I agree that there isn’t much point of me going up if I bought another Convoy S2+, as the battery life to brightness seems good with the 6x7135 for me.
I just guess I would like to try something else, and was wondering what falls in my budget, that is actually worth getting and not junk lol.
If the Convoy is really the best I can get, it will be another one, but it would be nice to try something else out if possible :).
In regards to the VG15/VG15S they have a step down from their top brightness at 3mins. 45c certainly isn’t hot. My TN36 hits about 70c which is too hot to hold comfortably.
I really need to do a heat/lux test on that at some point.
Ahh, I understand now. That is not a bad idea, as I remember my Convoy S2+ on high did get very hot near the emitter if used on high, which was why I mainly used it on mid mode, plus for the better battery life.
Is the clip removable on the Thorfire VG15S? As I was thinking if I used it on my bike, the holder for the flashlight may not work with a clip in place.
It seems the S2+ is still a well recommended light, and for the price I will probably grab another.
But, I would also like another flashlight as I fancy one lol.
So, there is the Thorfire, if anyone else has any recommendations please let me know.
I also can’t think of any better than S2+ with the new firmware.
I was removing old Convoy drivers instantly - that was the weak point I could not stand. But with the new FW - it’s perfect! Simple, enough flexibility, no visible PWM, I love it!
For the perfect light - I could recommend S2+ 6x7135 + high CRI Nichia 219C.
Ok then, I think it will be a Convoy S2+ with the new firmware then, although I will also buy another flashlight from another brand, as I fancy another one too :).
It will be the 6x7135 version I go for again, although I will be sticking to the standard emitter, I am not very good when it comes to mods and ruined my first S2+ when I tried to mod it, so I think it will be the Cree emitter over the Nichia.
Also, are there any recommended batteries, or are my high drain li-Ions fine to continue to use? I have 2500-3000MAH Cells such as 25R’s and 30Q’s.
EDIT: Also, which tint would you recommend? I have no idea what my old models were, although they were quite white and not yellow.
I can’t seem to find the model with the new firmware on the Convoy store unfortunately, I do want to get one though so will have to find out how to do this.
I still wish to get another flashlight though too, so the Thorfire seems good, although any other ideas in this price range would be great too.
I will just use my current batteries like I did for the Convoy I lost, I got good runtimes out of a 25R or 30Q in mid mode, so might as well save money by using them still.
For XM-L2 most recommended tint is T6-4C. It’s more warm, but I like it very much. I also like 3B - more neutral.
Go to Convoy store on Aliexpress and write a message to Simon, he’s very responsive. As far as I remember for about $1 more he can make you light with the new firmware.
I’m a big fan of the Convoy S2+ and own four of them. I bought a couple of the new firmware drivers but haven’t installed them yet but they should be quite nice. You can’t go wrong with an S2+.
However…
Like you I wanted to try something different as well. I just got the Astrolux S1 last month and like it quite a bit as well. I like that it has the 18350 tube should I choose that option. It has about 7 levels of brightness with a nice moon mode. Turbo is suppose to be around 1200+ lumens. It has the strobe, battery check and bike strobe functions as well. I think they’re around $25 now with a code. Check one of the folks here with GB codes to see.
Like others I own about 4 Convoy’s but haven’t gotten around to testing one out on my road bike. I do like to have a touch of throw up the road so I’ve got the (newer, XP-L) Nitenumen NE01 - an MH20 clone. I’ve only used it for a couple of rides so far but it seems pretty good. I do like the USB recharging convenience (I’ve setup a power supply with a load of microUSB cables where I store my bikes.)
Worth thinking about. If I get the chance I’ll test out the NE01 vs. the S2+ to see if I can live without the extra throw.
If it’s worthy info, I have just bought a Convoy M1 in 7A with Biscotti from Simon, so the costliest combo for the model. It didn’t cost even 20 bucks by itself - it cost me a little more with the BLF discount because I also got two pocket clips. Everyone tells me it gets the flood/throw balance just right with an excellent form factor.
Eagle Eye X2R
I own both (S2) and the EEX2R feels like the it has better quality. Doesn’t appear you desire a lot of modes so the 3 simple modes should suit you though it has no moonlight mode. Its a good walking light and I’m sure for trail/slow riding it would do well on a bike. Doesn’t have the throw for any sort of speed riding but in that arena its similar to the S2. Just a very nice flashlight for the money (under $20.00) delivered
