Moonlight is one of my most often used modes as we have a child that sleeps in our bedroom so I always use a sublumen mode flashlight when entering the room while he’s sleeping. Often times he’ll cry in the middle of the night or we need to change diapers or there’s a fever and we need to administer medicine (you don’t want to know where…), there’s been endless times where moonlight has been useful.
And if you don’t have a child, moonlight also helps when going to the bathroom or camping in the dark with night adjusted vision. I find that anything over 1 lumen is actually too bright if I’m just waking up. Obviously, high cri is also nice to have at night since more detaisl can be seen at lower levels of light.
I am interested in Thorfire hosts, depending on availability and price. Might be cheaper/easier to wait for a sale and then buy the whole light though?
For a true EDC light, moonlight is a must. Thing is, people have different definitions of “moonlight”, and seem to conflate all of them. I prefer to distinguish them as “low-low”, “moonlight”, and “firefly”.
“low-low” is the brightest of the bunch, similar to low but actually lower. It’s probably a few lumens, good for grubbling around in a bag to find your keys.
“moonlight” is next down, maybe 1lm or so, enough for lighting up a clock from across the room at night without ruining your night-vision.
“firefly” is lowest, able to look right at the LED without squinting, a fractional-lumen, just enough to read something close-up without ruining your night-vision.
Again, some people find “moonlight” on their lights to be too bright, others not bright enough. Good luck trying to make everyone happy.
The brightness levels I see on my VG10 are about perfect for me. I’d recommend keeping those.
Ditto. Whatever light I have at night, I make sure is set on its lowest setting. I’m even using my S2+ less and less (read, hardly at all anymore) because generic “low” is just way too bright in the middle of the night.
Lights went out here a few days ago. So time to put my new (Jan. 2017) VG10 to use as a nightlight in moonlight mode. Barely able to tail stand, with a good amount of lean. It would be nice if the switch cap was recessed a little in relation to the tailcap. Really like this light a lot.
Hosts would be excellent to sell in any of your lights. I’ve modded the new version and old version C8s, the TG06, the VG15, and a few VG10s. They are all very easy to mod and it would give us a chance to put what we want in them. I’m sure you’ll sell quite a few more going just the host route because your flashlight bodies are very good quality.
Wonder why no one ever had a UI where, say, if you had 4 “slots” of light output, you just set 1-255 “clicks” for each setting (setting to 0 means skip that slot). 1 flash for slot 1, through 4 flashes for slot 4. You set ’em as you want ’em. Lets you set:
• firefly, low, mid, high
• mid, low, mid, high
• high, mid, low, moonlight
or whatever your twisted little hearts desire.
Then, no one’d be bitching about “moonlight” being too bright or too dim, or about HML/LMH ordering, or about mode-spacing, etc.
And 255/0/0/0 would be a 1-mode on/off light. 10/255/0/0 would be moon/turbo. Etc.
Gimme a VG10 with that UI, and I’ll kiss ya on the mouth.
