I received the Manker MK35 from Manker for the review.
The MK35 is a big thrower light from Manker.
This sample is a prototype, so expect some imperfections in the finishes, and some changes in the final version (for example, my sample does not feature physical polarity protection but that will be present in the final version).
The Light came in a cardboard box, padded with white foam. No accessories for a prototype but a lanyard.
No manual or specification was given to me, except:
a) The max output (around 2500 Lumens).
b) The UI is the same as the Manker MK34.
c) It has over discharge protection integrated.
d) NW tint will be available in the future.
The light is comparable in size as my Nitecore TM16GT.
The light packs a XHP-35 Hi Emitter, in a deep smooth reflector
And, as the MK34, it is controlled by a single electronic switch, at the head.
It can be found in the dark because it is positioned in a fin less zone, and is deeper than the surface.
Notice that the usual Manker rubber switch cover, with the Manker logo, has been replaced by a hard plastic one, black except for a clear part in the center.
Opposite to the switch, there is a tripod screw.
The tailcap is wide and flat and has 2 position for mounting lanyards.
The tailcap has the usual construction, adopted by several 3-4x18650 models.
The threads on the body are squared cut and anodized. so physical lockout is possible at the tailcap.
A few marks on the anodization inside the body. Again, this is a prototype and not a light that will go on sale.
On the end of the body, there are the contact points for the driver at the head. They are golden plated, and the threads are anodized and square cut.
At the head, the 2 contact points are golden plated also.
Some size measurement
My scale is broken, so no info on the weight.
UI
I paste what I wrote on the MK34 review:
• When the flashlight is off, one click, access to moonlight mode (left part of the figure), one click to circle: Moonlight – Low – Medium 1 – Medium 2 – High. Long press for light off.*
• When the flashlight is off, long press to access to the mode your last use as in left part of the figure (Memory function), one click for circle. Long press for off.
• When the flashlight is off, double click access to Turbo, one click for circle. Long press for light off.
• When the flashlight is on, double click to switch between the two groups (left and right part of the figure)
• Basically, the UI is very similar to the one of the other Manker lights, but it has improved: you keep access to the lowest mode and the last used mode… but finally you can directly access to turbo mode.
• When the battery is running low the LED under the switch will be purple (<50), and later on red(<20).
• *if you are in high, and keep pressing the switch, the light will switch levels in this order: high, mid2, mid1, low, moonlight.
• The output of the moonlight mode is 0.1 – 30 lumens because using the engineering mode (indicated in the graph) you can change it.
But there are some differences:
a) The LED under the switch will work as battery indicator staying on all the time.
b) The rubber cover on the MK34 was more transparent compared to the dark plastic one of the MK35. The dragon breath still works, but the light is visible only at the transparent center of the dark plastic switch cover.
c) I have not measured the max output that can be set at moonlight mode, but to my eyes is less then 30 lumens.
Output and runtime.
Due to time restrains, I have not tested the output at moonlight and low mode.
After the temporized stepdown, the brightness from Turbo stays on the High2 levels.
Sorry about the plot below, but I started the runtime test without knowing the output of the modes and I expected a shorter runtime ad mid mode (I thought it was in the 2-300 lumen range), and so the light has been stuck in the runtime box for straight 33 hours.
The fluctuation in the output is gradual, and in the 10 lumens range. Not noticeable with the eye during the use.
Throw measure
Turbo 19’450 lux at 5 meters = 486’250 Cd
High 13070 lux at 5 meters = 326’750 Cd
Mid2 4760 lux at 5 meters = 119’000 Cd
Mid1 643 lux at 5 meters = 16’075 Cd
Beamshots
I got a new, nicer camera and I have not had the chance to use it many times.
Tree at 100 meters. As control, I used a well known light with good throw: Nitecore TM16GT. On the camera they looked very close to what I saw, on the monitor that I’m using they are underexposed. Still, you get the idea.
A couple of GIFs.
In the GIF is more evident that I moved the tripod when changing from one light to the other.
It would have not happened if the TM16GT had the tripod screw on the body and not on the tailcap. At 100 meters, 1 meter closer or further does not make so much difference.
While I was taking the shot a visitor run through the beam and stayed a bit to watch.
Here are the other Beamshots (hopefully I have written the right distances)
Tree with a reflective element on it. 140 meters.
Building. 350-380 meters.
In this pic I moved the light on the left to show better how bright and wide the spill is.
Building. 450 meters.
My thoughts
Fit and and finishes are not relevant in a prototype, however except the minor scratches in the battery compartment, my sample is perfect.
During the use I found myself at ease with the great throw and the wide and bright spill combined. In the many beamshot you’ll see that the spill arrives at the center of the tripod, so you can actually point at things that are very far away and still see the details of the path that your feet are traveling.
The tripod screw is right where you can mount it on a tripod and orient it in the direction you want without making the tripod fall or reach the max inclination degree. This also helps the Beamshots a lot.
Compared to the MK34, the switch feels now much more soft and easier to press. Given the lack of physical lockout, the electronic lockout is the only lockout possible (which now is much easier to achieve given the softer switch).
The UI is fine, now I have access to the low mode, the last used mode and the turbo mode.
I like the LED under the switch working as a battery indicator, but I’d rather have the rubber switch cover of the elder Manker models, so I can better see the light from that LED, and I find it also nicer to the eye.
On the MK34 the max customizable output of the first mode is much brighter (and usable) than the one of the MK35.
This light could benefit from being sold with a shoulder strap (one attachment point at the tailcap, another in the tripod screw).
Thanks to: AntoLed for the camera help and the luxmeter, Zampa for the tripod, thermal equipment, and PP for the beamshot location.
