Ahh, I understand now. That is not a bad idea, as I remember my Convoy S2+ on high did get very hot near the emitter if used on high, which was why I mainly used it on mid mode, plus for the better battery life.
Is the clip removable on the Thorfire VG15S? As I was thinking if I used it on my bike, the holder for the flashlight may not work with a clip in place.
It seems the S2+ is still a well recommended light, and for the price I will probably grab another.
But, I would also like another flashlight as I fancy one lol.
So, there is the Thorfire, if anyone else has any recommendations please let me know.
I also can’t think of any better than S2+ with the new firmware.
I was removing old Convoy drivers instantly - that was the weak point I could not stand. But with the new FW - it’s perfect! Simple, enough flexibility, no visible PWM, I love it!
For the perfect light - I could recommend S2+ 6x7135 + high CRI Nichia 219C.
Ok then, I think it will be a Convoy S2+ with the new firmware then, although I will also buy another flashlight from another brand, as I fancy another one too :).
It will be the 6x7135 version I go for again, although I will be sticking to the standard emitter, I am not very good when it comes to mods and ruined my first S2+ when I tried to mod it, so I think it will be the Cree emitter over the Nichia.
Also, are there any recommended batteries, or are my high drain li-Ions fine to continue to use? I have 2500-3000MAH Cells such as 25R’s and 30Q’s.
EDIT: Also, which tint would you recommend? I have no idea what my old models were, although they were quite white and not yellow.
I can’t seem to find the model with the new firmware on the Convoy store unfortunately, I do want to get one though so will have to find out how to do this.
I still wish to get another flashlight though too, so the Thorfire seems good, although any other ideas in this price range would be great too.
I will just use my current batteries like I did for the Convoy I lost, I got good runtimes out of a 25R or 30Q in mid mode, so might as well save money by using them still.
For XM-L2 most recommended tint is T6-4C. It’s more warm, but I like it very much. I also like 3B - more neutral.
Go to Convoy store on Aliexpress and write a message to Simon, he’s very responsive. As far as I remember for about $1 more he can make you light with the new firmware.
I’m a big fan of the Convoy S2+ and own four of them. I bought a couple of the new firmware drivers but haven’t installed them yet but they should be quite nice. You can’t go wrong with an S2+.
However…
Like you I wanted to try something different as well. I just got the Astrolux S1 last month and like it quite a bit as well. I like that it has the 18350 tube should I choose that option. It has about 7 levels of brightness with a nice moon mode. Turbo is suppose to be around 1200+ lumens. It has the strobe, battery check and bike strobe functions as well. I think they’re around $25 now with a code. Check one of the folks here with GB codes to see.
Like others I own about 4 Convoy’s but haven’t gotten around to testing one out on my road bike. I do like to have a touch of throw up the road so I’ve got the (newer, XP-L) Nitenumen NE01 - an MH20 clone. I’ve only used it for a couple of rides so far but it seems pretty good. I do like the USB recharging convenience (I’ve setup a power supply with a load of microUSB cables where I store my bikes.)
Worth thinking about. If I get the chance I’ll test out the NE01 vs. the S2+ to see if I can live without the extra throw.
If it’s worthy info, I have just bought a Convoy M1 in 7A with Biscotti from Simon, so the costliest combo for the model. It didn’t cost even 20 bucks by itself - it cost me a little more with the BLF discount because I also got two pocket clips. Everyone tells me it gets the flood/throw balance just right with an excellent form factor.
Eagle Eye X2R
I own both (S2) and the EEX2R feels like the it has better quality. Doesn’t appear you desire a lot of modes so the 3 simple modes should suit you though it has no moonlight mode. Its a good walking light and I’m sure for trail/slow riding it would do well on a bike. Doesn’t have the throw for any sort of speed riding but in that arena its similar to the S2. Just a very nice flashlight for the money (under $20.00) delivered
Diving light, thus waterproof. Magnetic slider, so infinitely adjustable from moonlight (get it on and slowly nudge it dimmer ’til it’s as dim as you want it) all the way to full-on.
Natively takes a 26650 but has a sleeve to take 18650s too. (Tried both, work great.)
~16bux at FT, - 5% with BLF discount == 15bux and change with free shipping.
Nb: The S2+ is rather floody, so any non-S2+ will have a throwier beam. Make sure you’re okay with that first before committing to a non-S2+ of any flavor.
