interesting test. About what I would have expected given the results for automotive parts with about the same results (aka, powder coating doesn’t have a large effect on temperature transfer. Now ceramic coating on the other hand is a whole other ballgame).
I have to say, that yallow light is really not bad, I could see several uses for it.
Captured on film for the first time ever, the dreaded Li-ion Tape Worm. This illusive creature has been the bane of electronics consumers the world over.
On a serious note, Thank you djozz for yet another hobby changing, well designed test and report.
Thanks for the test.
Djozz busting myths, I like that.
Next we need, disproved theory that solder alloy thermal conductivity rating as being critical for better LED cooling in DTP MCPCBs
Current plays a huge role in lifetime, see CREE’s results.
Those L70 ratings are rather pointless at low currents.
Reaching L90 at higher current is way faster even if case temp is way lower.
Just compare the last 2, huge difference for L90, despite the way much lower case temp.
Glad to see this thread vindicating James and his attempt to fill a niche market with custom finish lights…
I was watching the other thread closely as I thought the powder-coated light looked really good. I was disappointed to see that thread get turned into such a flame war.
I’m also sad to see that nice fluorescent yellow light hacked up, but at least we know it was…
The Fluorescent Yellow C8 price after code is £25.85 + Shipping
The Fluorescent Yellow S2+ price after code is £24.75 + Shipping
A bit higher than original mainly due to the current exchange rates! etc.
I currently have NO spare hosts in stock (but there are more on the way)
Depending on how many orders there are I will order more hosts tomorrow. So please see this as a pre-order!
e.g If i get 10 orders tonight I will order 15 more hosts tomorrow
They will be done ASAP after I get the hosts
This way it saves me from doing an interest list and waiting for it to fill up, then ordering the hosts, then coating them.
I will do it as and when people order. It should cut down the wait time
I’m not going to set an end date for the coupon, but it will end so if you want one get it before the price goes back up!
Do you know the LED case temperature of a XML2 when the body is 70dC with an aluminum star at 2.7A?
There are reports from self desoldered LEDs in FET lights that do at best 5A with lead free solder which has over 200dC melting point
I would estimate that the LED case temperature of the XML2 can reach easily above 150 dC when left unattended at 2.8A in a stock light
As long as the only problem with them is the waterproofing, then awesome, they’re battle-scarred champions with history behind them. If you’re not too attached to them anymore, I’m sure they’d be a real object of desire and a guaranteed sell on a WTS thread :innocent:
Fwiw the 1.14A S2+ triple I just finished needed no time out. It got hot but never too hot to hold. I suspect that 4 chips or more minutes might need it if left free standing while hand held might be stable though hot.
I do not know the temperature unfortunately, I am curious.
None the less it seems like the word around is throw that only thing it matters to LED life is how cool is everything (as it what is the host temp). While in CREE tests you can see how that is not real. Low current with huge case temp still outlives high current and low case temp.
I have seen it with my eyes how an XM-L1 started to shift at 45deg on an aluminum MCPCB, basically solder got into liquid state. Did not seem to have come with any issues of soldering, just by looking at it.
Solder is hard to know what it is from China, I suspect they use the 138C melting point solders (Bismuth based) in China just to claim lead-free and make everything simpler for them (less control over reflows especially comapred to other non-bismuth lead-free common solders)
However there are some claims only that due to certain reflow process such solder might happen that it melts at even as low as 120C
The other route of lead-free is the regular 200+C melting point solder which would probably create the need of too much attention/control
This is speculation of course, based on the fact I have seen an LED starting to flow around the MCPCB and it would be really hard to imagine 180-220C temps
