Hey mate i just tried and it does! My LG HG2 are a tad short so it rattle a little nothing major. Only when you shake the light really hard.Same with my Samsung 25r they work but if you where to hit the light to hard it may turn of because the connection would be broken. I wouldnāt suggest hitting the light hard lol.
The head has a tint button on driver board that is maybe 1mm long.
No. The battery is not being.
Do not PWM. Trembling brightness. Approximately 10-20% brightness its happening.
This is a problem in the driver may not be correctly matched inductance or capacitance.
I just tried mine again but this time on a white wall through my camera and its completely fine. Maybe it was just the first ones? i would have noticed when i was taking pics. I will have a video up soonish i hope you will be able to see in that.
Iām afraid to open it. I saw pictures of whatās inside and it does not inspire optimism me
There is a problem. What exactly is due, I do not know. If a newer version to fix it, itās good.
It does not look like frequency issue.
Just random blinks with significant output drop. Usually happens in low mode. Not so often to stop using flashlight but stillā¦
Can you quide me in the right direction about optic options for the hc30?
Do you mean ready to buy click on little adjustment optics or get the heat gun ready and fire up your soldering iron optics?
I have a HC30 and want to venture into maybe doing something with a flip up/down diffuser like the skilhunt H03F has got.
Thanks
I kinda like the H03F but refrain from buying one, due to people saying it may flicker and Skilhuntās customer service/guarantee sucks.
My optics fit straight in the HC30 I had to sand Down the sides a little but nothing major. I got mine from fasttech. Iāll find the size for you. I think my optics may be a little floody for most people.
This is the optics that fit on the HC30 i use this exact one. It maybe better to get a different angle how floody do you want the beam to be? these optics have like no throw at all. You could use a diffuser if you want like half/half? Get a tiny hinge and piece of metal that fits over?
I LOVE this headlamp and can also confirm the newest version with blue top works perfectly. No issues.
All of these types of headlamps are meant to be worm with that dorky top strap. I refuse to wear it! Without that top strap it does flop a bit. Doesnāt feel stable. I have a Thrunite TH20 and decided to pop the Imalent into that strap (it doesnāt have a top strap). WOW! The Imalent is not perfectly stable. No need for a top strap now. The rubber mount is beefier so grabs and hold the Imalent tighter. AND the Thrunite strap is tighter and sturdier. I will now only use the Thrunite TH20 strap with all my headlamps. Try it!
Update charging light went out completely! Ughhhh. Iām pretty sure itās still charging because I take out the battery completely and while plugged in the light still work.
Itās not the battery. Iāve tried a few others.
Iām almost certain itās still charging batteries just no LED indicators of doing so. As I mentioned, while plugged in I can take out the battery and the headlamp still turns on
