Awesome mods. Thanks for sharing
Couldn’t agree more with everyone’s comments. Amazing effort and skills. Thanks for posting it up.
Outstanding work again!
You chose one of the ugliest hosts around (in my opinion) but that does not matter, after you’re done it is a wow light!!
Another 5* mod from you Cula !
Thanks for sharing…
Wow, nice mod, great job :+1:
WOW!!
Avesome job!!!
Bravo!!! :+1:
Impressive! Thank you for taking the time to take pics at each step of the process.
Questions:
- Is there any “springiness” or compression room remaining in the spring bypass setup? In other words, any wiggle-room for slightly different lengths of batteries? Maybe this doesn’t matter since protected cells will never be used here
- What is your preferred method of sanding and polishing the exterior? Great idea using rope for the cooling fins!
You could be a jeweler, :heart_eyes:
Fantastic job! I only wish I had the knowledge to do something similar myself… One day I’ll try to mod something. I think I’ll start with a S2+ triple.
AMAZING MOD.
Thank you guys for your comments .
You are indeed right. It is a reflection from AR lenses.
1) Barely, don’t have any protected ones to try. I can’t be sure.
2) I used something like this mounted on my bench drill (https://www.amazon.co.uk/d/brv/Wolfcraft-2178000-Hobby-Polishing-Metals-Plastics-Marble/B0011LQGBE) and a lot of elbow grease . This kit can be bought in almost every hardware store.
Very nice build and thread. Congrats and thank you for sharing. :)
Holy crap. That is beautiful; your mirror polished parts are always breathtaking. I’ve seen something similar to the blue rings before; I think It’s caused by the AR coating on the glass. I have a 20mm AR lens with an unknown origin, and it projects a blue ring of light from it for some strange reason.
Here are some beamshots. Pictures don’t do the justice but that is the best I could do with my limited photograph skills.
Also did current measurements:
Low low - 0.12A
Low - 0.18A
Mid - 1.14A
High - 3.27A
Turbo - 11.10A
1. White wall
2. Control 1 (lots of street light, distance 70 meters)
3. Beamshot 1
4. Control 2 (distance 25 meters)
5. Beamshot 2
Cheers
Nice build! How long did the polishing take?
Is the ZY-T08 tail switch only, or dual switch? I thought I saw somewhere that newer models have an E-switch.
Good work Cula
Hi Mike,
Polishing took several hours, lots of corners, hard to get places , sharp edges. Very difficult task, especially cooling fins. It came out very nice but far from perfect.
ZY-T08 is a tail switch only.
I think there is another similar model with the side switch but there is something wrong with it (something glued, cannot be taken apart if my memory serves me right). There is a review on this forum but I can’t find it anymore.
Thanks, good to know. I have an old one with a tail switch which I converted to 2S for a MT-G2. I found it too large for tail-switch only so I mounted a side E-switch, so now it’s dual switch.
Nice lighted basketball court you have there! You could start a night league.
Amazing build you have there, and it sure takes lotsa patience to achieve this!
