What host, URL please?
The KD host is the same size as an S2+ā¦
I think FT had some 18650 brass beautiesā¦
Ahh, didnāt realize it was S2+ size. Was more interested in it for the brass aspect.
Yes, they have. Thanks! :+1:
~~X3~~:I think FT had some 18650 brass beautiesā¦
Having trouble finding it at FT. Could you post a link please?
Cheers.
Donāt see any brass 18650 models-just this one for AA
https://www.fasttech.com/products/1601/10007053/4217301-cree-xp-g2-r5-3-mode-900lm-led-flashlight
Thanks Gunga
Oh, thatās great. I didnāt think theyād turn up again. I ordered one just to have a spare to mess around with - it claims to be ārestockingā and the date has gotten pushed out a couple of times to 3/2 so far, but at least itās still listed on my order.
+1, endless ārestockingā - ETA was extended several times. Looks like itās out of stock indeed.
It took 2 weeks before mine was shipped, from the date of order.
Arrived yesterday. A few differences compared to my original one;
* Tube is about 6mm longer.
* Double sided driver.
* XM-L2 emitter.
Not sure if it's an ATtiny chip, my clip wouldn't fit due to the CAP being in the way.
5 modes; L,M,H, SoS, Blink. Next mode memory. Have not tested to see if it's set up for config change via the stars.
Machining quality is on par with original, & threads match.
There's almost enough spare thread in the head to cut it down to 18350 size..... Hmmmm :)
Disappointing that itās longer than the original. Thatās too bad. Mine apparently shipped yesterday after ordering 2/25, not so bad I guess. Is the driver still held in place with a threaded retaining ring like the original, or is it soldered in now?
Still has the same pill & threaded retaining ring.
I canāt see the pictures. Iām curious about what is taller.
I can't see the pics either.
Sorry about pics for those that canāt seeā¦. Whatās the best method for sharing pics from Google pics??
The length difference is in the tube only. The head & tailcap are the same length.
You could save and then upload to imgur.com and post the links, donāt even need an account. Doesnāt look like the forum lets you upload directly.
So everything else is the same? Just a longer tube? I guess this allows it to fit button top cells. The spring on the tailcap is too small and weak though. Has it been beefed up?
