Utorch UT02 review
21 posts / 0 new
Narmattaru
Last seen: 2 days 17 hours ago
Utorch UT02 review
I suppose most of you have red about this situation with about manker\utorch version of (I believe) the same flashlight. A lot was written about it, so I`d just like to share my impression about UT02. I bought it at here Gearbest for a nice price, which was just 39.99$ (coupon utorchdeal). And I strongly believe that for such a price there is no product of the same build quality and functionality at market.
Stated characteristics.
● Rugged, solid and far-reaching palm-sized light
● CREE XHP35 HI LED, maximum output up to 1300Lm (actually, less)
● Precision reflecting system emits up to 700 meters’ throw
● 6500K cool white and 5000K neutral white dual light color options
● 5 constant outputs as well as 2 flash modes
● Micro USB charging port, 2A quick charge protection circuit
● Charging and power indicator display charging status and remaining battery capacity
● Waterproof in accordance with IPX-7 standard
● High strength and light weight aircraft grade aluminum alloy with premium Type III finish
● Compatible with 18650 and 26650 batteries ( not included )
PACKAGE AND APPEARANCE*
UT02 is packed into cardboard box with simple design.
Package includes:
Flashlight, 26650-18650 adapter, USB Cable, lanyard, 1 x O-ring, english manual.
Utorch UT02 looks good, and feels good in hand. It definitely doesn`t look like 40$ flashlight.
Body is accurate, of modest size (comparing with most popular 26650 flashlight which is L2).Total length of UT02 is14.8cm, head diameter – 5.9cm, body diameter is 3.5cm and 4.1 cm at button part. Without head it is about 10cm long.
Reflector is (of course) SMO, with CREE XHP35 HI. Now I suppose that i`d better pick NW version.
I`ve red some comment here about fingerprints at reflectors, mine came clear, but there was some dust under reflector, simply`ve blown it away.
Dualsprings
Knurling is regular, rhombic.
Threads were well lubricated only at tail. Threads in body-head connection were not lubricated as much as at tail, and there were to lubrication under bezel.
As threads are anodized, it`s possibly to physically lock flashlight.
USB-port and side button are located at opposite sides of head.
USB-charging port also deserves to be mentioned, as it really provides 2A, taking it little bit than 3 hours to fully charge 5000nah 26650 Liitokala
There is print with model name and hole for lanyard at the tail, that`s it what about appearance.
Build quality of Utorch UT02 is really good, you never can tell that this flashlight`s cost is that low.
UI
Simple
ON\OFF with long press.
Short presses will change modes.
2 quick presses in ON will enter strobe-dragonbreath-SOS (call it mode A).
There is also way to enter dragonbreath in OFF – 3 clicks, then strobe-SOS.
And here is a hidden mode (B) Hold side button for 10 sec, light will blink twice and turns off. Now you get hidden mode, where strobe-dragonbreath-SOS get additional Turbo+ without stepdown-beacon- side button constantly glowing blue light.
If you press twice in Beacon mode, UT02 will turn off, then you turn it on and get into LOW adjustment, with 15 degrees of brightness up to 100 lumens (i`ve also heard of 21 levels, may be this was with 1st version of driver). To set Low after adjustment , just turn light OFF, I prefer to keep my LOW as it was.
Turbo+ works about 10 min and then lights turns off to prevent overheating, in cold weather runtime may be longer (i`ve red about 52min).
What about button. Thought it looks good, my opinion is that it could be made better. To be precise – I don`t like short movement of button. Even 1mm deeper will be ok. Regardless this – button is ok. There is also indication in it.
During charge indicator glows red, then turns blue when battery is full. It also turns red when battery level is below 25%.
Max temperature that I measured was 50 Celsius
UT02 IN WORK*
I have 2nd version of driver with 1100 lumens and 100kCd, for NW it will be 1000 and 90.
Amperage at tail:
0.012 – 0.145 – 0.458 – 0.951 – 2.83А
0.0085 mAh – parasite drain, it`ll took eternity to discharge battery.
Short video to show stabilization, starting from turbo.
As my luxmeter is not precise at all, I can give you only reference measurements from about 5m distance to give an idea.
Utorch UT02 – 13600 lux
Nitecore P30 – 15800
Convoy L2 – 20600
YL Ballista 3.0 – 30100
Maxtoch 2x shooter – 41600
There is 175m to this wall. It is not clearly seen on GIF, but there is light at this wall even in MID2 mode, which is qiute good for 100lumens. I made separate pic to show this.
230-235m distance to trees at the end of path.
Same with zoom.
That is so hard to catch real output of low modes at video, but it is better than nothing. Hope it will be of any use.
OVERALL
UT02 seems to be really good choice as longthrower for such a price. It has good build quality and stabilization with long runtime. My personal dislike is one – button, though it is better than at Nitecore P30 which I reviewed at the same time.
So, here is coupon, it expires quite soon, at 10.02 and valid for both NW and CW versions – UtorchDeal.
Edited by: Narmattaru on 02/08/2017 - 10:37
Abqjohnny
nice review on a flashlight I am somewhat interested in myself.
Bill_tong
Last seen: 2 weeks 3 days ago
Great Review, but why do you think it’s better than the Nitecore P30?
Narmattaru
for me P30 has only one advantage – size
UT02`s cost is the same, but you get better runtime, more modes and usb-charging port.
i don`t say P30 is bad, but i think ut02 is better.
kotobuki
Last seen: 3 days 11 hours ago
My Utorch 02 from Gearbest arrived few days ago but missing O ring in a front, it made rattling noise when I moved flashlight around. Sent email to Gearbest but have no reply yet. Does anyone have a problem with Gearbest Ticket page when attached files (says “Invalid code” when attached picture or video but pass through when not attach anything!!). I’m using Chrome as a browser.
By the way, I like the spot of this flashlight and look likes it never gets overheated.
Narmattaru
write me PM with links to photos\videos and order number
i`m in touch with GB manager, may be she`ll help you out at leacst in transferring your message to support.
they also had chinese new year holidays, so may be customer support girls were busy.
Streamer
Streamer's picture
Last seen: 5 hours 54 min ago
kotobuki wrote:
My Utorch 02 from Gearbest arrived few days ago but missing O ring in a front, it made rattling noise when I moved flashlight around. Sent email to Gearbest but have no reply yet. Does anyone have a problem with Gearbest Ticket page when attached files (says “Invalid code” when attached picture or video but pass through when not attach anything!!). I’m using Chrome as a browser. By the way, I like the spot of this flashlight and look likes it never gets overheated.
Seems a real hassle to wait on an o-ring from China….I’d try to find one at local hardware. Shouldn’t be too hard if you measure it.
Narmattaru
here you are, tovarisch
kotobuki
PM sent, thank you Narmattaru.
But my O ring is in a front of glass lens (as you can see in the picture), not in behind the head.
!Image and video hosting by TinyPic!
Lexel
Lexel's picture
Last seen: 4 hours 39 min ago
The oring on that light is placed between the glass and reflector
Mkduffer
Last seen: 3 hours 57 min ago
I’m debating between the UT02 and P30, too.. Dang…might have to get both. Big Smile
People say I’m a flashaholic like it’s a bad thing…
kotobuki
Sorry, I didn’t know because it’s missing.
Thanks.
Narmattaru
got it, replied im pm
what about buying both P30 and UT02 – for such a price that may be a good choice.
komeko
komeko's picture
Last seen: 1 hour 14 min ago
Today I got my UT02.
I ordered the NW version (5000K) but from the measurements it turned out that it is 4250K. It is a pity because I would prefer 5000K.
As for the currents in turbo I am 2.9A. Overall, I’m happy with this light. A good compromise between weight, size and power.
Click on:        ANSI WHITE
Click on:        MY COLLECTION
Click on:        Q8, D4, D4S, GTmini, SDmini, Mini AAA, TIP CRI, M43, H1, H03, TC20, TN40S, TN42, V6, UT01, H600Fw, SC600W
klrman
klrman's picture
Last seen: 5 hours 32 min ago
Any reliable way to measure amps in turbo that I could do?  I'm curious what my two UT02's are pulling.  I have both NW and CW and the NW is very very yellow.  The CW is just perfect, maybe around 5500k.
BlueSwordM
BlueSwordM's picture
Last seen: 4 hours 44 min ago
If you don’t have a clamp multimeter, build yourself some probes with 14-16AWG sized wire.
It worked nicely for my Astrolux S42 FET mode.
My very own high current Beryllium Copper springs: http://budgetlightforum.com/node/64047
wstrachan
Last seen: 8 hours 24 min ago
I find the second version pretty weak and unimpressive. I have the first version which still works perfectly and that’s a different story.
With as much mass to help with cooling that the UT02 has, I don’t understand why they cant get 1800-2000+ lumens out of the XHP35 emitter and do it reliably.
I ordered the Lumintop ODL20C today. It’s a manker or Utorch look-alike but with 2000 lumens. Cautiously optimistic I am.
light addict....yeah I've got the bug.
Atrolux MF02_O2S
Imalent DT70
Emissar (All Models)
Lumintop ODL20C
Wuben A21 & T70
thrunite tn32 ut
acebeam k60
many, many others...
klrman
klrman's picture
BlueSwordM wrote:
If you don't have a clamp multimeter, build yourself some probes with 14-16AWG sized wire. It worked nicely for my Astrolux S42 FET mode.
Will give it a try, thanks.
komeko
komeko's picture
wstrachan wrote:
I find the second version pretty weak and unimpressive. I have the first version which still works perfectly and that’s a different story. With as much mass to help with cooling that the UT02 has, I don’t understand why they cant get 1800-2000+ lumens out of the XHP35 emitter and do it reliably. I ordered the Lumintop ODL20C today. It’s a manker or Utorch look-alike but with 2000 lumens. Cautiously optimistic I am.
I managed to squeeze from UT02 1742lm at 5.7A. Now a little more feel the warmth but I see that it still has a spare. With this cooling mass, it’s easy to have 2000lm to be.
BlueSwordM
@klrman, here is what I do. I usually do the first method with single cell lights:
https://lygte-info.dk/info/Measurement%20UK.html
klrman
klrman's picture
Thanks BlueSwordM, that is just what I was looking for
