I would likeā¦.
7pcs. line 1 - 219B V1 SW45K R9080
7pcs. line 6 - 219CT SM503
7pcs. line 5 SM403 (EDIT)
please, and thanks for doing this! :+1:
I would likeā¦.
5x 219B-V1 SW45 R9080
15x 219C SW50 R9050
How many 219Bs with R9080 did you get?
UPDATE 170124:
Got you added.
The 319A is the latest and greatest from nichia, I have high hopes for it but it is not tested yet. I plan to fix then as soon as my order comes in.
Added
Added as well
Added
Got you are well
This GB will run till around the 17th of February. Shipping will be the following week to us distributors and then from us to yaāll as soon as we get them.
On the list
You get the idea by now I think lol
Same for you.
Please check over the reserved numbers for all your orders to make sure they are right, easy to get something wrong.
I am not sure where you are located and which list you should be on?
In for:
4x NVSL219B-V1 SW45K [4500K ANSI BBL] 9080 L2 [2,9 - 3,1V] D220 USD 4 USD 3,7
4x NVSL219CT SM273 [2700K 3 steps MacAdams] 9050 L2 [2,9 - 3,1V] D220 USD 4 USD 3,7
4x NVSL219CT SM353 [3500K 3 steps MacAdams] 9050 L1 [2,7 - 2,9V] D220 USD 4 USD 3,7
4x NVSL319ATE SM453 [4500K 5 steps MacAdams] 8000 coming soon coming soon USD 4 USD 3,7
USA
Added
Done. Please double check if I got you in the right spots and in the right amounts.
TA - you got my order correct, but I would like to add two more 319A 4500K to my order please.
Thanks!
Are these listed slots hard limits on the quantity? I definitely want to get in on this, but I havenāt figured out my whole order yet.
Hi Chouster, if possible I would like to purchase 12 of item number four:
4 NVSL219CT SM353 [3500K 3 steps MacAdams] 9050
I am also interested in the 319
Thank you.
Added
The numbers in our lists are simply to make inventory easier. The numbers will grow as the lists do. We will update the lists with a sold out notification when that happens.
The 219B will sell out for sure, in the next day or 2 if I had to guess. So if you want those, I would get on those lists quick.
The rest are limited but we should be ok for at least a few days on them at this rate. Clemence manages the overall inventory and generally posts updates on remaining quantity once one of them starts running low.
They are all first come, first served. Just too hard to do it any other way.
Hi, youāre on the list now.
TA,
Iāll take
2x 219C 5000K
3x 219C 5700K
If 5,000K not available then make it all 5,700K
done
Ok, then Iām in for:
for Europe. And Iāll update my order later as I definitely want some 219Cs and 319As.
Roger that.
Got you added. There are lots of 5000k, I simply do not always take the time to add more numbers after the last one.
