Thank you djozz for all the time and effort you put into this testing. Great job! And thank you to James for providing the sample.Really like the yellow.
Thanks to djozz for running this test! Confirmed I picked the right man for the job, A lot of time and effort went into this!
Thanks Jos!
thank you for the test
Thanks for the comments all of you. Since I have these ruined lights now, I may as well do a few more tests with them when time allows that.
Well, as much as she understands that a man needs a hobby, ok, let’s just say that my six year old son a least found the tests very enjoyable to watch.
Very nice!
And I bet you will find good uses in future testing for those tortured lights
I’d be curious how well the finish would hold up ? I’d buy one. Thanks for the comparison.
Thanks djozz.
Thanks for that….3Tronic
interesting test. About what I would have expected given the results for automotive parts with about the same results (aka, powder coating doesn’t have a large effect on temperature transfer. Now ceramic coating on the other hand is a whole other ballgame).
I have to say, that yallow light is really not bad, I could see several uses for it.
Captured on film for the first time ever, the dreaded Li-ion Tape Worm. This illusive creature has been the bane of electronics consumers the world over.
On a serious note, Thank you djozz for yet another hobby changing, well designed test and report.
Thanks for the test.
Djozz busting myths, I like that.
Next we need, disproved theory that solder alloy thermal conductivity rating as being critical for better LED cooling in DTP MCPCBs
Current plays a huge role in lifetime, see CREE’s results.
Those L70 ratings are rather pointless at low currents.
Reaching L90 at higher current is way faster even if case temp is way lower.
Just compare the last 2, huge difference for L90, despite the way much lower case temp.
Glad to see this thread vindicating James and his attempt to fill a niche market with custom finish lights…
I was watching the other thread closely as I thought the powder-coated light looked really good. I was disappointed to see that thread get turned into such a flame war.
I’m also sad to see that nice fluorescent yellow light hacked up, but at least we know it was…
The code is active for the Powder coated lights!
Fluorescent Yellow Hosts:
The Fluorescent Yellow C8 price after code is £25.85 + Shipping
The Fluorescent Yellow S2+ price after code is £24.75 + Shipping
A bit higher than original mainly due to the current exchange rates! etc.
I currently have NO spare hosts in stock (but there are more on the way)
Depending on how many orders there are I will order more hosts tomorrow. So please see this as a pre-order!
e.g If i get 10 orders tonight I will order 15 more hosts tomorrow
They will be done ASAP after I get the hosts
This way it saves me from doing an interest list and waiting for it to fill up, then ordering the hosts, then coating them.
I will do it as and when people order. It should cut down the wait time
I’m not going to set an end date for the coupon, but it will end so if you want one get it before the price goes back up!
The Discount Code Is: FLOYO
Bravo Djozz! Many thanks.
PS, cross-referencing a search, the specific material used for the powder coat affects the emissivity (how well it throws away infrared to the universe around)
https://www.google.com/search?q="powder+coat"+emissivity
Woah, nice work, thanks!
Would be interesting to compare a FET driver, the 8x7135 and lower power drivers. I would assume that the temperature would scale exponentially?
This test is a MASSIVE boon to the community in my book, so thanks a bunch, Mythbuster djozz :+1:
Just for curiosity’s sake, how are the two torches behaving after the test? Do they even work still?
Do you know the LED case temperature of a XML2 when the body is 70dC with an aluminum star at 2.7A?
There are reports from self desoldered LEDs in FET lights that do at best 5A with lead free solder which has over 200dC melting point
I would estimate that the LED case temperature of the XML2 can reach easily above 150 dC when left unattended at 2.8A in a stock light
