I just ordered an SJ6000, so this is good information. Thanks!
Excellent camera!
Congrats.
I want to get an action camera. How would you rate the SJ4000 over others in the less than $100 range?
Edit: Nevermind, I ordered one based on reviews I’ve read.
I have two younger kids (8 and 4-1/2) so I figure something like this to play with in the water during the summers will be fun. Maybe in the snow, as well.
I’ve done tests on a number of different OEM replacement batteries for both camera and cell phones. I cobbled together an arrangement to charge/discharge them on the AC-6 like you did, though not so elegant.
So far I haven’t found any that were as good as stock, though they generally were WAY cheaper. A few made it almost to 80-90, most were 50-60, occasionally there were duds. :confounded: I suggest you do test your used/stock battery. I found several of mine that were still significantly better after 2-3 years use than the new replacements. That’s pretty telling.
I’ve found you can’t use the reviews at all unless you stumble on someone with the knowledge and equipment to make a test like you did, which is VERY VERY rare. People either don’t have a clue, or it’s kind of “these are great vs. these suck”. They really don’t KNOW, they are guessing based on their anecdotal experience and use pattern, which is likely all over the map. Kind of like some people love [Ultrafires] since they actually do work in their light awhile. :person_facepalming:
With supporting pictures I have been able to get refunds IF I bothered. I’d sure like to know a reliable source for replacement batteries that don’t suck.
Re: Wasabi batteries - I just checked that brand for my Canon SX280. Stock cell is 1000mA. Wasabi claims to be 1300mA. My experience is the bigger the claim, the bigger the lie. I actually bought an Ansmann only claiming 750mA hoping a known brand name and a modest claim would actually be valid……NOT! They were ~660mA.
A couple of reasonable tests conducted on Amazon seemed to indicate this was true for THAT CANON battery. I doubt they make them, so different models could well show different results.
(This test compared video record time in minutes on the camera itself)
Canon: 29, 28
Wasabi #1: 24, 10
Wasabi #2: 27, 8
Separate test.
These cells are much cheaper than Canon’s and seem fine mechanically, but don’t expect 1300 mAh. The actual discharge curves, measured into a 20.1-ohm resistor, showed the capacity to be about 780 mAh (using Wasabi’s charger). Both cells gave very similar results; a couple of charge/discharge cycles made no significant difference.
Excellent post flydiver.
Couldn't agree more. And BTW, I did test the OEM batteries and guess what? Just as you said, they tested higher capacity than my new "high capacity" batteries.
I forgot who, but another member suggested I try Wassabi Japanese batteries so I ordered those and will return these. Rest assured, the firt thing I will do when they arrive is run a few cycles and check the capacity.
Just added to my post when I checked out those Wasabi for possible purchase. I may buy, but I’m not much encouraged. They seem like more of the same BS.
Hope not. I just bought a few. If they fail the cap test, back they'll go too.
If so, I may try to find some authentic OEM's. But that may also be a mouse chase.
I have had an SJ4000 WiFi for a year now & paid about $45 for it on a deal with 3 batteries & 2 chargers.
I have been very impressed with it for the money :+1:
I use them on sport vehicles, my drones, my motorcycles etc.
Very good camera. I paid about $60 for each one and honestly……I rarely use my $300.00+ GoPro anymore.
I use mine on my boat when fishing to make short videos of catches
I needed a water proof camera & when I saw how much the GoPro”s were I thought I would get one of these SJ 4000”s & see how I got on with it before splashing out hundreds of dollars on a GoPro.
I have been so pleased with it I never bothered getting a GoPro :+1:
One thing I would say to anyone thinking of getting an SJ is to do some research first before buying so that you can tell the difference between an SJ & the far inferior clone versions of it that are out there so that you do end up with an SJ.
The SJ is obviously a clone of the GoPro but if you read the many reviews there is little difference between it & a GoPro but the clones of the SJ are nowhere near as good
Excellent point. The Clones are no good. You have to get the Authentic Original SJ4000 (or an Authentic SJ5000, SJ6000)
Unfortunately, many have bought the clones then give the real deal a bad name.
Today I received the Wasabi Power SJ4000 Batteries and charger.
For reference, the Wasabi batteries weigh in at 20 grams……IR = 202milli-ohms
They’re on the charger now and once charged I’ll run a discharge test on them to see how they do. Hoping for a good outcome here.
On a side note about the other SJ4000 batteries, the seller of those batteries candys-outlet-store, was very cooperative and helpful with the return of the EforTek batteries and charger.
Today I received the Wasabi Power SJ400 Batteries and charger.
Curious what the stock batteries weigh.
The original batteries that ship with an Authentic SJ4000 weigh 18 grams
This is what I ordered:
I didn’t see that it says the charger adapter is not included- does it charge via USB, so that any USB charging station should work?
SJ6000
Sir,
I do not mean to be the bearer of bad news, but the camera you purchased appears to be a clone. Not an authentic SJCam.
Authentic SJCameras will have “SJCAM” printed right on the front. Clones are not allowed to do that.
You must be very careful when shopping to ensure that you only buy the Authentic SJCAM. Many have had much lesser results with the cameras that were not Authentic SJCAMS.
As far as charging, the camera has a USB port on the side. All you need is a USB micro cable to charge the battery.
Let us know how your clone works out.
Good news on the charging, not so much on the source of the camera.
It will get more use once the weather here warms up, but I will see what I can do with it in the mean time (once it arrives.)
What would be a good source for the real SJCams?
Thanks for checking in!
You’re welcome
Any source that has the word “SJCAM” printed right on the front of the camera is usually fine.
GearBest and BangGood both probably sell the Authentic versions and the Clone versions.
I bought mine from B&HPhoto in New York. They were about $58.00 each IIRC
Thanks for the input!
I will check those sources out, and wait to see what I actually get.
I am also considering an accessory package that is supposed to be good for the SJ’s and GoPros- they seem to run $20-$30 for quite an assortment. Do you have any recommendation on those?
