Review Atactical "A1" (New Company)
5 posts / 0 new
robo819
robo819's picture
Last seen: 3 hours 40 min ago
This is the Atactical “A1” sent to me for review and NO other compensation other than keeping the light. You can find the light at any of the following links……..
(ALL links are NON afilliated)
Official Website: http://atactical.com/
Amazon United State : https://www.amazon.com/dp/B01NBKWBU8/
Amazon Germany : https://www.amazon.de/dp/B01NBKWBU8/
Amazon United Kingdom : https://www.amazon.co.uk/dp/B01NBKWBU8/
I was also asked to mention that Atactical will be giving away a free light by randomly picking up winners from thier Amazon reviews. Follow the outcome on Facebook or official website to see the outcome of the giveaway.
Facebook Page: https://www.facebook.com/Atactical-680078065495037/
Now on to the main topic here……….
ATACTICAL is a new company with only a couple of products at the moment , but that may be changing very soon the way it is looking to start shaping up. This A1 is priced at the time of this review at $19.99 on the Amazon site , which makes it a budget friendly light. Atactical is working through / with ThruNite on the testing and advice of these products so I feel the quality should be there , as it is at least with this particular light. The A1 “S” model is in the making with double the lumens and a XP-L V6 emitter , so it may be one to watch also.
I covered most everything in the video portion of the review but I will mention highlights here for anyone not wanting to watch the whole review video.
The A1 is a well built light with good anodizing , smooth threads that were well lubed , and no sharp edges or noticeable mill marks and such. It also comes with the USB rechargeable cell and has the charging cord included with the rest of the package , or you can simply put the cell on a traditional charger and charge it that way if preferred.
The light has Low/Medium/High/Turbo and SOS modes , that are changed by using the side switch on the light , with a hidden strobe that is accessed from any mode by simply holding the side switch down for about 1/2 to 1 full second and then a quick click to exit the strobe. The tail switch is used for momentary on or to turn the light on and off only. There is also a low Voltage indicator built in and the light will blink twice periodically , when the voltage starts getting low on the cell. The lens is AR coated and the reflector on the sample I recieved is very smooth and clean. The side switch is metallic with a coating of what looks like either powder coat or anodizing , but I cant say for certian on that. The XP-G2 emitter is well centered and the beam is fairly tight , but has decent coverage and no visible rings or artifacts that I have noticed in normal use.
The A1 and the ThruNite TC12 V2 are very very close in design , with only a few slight differences , so it could be that ThruNite had a hand in helping design this light also. I guess it could be speculated that this is a budget version of the ThruNite product even. Either way the quality of the light for the current price of $19.99 makes this a very good deal IMO and well worth a look for anyone who might be interested.
For those who don’t want to watch the whole video , the still shots , teardown and beamshots start at 5:47 in the timeline and the live footage outside with comparison to the Throfire VG10 and the ThruNite TC12 V2 , starts at 9:44 in the time line. As usual I will mention that the still beamshots are much more true to life than what my cheap video camera shows.
Video followed by listed specs……………
FEATURES
•One USB rechargeable 2600mAh 18650 battery included which provides 550 lumens output.
•Reverse polarity protection design to protect from improper battery installation.
•Aircraft-grade aluminum body.
•Toughened ultra-clear glass lens with anti-reflective coating.
•Low Power Indication: When the voltage of the battery is low, the light will blink twice periodically.
•Direct access to strobe mode: when the light is ON, long press to quickly access to strobe mode.
•Dimension: 136mm*25.4mm
Accessories
•Spare O-rings x 2
•Customized USB rechargeable 2600mAh 18650 battery x 1
•USB charge Cable x 1
•Pocket Clip x 1
•Instruction Manual x 1
Click any link to see MY REVIEWS:
Maxtoch M24 Sniper / Maxtoch 2X Shooter (2016 factory dedomed) , 2X - XHP 70.2 / Maxtoch Xsword / M1 Archer *** ### ThruNite // Archer 2A V3 / Ti4T / TN4A HI / TH10 / TH20 / C2 Mini / TC12 V2 / T01 /  , neutron 2C V3 , TC20 / Catapult V6 / TC15 / *** ###  Olight // H2R Nova , S10R III / S30R III / H1 Nova / H1 R Nova / X7 Marauder , PL Mini ,  M2R warrior //// Orca T11 / Nitecore EC20 / BLF A6 / Custom Convoy C8 / Lixada Triple 3800LM / Lixada 1000LM / LuxStone X30 / Manker E02 / Manker E14 II /  ### Thorfire /// PF03PF04 , Upgraded PF04 , C8 , S-50 ,  VG-10 , VG25 , C8s , BL30 , TK4A  , S1 , VG15 S  , TK 18 //// ##WowTac// A4 , A1 (original) , A2 headlamp , A3 //// Acebeam L16 /// Massdrop (Lumintop) Brass EDC
Edited by: robo819 on 02/03/2017 - 18:43
EyeballFryer
Last seen: 2 hours 49 min ago
I like that in your slide show section, you took time time to label each slide with a brief description. It is much appreciated.
robo819
robo819's picture
Thanks and glad to do it also.
bikenber73
bikenber73's picture
Last seen: 21 hours 29 min ago
Nice review!
Good to have a quality $20 rechargeable 18650 light two days away. When I first started in this hobby, that was an impossibility!
robo819
robo819's picture
bikenber73 wrote:
Nice review! Good to have a quality $20 rechargeable 18650 light two days away. When I first started in this hobby, that was an impossibility!
Thanks and yes I was pleasantly surprised with this one and the upcoming A1 “S” myself , with the quality to price aspect also.
