Discussion : - Utorch UT01
Does the above apply to all battery chemistries(?) as I was under the impression that unprotected cells were afforded a different (the least) LVP.
I was talking for 3.7V li-ion batteries . Both protected and unprotected batteries will act the same in the light (LVP wise speaking) , protected batteries protection usually kicks in @ 2.5V .
When using an eneloop charged to 1.405V, my UT01 works great. When the voltage drops to 1.295V, the light starts to act weird. Sometimes it will turn on normally, sometimes I have to click two or more times to turn it on, other times it doesn’t turn on at all. Once it turns on, it works normally.
Anyone knows what’s going on?
Put another eneloop in. Ran it on high until it dimmed. Now it won’t get any brighter than medium. Turned off and it won’t turn back on again. Voltage is 1.1V. Is LVP kicking in? Shouldn’t it do that at 1.0V?
FWIW… I just depleted a 2000 mah eneloop on Turbo. Didn’t actually time it, but it was in the vicinity of 45 minutes. Right around ~1V output dropped down to one of the low modes. I am not sure exactly which one but it was around 50 Lumens and i think its similar to my second lowest programmed mode. Pressing the button at this point only cycled between 50L low and firefly. I could turn the light on and off, but turning it back on at this point only presented two modes… firefly and the 50L.
Removed the cell and measured it immediately at a comfortable .95V.
I dont think that’s the LVP. 1.29V is still more than healthy for NiMH. FWIW neither of my lights do that… the UT01 or Makner E11.
Not getting any brighter than ~medium sounds like the LVP doing its thing…. at least thats what mine does.
Mine at that point will turn on and off however.
I am guessing there is a tolerance or window for the circuit, so the actual voltage level may vary from light to light. 1.1V - 1.0V might be within range for the LVP.
It sounds to me like you just have an over-protective LV circuit.
Thanks for sharing. I may end up using this light with a 14500.
Not the highest quality torch, but it’s not bad.
I got one during 11.11 event in NW XPL V6-3D
But compared to my other lights including the Q8 it is definitely a 4000K emitter
anyone else have too warm emitters?
My Manker E11 is very warm / amber colored while the UT-01 is pale white.
Both were the NW version of each.
Same here. The one I received a couple of weeks ago seems warmer than 5000k.
Mine too.
I like it.
But the switch problem… :person_facepalming:
too warm for me, sounds like they get a ticket
I ordered the CW version now, hoping I will like it better. Just keeping my fingers crossed that the switch is not broken.
I mentioned the 4000K two weeks ago in the other UT01 thread. I like it too, but it is way off the 3D tint that the site and the package claims.
Last night I was comparing some lights.
I have some 5A tints in other 1xAA lights (emitters that I got from Intl-Outdoors), and these ‘alleged’ 3D UT01’s are remarkably close - which is fine by me. :+1:
I have Astrolux S1 3D (neutral white), the tint of which I like.
Comparing the UT01 neutral white (supposedly “3D” tint), this is a much warmer — in fact I compared it with a Convoy S2+ (XM-L2 T6-4C tint), and the two tints are closer to each other, or the UT01 “3D” could even be very slightly warmer…
Decided to do some more pics while I’m at it…
Lighting under fluorescent tube
Astrolux S41S Nichia 219B (90CRI — based on product description when I bought this)
(This is the closest to what the floor looks like in actual)
Astrolux S1 XP-L (3D tint)
Convoy S2+ XM-L2 T6-4C
UTorch UT01 neutral white ‘3D’
using a budget digital camera with setting “Daylight” white balance
Not a fan of this NW tint on UT01. I’m hoping I like the CW version better.
