Thiz one
I’m just sad that FastTech stopped selling the awesome 602C host… :weary:
The UF UF10 is quite different internally than the EC11 IIRC. The UF10 is a pull out zoomie like the SK68 whereas the EC11 has the two switches and quite a few more functions. I like the looks of both of them though. I have an EA11 and would also like to get the EC11 as well since I they have the same features (which I like). The UF 10 is very similar to the Tacfire SK69 from what I’ve recently seen.
NiteEye 10…also uses 18350…
EagleTac D25C
Wow had no idea they made a zoomie in that style!
Yeah one is a cheap zoomie while the other is a high end reflector light. Both look nearly identical from the outside though
16340 is my fav edc size, output, run time and of course size! Find it(along with 18350) a decent balance for every day uses.
Few i like a lot are………………
v11r mirage with 219c(thanks to gunga)
HDS rotary hi cri 200lm 219b
Haiku tana triple 219b 4500k
Pocket Rocket off PK
Difficult choice between these two, but probably the good old D25C (5000k nichia, biscotti fw and trits)
One is a lot bigger than the other
Malkoff SHO.
My custom flashlight
XTAR WK42
I did not like PWM.
So I made a new driver for it
http://forum.fonarevka.ru/showpost.php?p=881876&postcount=20
SWM V10R dark gray:
My 16340 collection
Nice pics guys! Thanks for sharing
My favorite 16340 is an Aspheric Utorch S1 Mini, modded to 2000k and 4500k Nichias
Aspheric Lenses are outstanding for close range and HatLamp use
I include an RRT-01 for the infinitely variable UI, the lowest low, and highest high (destined for a High CRI LED swap)
I include a Novatac, for the small hotspot, and Programmable brightness modes (destined for a High CRI LED swap, that will also triple the max brightness)
I have a couple of 16340 lights but for months I’ve been carrying a 4000k triple modded D25c ti (2017 version) with single led lighted tail. Occasionally I need something with a little more throw but the size, feel, tint etc… it’s been hard to find a new fav
