have a couple & feel the TIP Clip Luv…….
