yes,dear, we use a kind of high heat conduction index glue to fix the lens+Pcb.
sure,Aliexpress standard logistic service provide tracking number for you. it is air shipping and not expensive.
dear, now we have not other color body ones. this batch we all produce the dark gray version.
dear now we have not enough time to sell small order for the parts. if your order is some big,you can contact us
Thanks Jaxman for the quick reply. Will place 1 order in your website.
Thanks
Please consider to offer the Nichia leds.
Thanks
Seems like a nice little light.
I’d prefer not having an additional glass and the optic not glued in place.
What driver are you using? I can see its a 7135?
Seems to be considerably shorter than the E2/ convoy S2… I’m in!
Please consider offering short battery tubes for an 18350 battery as an option.
Hi Jaxman, I bought one already, I’m looking forward to it!
The short Convoy tube may just fit, I believe that Jaxman uses the same threads (but you never know in the end)
Thanks djozz.
This light is tempting, I would’ve already pulled the trigger, but the glued optic and MCPCB held me back. If one doesn’t plan to modify anything this light should be great.
What about Nichia variant of this flashlight?
could we try to organize a group buy, requesting a driver change ?
glue… :person_facepalming: :weary:
Wouldn’t only the feet be glued?
To me this is a great flashlight.
Look at that : you have 900 real lumens but at the same time only draw 2.1A which gives you both reliability and runtime !
How much do you have to feed a single emitter flashlight to get 900 lumens ? About 2.8A, which is less efficient and produces more heat !
Triples are the future !
Well setting up a new entry for a host is far more easy then a driver swap and was denied so I do not see it happen.
We just have to buy it and mod it
The cost of the flashlight is not bad, but shipping costs to my country are a little expensive, more than 20% of the cost of the flashlight. Finally the total cost (flashlight + shipping) is a bit expensive
+1
Glue scares potential buyers like me
Glue does not scare me… but it makes me take into account that the light may get scratched or that I may be replacing the optic after a rough disassembly. I really like this look and idea behind this light as an EDC, but it would have to be either a Cree 5Ax or 219B or C for me to be happy with it.
