DQG Tiny 26650 III Review - 7x XP-G2 2,500lm Pocket rocket!
90 posts / 0 new
will34
will34's picture
Last seen: 5 days 12 hours ago
Review: DQG Tiny 26650 3th 7x XP-G2 CW 2500LM 4modes EDC LED Flashlight
I was contacted by Banggood & Freeme to review a very interesting light: the DQG Tiny 26650 III, the brightest DQG yet and the smallest in 26650 format. DQG is long known for their smallest in class lights, but their performance have never been mind blowing… well, until now Wink
Freeme is currently running a groupbuy on the Tiny III, check it out here: http://budgetlightforum.com/node/51216
Direct link to BG (affiliated by BG not me): https://goo.gl/mYYZkb
Specs and features from DQG:
• Utilizes 7x XP-G2 LED
• Driven by a unprotected 26650 to emit up to 2500 lumens brightness
• Maximum output of 2,500 lumens and runtime up to 200 hours
• Four easily accessible brightness levels and memory function for fast boost
• Toughened ultra-clear mineral glass with anti-reflective coating
• Waterproof in accordance with IPX-8 (two meters submersible)
• Available in two finishes and two tints: CW and NW.
Unboxing:
When I first opened the bag it came in and saw the size of the box, I couldn’t believe there was a 26650 flashlight inside. This is the smallest box containing a flashlight I’ve ever received, its the exact same size as the light. A sticker on the outside shows some quick specs in Chinese and interestingly 4 choices of tint. 90CRI and WW version in a near future maybe?
The contents are as minimalist as possible: the light itself and 2 spare o-rings.
Build quality, fit and finish
My first impressions: Extremely compact, lightweight, with grippy knurling and great build quality. It has a unique look to it, and when you hold it it simply feels special, every element seems to have a purpose: designed to save weight and volume while keeping the highest level of performance possible.
My unit has “grey” finish, but it is not actually grey, but a natural anodizing much like zebralight and surefire. The anodizing was very even and consistent overall and has a semi shiny feel to it. Flat SS bezel on the front.
Lanyard hole
DQG branding and model on the back, completely flat allowing tailstand
The business end, 7x XP-G2 with a 3-legged optic, not sure which exact optic it is but definitely seems well made. The specs says there could be an “ultra clear coated mineral glass” but there was just the optic in my sample.
Multi-emitter lights always looks pretty Smile
But wait until you turn it off! They actually thought of a very clever way to incorporate the GITD material, more on this later.
Close up on the switch, great tactile feedback and short travel. Zero mushy-ness.
Close up on the knurling and you can see tiny machine marks:
Despite the tiny size you can have a good grip on it:
Size comparison with other lights which are also smallest in class, left to right:
Liitokala 26650, Lumzoo GH10, Tiny III, Meteor M43, Sinner custom Cu EDC, and the not tiny Convoy S2+ for comparison.
Both of these lights puts out 2,500 lumens Silly
Some measurements:
Lenght with battery: 92.1mm
Diameter: 38mm
Weight w/o battery: 92.4g
Weight w/ battery: 187.3
The Guts:
The threads are trapezoidal cut, they arrived dry but after adding some lube it was nice and smooth.
This is how much a Liitokala sticks out:
If you ever need to use a 18650 in this light, just get a 26650 adapter and add a magnet on the tail:
A look at the tailcap, it has a raised button that allows contact when the foam insert is compressed. This is DQG’s clever way to allow multiple cell lengths to be used without the need of a spring, but careful to not overtighten it because it would crush the battery or driver. You can lockout this light by unscrewing the tailcap just a bit and it will disconnect the battery.
Same foam ring in the head, some flat tops are compatible but I recommend using only button tops to avoid crushing.
To add a top to your flat 26650s, the easiest and safest way is solder a blob on top:
The brass ring can be easily removed revealing the driver
Integrated e-switch on the driver and decently thick wires going to the MCPCB. Unlike others DQG lights the Tiny III has a solid shelf!
Removing the SS bezel there is the optic and an o-ring surrounding the underside of it. This method is actually more efficient than using two separated o-rings, but doesn’t seal between the optic and glass (if there was one).
The 7x XP non-DTP aluminium MCPCB, which works fine considering the low current going to each emitter. The emitters are all in series and I measured a Vf of 17.5V at the lowest mode.
Now the reason it glows is because of this cleverly placed GITD tape. I have modded dozens of lights with triple and quad optics and never thought of this. Facepalm
UI and performance
UI is very simple and straightforward:
From OFF
-1 click to med
-2 clicks to high
-3 clicks to low
-Hold for turbo
From ON
-1 click to off
-2 click to turbo
-Hold to change modes: low-mid-high
From Turbo
-1 click to OFF if you accessed from OFF, returns to medium if you accessed from ON
-Hold to switch modes
A simple white wall beamshot, more to come later… The beam is the floody type, much like our triples and quads. There are some artifacts in the photo but not really noticeable in person.
Measured throw: 18,100cd, taken at 3 meters
And here comes the sweet part…
Tailcap current draw: my numbers were a bit higher than Tom E readings, using a freshly charged Liitokala 26650. My DMM is not special by any means so the standy current could vary a bit, Tom E measured 12uA or 0.012mA
Measured output: I used 6 ANSI rated lights to calibrate my ceiling bounce tests prior taking any measurements, and my readings came up pretty up on par with Tom E’s. Was surprised to see medium and high modes were under-rated, and high mode is truly impressive putting out 900+ lumens with less than 2A current draw. This is thanks to the amount of emitters running at their optimal efficiency range, much like the meteor on lower modes.
Runtime tests
Medium mode has a pretty much flat output from start to finish, stabilizing at 298 lumens from 2:00 on. Total runtime was 7:56, spot on with the spec’d 8 hours.
Turbo mode starts at 2,457 lumens and steps down to high after 99 seconds then it runs flat until battery depletion at 2:27 also spot on with spec’d 2.5hrs of high. High mode has almost the exact same runtime figures as turbo after step down, with a couple minutes extra.
A closer look at turbo for the first 10 minutes, with manual restart after 1 minute rest: The DQG tiny III has no problems running turbo like this, but make sure to provide proper heat sinking, it will get HOT!
Combined runtimes turbo and medium
Notes:
-No PWM noticed in any mode
-Measured voltage right after LVP shut off was 2.97V
-Turbo/High mode is extremely efficient, providing close to 1,000lm for 2.5 hours on a single 26650 cell. For comparison, the Utorch UT02 does 1,100 lumens for 1.8hours and is already considered excellent. This DQG seriously kicks ass!
-The 7x XP-G2 are in series and Vf was 17.56V in lowe mode. That’s 2.5V per emitter, not sure if that’s too low?
-Modding possibilities: Almost none? First we need to find a compatible MCPCB with 7 emitters in parallel, and then design a driver with a spot for the switch, since there is really no room for driver piggyback. Maybe it can be resistor modded, but boost drivers are not very happy with that. Anyways I don’t see why would someone want to mod it, it is already amazing in stock form. Big Smile
Final words: We have been asking for a compact pocket rocket in 26650 format, and here we have it. The DQG Tiny III fills the gap between FET-level output and superb regulation: 2,500lumens with less than 7A current draw, and then 900 lumens flat for more than 2 hours straight!!
The good:
-Smallest 26650 flashlight
-Great build quality and finish
-Insane output for the size (and price)
-Fully flat regulation on all normal modes
-Impressive boost driver that takes the voltage of a single cell to 17V+
I have really no major complains, just observations about some details, see below. This is now one of the favorite flashlight in my 50+ collection. Thumbs Up
Room for improvement:
-Would like to see more choices of emitter, including 90+ CRI nichia and XP-G3
-There was no glass in my unit and it doesn’t seem to be designed to carry one (the bezel would not fully screw down if there was a glass).
-Some people might like turbo in the mode sequence
-Lanyard hole has sharp edges
Thanks for reading and I hope this review was useful to you! Feel free to ask anything!
Edited by: sb56637 on 09/02/2017 - 11:56
will34
will34's picture
Reserved
djozz
djozz's picture
Last seen: 2 hours 56 min ago
Thanks for the convincing review, it looks really good, now I truly had wished that Bangood had not auto-cancelled my order for it Sad
will34
will34's picture
Thanks! well, you can always order again… BG cancelled my XT12GT order twice and by the third time I ordered they probably realized I was willing to wait for stock. I heard rumors about they are about to fix it, supposedly a system error.
djozz
djozz's picture
You are right, so I just re-ordered it, freeme’s code still worked Smile
giorgoskok
giorgoskok's picture
Last seen: 15 hours 17 min ago
Thanks for the review Will .
Now i can’t wait for mine to arrive . Innocent
I spoke with a banggood rep and he said you need to contact them with e-mail when and if your order get canceled , to re-activate it (that way it won’t get canceled again) .
igeigeige
Thank you for the review!
Gerrit
Last seen: 6 hours 28 min ago
Nice review Will, thanks.
LightRider
LightRider's picture
Last seen: 11 months 6 days ago
Can you measure the driver diameter? Thanks for the review!
DB Custom
DB Custom's picture
Last seen: 10 hours 28 min ago
Nice review and pics Will, appreciate it. I like the natural look, the fine machine marks, looks like it’s freshly made and the machine marks give it an impression of being steel instead of aluminum. I for one really like the look. Big Smile
Mine is lost in space somewhere but will probably show up someday.
I would love to stuff XP-L W2 1D’s in there, on individual 10mm copper SinkPAD’s. Smile We’ll see. If I did that I’d probably piggyback a FET driver with Ramping software and run the W2’s in parallel. Will have to see how it’s all put together and figure it out from there, am surely willing to give it a go for a while as is with all the good reports.
It’s just gotta GET HERE! Smile
rmkline
Thank you for an excellent, detailed review. I had my order from Bang Good cancelled once (or was it twice?), kept re-ordering, got my NW yesterday. It is all Will34 says it is. I have been comparing it to different lights, it’s a little bit deceiving comparing it to other lights (such as the BLF X6) because it is so floody, it doesn’t have ultimate throw, but it really puts out a wall of light. I can’t help but think of it as a miniature Noctigon Meteor – superb floody output with small size, many drivers. Recently got a Meteor with 219C ET, fantastic. I emailed George at DQG and congratulated him on his new light, and asked him to consider a Nichia option, it would be incredible. Only other thing I would like is lighted switch, although I have never seen one in this this size / form factor. I have no modding ability myself, but if any talented people have the urge, it would be incredible. As long as we’re dreaming, I’d like one in solid copper.
Richard
rmkline
AEDe
AEDe's picture
Last seen: 18 min 24 sec ago
Thank you for the review.Has flashlight been tested in water(ipx7/8)?
Also could you post large photos of both side of driver?
igeigeige
Hi, have you tried keeppower imr 26650?
M4D M4X
M4D M4X's picture
Last seen: 43 min 58 sec ago
Very nice review!
thanks for your work!
find all available items in this list
i launched my new blog - all deals for members without MAP B$ Wink
find a short description about my idea here
if you want to buy a flashlight or battery for a better price: just send a mail - i will try to save you money!
patmurris
patmurris's picture
Last seen: 1 month 6 days ago
Thanks for the review. I appreciate the run time table. Height hours on med and two and a half on high!
I received my gray NW not long ago and it has become my favorite light when going out in the garden at night – replacing a trusty SRK triple with the same output. The floody beam is very appropriate for close range with no overly bright hotspot to kill your night vision. The NW tint is a tad too warm for my taste though.
A couple things that could be improved:
- I’m often struggling to find the switch in the dark. Although it is opposite the lanyard hole it does not stand out enough to be felt.
- The lanyard portion has some sharp edges.
- There is room for a mode between low (almost moon) and med (which is rather bright).
- Although i’m not a fan of disco modes, a hidden strobe would be nice – just in case.
I would immediately buy a second one if a high CRI option was available.
Really great little light! Thumbs Up
finges
Last seen: 1 day 26 min ago
I would also like to know the driver diameter.
Flashy Mike
Flashy Mike's picture
Last seen: 1 week 1 day ago
Ok, I got the ordered spare micro switches today so I dared to disassemble the light partly: driver diameter is 28.4 mm.
Flashy Mike
… and noticed my ordered switches are too large …
Flashy Mike
Had anyone success modifiying the sense resistors meanwhile?
finges
Thank you!
xlotus
Last seen: 2 years 2 weeks ago
Mine is already at the local post office and I am sure it will be delivered tomorrow. Yeay!
I am not too fond of light that has too much warm tint.
Too much yellow it should not be called white. Big Smile
4700K – 5000K would be ideal, like the tint on my K40M.
I also want to add that BTU PK26 also has the same raised terminals surrounded by compresible foam.
Meanwhile, Imalent DN70 has the same raised terminal on the top but it has a large spring at the bottom.
Too many flashlights!!!
Jerommel
Jerommel's picture
So, there are 7 LEDs in series?
That requires 21+ Volts !?
That’s quite a boost then.
2Q19
will34
will34's picture
Jerommel wrote:
So, there are 7 LEDs in series? That requires 21+ Volts !? That’s quite a boost then.
I measured 17.5V driver output voltage on the lowest mode, not sure if these LEDs have very low Vf or there is something wrong with my multimeter. But either way, all the LEDs are in series. Impressive boost driver indeed!
DB Custom
DB Custom's picture
Highest mode will have higher voltage right? Should have, by a significant increase. Well, they’re still not being driven hard so the Vf shouldn’t go up all THAT much, not like an FET direct drive light or anything.
Still waiting on mine….
adirondackdestroyer
Last seen: 3 days 21 hours ago
Awesome review, but thanks to you I’m contemplating breaking my new years resolution for 2017, which was to not buy anymore flashlights! lol And to think I almost made it a month! lol
This light has unreal performance, considering its size! 900+ lumens for well over 2 hours of perfect regulation! The only change I would have made is the UI. I think one click=low, two click = medium, three clicks = high, hold for turbo, makes more sense then what they went with, but other than that this light looks great!
Quick question, I have a pair of the 69.5mm protected keeppowers on the way, do you think they’ll fit in this light? They aren’t button top, but they aren’t flat top either. The entire top protrudes slightly.
D10ten
D10ten's picture
Last seen: 2 hours 21 min ago
I think the protection might trip due to the 7A draw since most protection is limited to 7A only
will34
will34's picture
Protected cells works, since there is no spring on the tail or driver the DQG lights can accept all sorts of cells length. As D10ten said the protection could be a problem when activating turbo with a partially discharged cell, it draws almost 7A on a fresh cell, and even more when the voltage drops.
adirondackdestroyer
Well shit, so much for using them then! I am referring to the 2015 keeppowers though. They work perfectly in the Convoy L6, which is brighter than this light, although I guess there is two of them (not sure if that makes a difference, regarding tripping the protection)
DB Custom
DB Custom's picture
The L6 is running 2 series at 8.4V to supply power to a Buck driver where voltage is reduced to a 6V emitter.
The DQG Tiny is a 7 series emitter light that uses a Boost driver to amplify the 4.2V cell to match some 21V needed by the emitters, as such the Boost circuit pulls considerably more amps from the single cell.
adirondackdestroyer
Gotcha, I figured that was the case.
Alright then, what cell is the one recomended for this light then?
DB Custom
DB Custom's picture
Good question.
I plan on trying it out with Basen, Efest, Powerizer LiNiMnCo, King Kong Gold, and (ran smack out of ideas, what’s the latest and greatest 26650 y’all?)
