the wait is on. Likely close to March to see it then.
Just ordered 3 of the 36x14mm triple reflectors, along with a few other things. So yeah, the wait is on! Haven’t ordered from Kaidomain in quite a while…
I believe kiribaru is making a triple spacer for the C8.
We are waiting for results
Only issue is that you need a lathe for a project like that , so i’ll have to see others’ mods
https://www.fasttech.com/product/5422602
36.5 mm diameter, but possibly the same as the KD 36mm one.
I have the 36mm version :
Noctigon 32mm
MAXTOCH 32mm
The flashlight I think it’s made for is the UniqueFire UF-1408 :
I have a triple X6,but with optics,not reflectors.
Khas, is it possible to center the leds with the noctigon?
I have tried to center the emitter in the reflector at the top but that leaves the other two off center.
It appears the Noctogon has the right hole layout as the reflector but the maxtoch doesn’t? How does the beam compare to the cute-3?
The solution seems to be 3x 10/16mm mcpcb’s … Soldering the wires is the tricky part , if someone can use nickel strips it will be easier .
I don’t think you can use this reflector with the Noctigon if you want all the emitters centered.
The only picture I have for comparison is the UF-1408 with the standard MCPCB re-flowed with XM-L2 U3 3D and the KD reflector VS triple X6 with Nichia 219C D320 5000K
About 1 meter from wall UF-1408 (left) X6 (right)
Khans can you take a picture of the stock UF-1408 mcpcb? There are several pcb’s on various sites that aren’t linked to a specific reflector or light, this might help identify it.
I went ahead and ordered the two reflectors. One way or another in one light or another they’ll fit something. I also included some XM > XP centering adapters for some HP options.
So, what I’m thinking… use a hacksaw and cut the Noctigon 32mm at 3 points, dividing it into thirds. Done properly, the 3 pcs should now line up and allow use of this reflector. Traces can be rejoined across the gap with flat sheet material. Could either solder them back together or leave them apart, glue the individuals down to the emitter shelf using the reflector as a template to position them perfectly.
Probably as easy or almost as easy as fitting 3 16mm Noctigons and then messing with all the wiring.
(Cut on the downstroke only. Pulling a backstroke would lift traces off the mcpcb.A band saw would make this easy peasy.)
I paid KaiDomain $67.71 4 days ago, haven’t heard a word in confirmation from them whatsoever. No email at all. They got the funds, I so far have not one scrap of communication.
Similar boat here, DB. Put in a KD order today. Got a PayPal receipt, but no sign of an order confirmation. :question:
I think KD might still be out on CNY.
CNQG was the worst for that. I never recieved confirmation for any orders placed with them. Occasionally with a few others but KD was usually good about it.
