no longer working
Lumintop Copper Tool AAA XP-G2 R5 LED (link is external)
$22.99 coupon NMCJ
I had used it in the past, but today it does not work, neither in Safari nor in Chrome… when I put other codes in for other items, they work, but this item and code just does this, AFTER I click Apply:
I tried multiple times with no luck
either way, thank you for the deals
Hello Fin, if it’s not too much trouble while you check on MT10C, can you also please check on a deal for the Nitecore MT10A? Thank you
Try clearing your browser cache ㎇ꓖꓐꓨꓭ GB*⁹⁹⁴⁵ ₲roup ₿uy ⁜ℳⅈℂ⅁ℊℬḠḆᙪᏀ
G 94⁹⁹
ÂḾÂẐÔŇ
₳ Ꭿ ã
❰ A ❱
⛯ ֍ ⛯ ꧅ ◎ GG
✅✊✋✌✍✔❛❜❝❞❟ ❆✪❋✿❂⚡ ❶❷❸❹❺❻❼❽❾❿ ☝ ⭐⭕ ✨ ❗ ➕ ⏩⚓⚜
I cleared my cache… no change in my results, but glad its working for you… and Im OK as I was only testing the code to give to a friend, but we found another code that works
thanks again
I do not understand why you have a problem occurred with the code.
Sorry.
All coupon codes, flashsales & deals - on first page (messages ## 1 - 3)
Because he already used it once. GB let you use their codes once only
Is the C8 the new version with the new firmware?
Hi Fin17 - any codes for the On The Road M6? Either simple or with cell?
Regards,
SP
Deputydave, check PM
Thank you, I got it. I decided to order the OTR M3 from your OP. I actually ordered this light and the Utorch UT01 from GB back in December. They refunded both with some B.S. excuse. That turned me off of GB but I’ll give them an opportunity to get it right. We’ll see if this order goes through correctly.
hmm, don’t see the order
Clicked on the link in the OP and had a confirmation email from GB that they’d received payment.
sub
Jet II Pro ordered, thanks.
GB once again refunded an order. That’s the third one in a row. PP paid the $ and I got a confirmation email saying so from GB. Order was refunded the same day.
Contact someone from GB , there is probably something not going well .
I did the first two time. Got two completely different answers. Neither answer made sense. I’ve ordered from GB previously without issue. Last three times PP paid the $, got a confirmation from GB that the ordered had been paid and then for some reason they refunded. Don’t know why. If they don’t want my money I’ll buy from someone else.
