Actually $32.99 with code 26800RAV
bummer that it doesn’t come w/ cable to jump start a vehicle, doesn’t look like it has the
correct connector for one neither.
For a powerbank to start a vehicle the battery must be high drain LiPo in 4S, the ravpower one uses 18650s in 1S configuration.
Superway 10,400mAh lantern / powerbank combo
Got one last week and it is great, measured 32Wh output at 5V 2A which means the 10,400mAh rating is REAL. About 400 lumens output and extreme runtimes in medium and low. Well built although glued all around so no modding possible. CW tint 5,700K with nice spread, about the side of a meteor.
I have a quick review coming soon when the runtime tests are done but I’m going to give you my word for $22 this is a steal, you won’t regret it.
Wowser, that's some serious run time. Looking forward to your review. How do you get it for $22?
delete.
At the time of my post there was a flash deal going on and it was $22.40, right now the price has gone back up but you can find the exact same lantern under other brands for about $28, or pay $36 for this superway one and get a smaller 4,000mah version free.
Runtime was Over 20 hours on high and 70hours on medium, not fully flat but a steady drop to about 50% power then LVP kicks in. Review should be up this weekend.
Astrolux S1 for 13.99
Saw this on Amazon after noticing GB had a sale on the Solarstorm K2 for $16.
Had to grab it at $7.99, even if it is a few years old…
Only 8 remaining at time of this post.
Reviews:
https://budgetlightforum.com/t/-/20035
https://budgetlightforum.com/t/-/20458
Thanks pieman7, only 6 left now
For $8 and prime shipping there is room to bring it up to date.
5 left
I don’t think I need this so pls put it out of stock soon
Thrunite Ti5T (titanium alloy) Cree XP-L LED flashlight - $16 shipped w/ prime
Astrolux S41 for $31.99 Prime.
https://www.amazon.com/KeepPower-3400mAh-protected-Panasonic-NCR18650B/dp/B00WDQTIN4
I was looking for some short KP protected 26650 cells for a friend and came across this deal on protected KP NCR18650B.
Next best US price I could find was ~$41 for different brand protected NCRB’s with slower shipping.
$36 with 2-day prime seems pretty good.
Buying lithium ion batteries through Amazon from a third party seller calling itself a Grocery already seems strange enough, but one named Bang Bang ???
I purchased those same cells linked from that seller. I made a similar comment at the time to wife, odd name indeed… Bang Bang Grocery, hmm… not sure what they’re aiming for here. Nearly two months later and no issues with the batteries far as I can tell! Try CamelCamelCamel and paste the AMZ link there to check the price history of an item, see if it’s really at an all time low and if there’s a pattern to price fluctuations
It’s fulfilled through Amazon. You can pick the other Supplier if it makes you feel better.
Either way, they can be returned for free if you notice anything even remotely out of place with them.
Always have liked Pannies, been pleased with Keeppower, and had good luck with Amazon, both from and through them: but I don’t need any Panasonic Bs or protected cells at the moment.
I have still been trying to figure out how much truth there is behind rumors they bin merchandise from different sources together at times.
Hard to imagine how they deal with returns, defects, counterfeits and serial numbers. Prefering not to believe, it is easier for me to attribute it to gossip, disgruntled employees, or competitors.
Still, after pointing out well recognized falsehoods involving fallacious flashlight lumen and battery mah claims, they either don’t pay attention, avoid doing their research, or seem not to care at all.
So what is up with the free Thor fire led color changing bulbs? It was posted in blf deals alert. Use the coupon and get it free. And it worked…
My bad, I meant to post it here, as this thread is what inspired me to search (“thorfire bulb” on Amazon) for those high CRI bulbs discussed above. I couldn’t find those, but it seems TF has a high rate of clearancing out old stock (ie VG10, bulbs, headlamps… lots of sold out listings)? I’m not sure the reason why they’re so cheap, but I’m sure you can tell I’m excited to report the deal haha.
It worked for me, and as vwpieces pointed out in the other thread, so does buying multiples. I made an order of 10 bulbs + 1 remote = $11 (and free 2 day shipping with Prime); quantities adjusted in cart after coupon applied. If I understood my father correctly, he got 6 + 6 for $12. Price goes up slightly from free (hard not to…) if you add more quantity than 1 + 1, but the coupon says 90% off qualifying items, and it’s still a killer deal. However, the code only works once per account, I believe; curious I tried to test it a second time, and see if it would also apply to any of their lights and altogether nogo. Fortunately, a lot of their lights seem to have (more realistic) promotions listed anyway
Here’s the link to other thread & repost:
Free RGBW smart bulb with remote, app, and over 16+million colors.
ThorFire G1
Amazon.com (link is external)
Scroll down to promotions, click Add Both to Cart (bulb + remote), then apply this coupon YALYTTXW before checkout. Checkout should then be $0.00
Thanks ThorFire! Big Smile
