What moonlight output do you prefer and why?
You can see the archived poll results on the Wayback Machine:
What moonlight output do you prefer and why? - LED Flashlights – General Info - BudgetLightForum.com
Ha I discovered that the lighted tail is good enough for nightly toilet visits. Idk how many lumens we talk about.
But I am happy with a low low like the Bistro offers and again idk how much lumens that is.
(Hey much/many one of them must be wrong but both don’t feel wrong, both correct?)
.2-.5 is perfect for me. love it in my tent at night when I go car camping and backpacking.
I like .5 for waking to pee
I do not like .2
I like 1-3 lumens for use in a camper, and for EDC
I do not like Low first on an EDC, but Low first is fine for a nightstand or camper.
I always thought the ML-L-M-H levels are in Amps. How would I convert it to Lumens? I think the Biscotti has 0.1A if I remember,
Voted for “other” because it depends. Generally I like about 0,3lm for walking around in total darkness and actually see where I’m going (this is where a stock Olight S1 trumps a stock S2, the S2’s moonlight is too dim for an 18650 torch in my book), but the 0,03lm of my dear Thrunite Ti3 is just awesome. Great for lighting up things on your hand like a book page, and it bothers nobody even if I shine it in their faces from less than 60cm away, as I found out in an unfortunate little accident one time :zipper_mouth_face:
Plus, less brightness equals more runtime, right? (although at such low current levels, it may not even make a difference given the inefficiencies of the system remain the same “large” percentage of the power consumption)
I believe that’s 0.1%, not 0.1A.
Thanks.
Maybe i have bad night vision, but i find most moonlight modes are too dim to navigate properly in the dark.
Moonlight 1 lumen
Firefly 0.05-0.1 lumen
Aha, okay.
Would you consider the lowest mode of a Skilhunt H03 a moonlight mode?
The wide variety of preferences is interesting, anywhere from .03 lm to 3 lumens so far! But it’s no surprise since moonlight is the one mode that is directly linked to our physiology in regards to our sensitivity to light in total darkness, and everyone seems to have a slightly different way of seeing.
More manufactures should consider user-adjustable moonlight modes to account for this; a 0.2 to 0.5 lumen difference in moonlight is going to make a much bigger user-experience impact than, say +/- 100 lumens, on a 1200 lumen turbo. I appreciate that a Zebralight UI allows you to do this and even some Manker/UTorch lights as well. There must be a few other brands out there … are there any clickies that do this or are they limited to e-switches?
0.2 if possible, but 0.5 works. I like ceiling bouncing a light on the nightstand while I sleep, so the lower, the better. Blue tailcap light works, too. Makes it easy to find when I get up, doesn’t burn a lot of battery, doesn’t ruin my night vision and bright enough for basic lego/hot wheel avoidance.
+1
That’s a good idea, I usually have a bunch of old AAA AA batteries “adjust” or simulate a moonlight/firefly.
Just be sure you’re not using them in any nice lights in case they leak :weary:
Good point. :+1:
For these eyes with five decades of mileage on them, 1-3 lumens is perfect. The 1 lumen moon mode on the Acebeam EC50 Gen II is fine if a bit dimmer than ideal. I have other lights that are on the higher end of that range or even closer to 5 lumens. For navigating the house and checking on kids and other animals, this is just about perfect,
Wilkey
I’m legally blind, with no low-light vision whatsoever, so “moonlight” for me is 5 to 10 lumens.
Even then, I almost never use that sort of level - I usually step up to something on the order of 25 or even 50 lumens, depending on beam profile. This is why I like BLF-348s, and Convoy lights with lowest modes at 5%.
All you firefly aficionados should probably hope never to encounter me on a campsite after dark :slight_smile:
1 lumen is enough for me, honestly, i hate some flashlights that has useless moonlight mode: too bright(5-6 lumen) or too dim{below 1 lumen)
I use my Astrolux S41 around the house on lowest setting. It is about perfect for me as it is so floody too.
Bump it up one notch and I can see where stuff is in most rooms, rarely need more than that indoors. Not sure what the lumens are for the S41 tho???
Moon/firefly much less use on narrower beams I think.
I believe the usefulness of moonlight modes are completely dependant upon the eyes of the user.
Personally, if I wake up and need to use the bathroom in the middle of the night, the (claimed) 0.5 lumens from any of my Olights is simply painfully bright. A neutral AO1 or Thrunite offering less than half that value are much more comfortable.
My wife, on the other hand, finds the 0.5 level useless - and needs about 3 lumens. It’s sure nice that we have lots of choices.
