New Convoy C8 – Clearly better
https://www.aliexpress.com/store/group/Convoy-Flashlights/330416_254412389.html?spm=2114.12010611.0.0.dUUAI4
Once you get it up and going, that clip will be very handy. But just flashing Bistro again likely won’t fix a “lost the noinit lottery” situation. As long as you’re using the same byte for noinit detection, it will likely decay to the same state. You could flash something that doesn’t use noinit. Or wait for the noinit tracking to be revamped (I’m currently working on that). Best of luck to you!
He has the store front on Aliexpress, but no regular website because his staff is small. He’s a small company dedicated to quality products, but without inflated profit margins like Fenix and Thrunite, etc…
If he made a .Com website he would have to hire more people to run it and to process orders from it and he’d have to raise his prices to compensate. Nobody wants that, do they? Lol
Anyone have any experience with epacket delivery to the US? How long have your orders from Simon taken to get in?
thanks
Epacket varies greatly depending on overall mail load. Right now with the holiday just ending you can expect longer then normal delivery times.
Generally epacket is around 2-3 weeks for me. Although I have had it as fast as 5 days and as long as 6 weeks.
Varies wildly for sure. I’ve had some go almost a month, others much shorter.
I just placed an order for an item at Banggood on Feb 8th and received it yesterday. That’s 7 business days… I was shocked.
I really wanted one until I saw the UI. It works for most but I am just completely inept at half/whole/long presses. I have the E14 and I barely use it because of the UI. It’s a crap shoot getting into and through the special mode menu. It’s a shame cause I really wanted this one. Oh well.
It took me awhile to get a hold of how fast to click but it is not so bad once you master it.
you can also post in the commercial forum if you are interested in your own personal UI the way you like it.
It would be a shame not to use your light
The C8 driver only has fast click IIRC, which is super simple. You simply tap the power button till the light blinks off then release and it goes to the next mode.
If you really don’t like that then simply set it to 100% only mode, which will be on/off only with no other modes.
Thanks TA. I’ll add the fact that there are 8 mode groups that don’t have blinkies and they all function beautifully.
I do not mean to imply that I am in any way excusing the problem with the current drivers and I don’t have the E14 to compare it to. We are working on the driver issues but it will take time.
For most (certainly not all) the current driver will be at the very least, quite an improvement over the old 3/5 driver with the annoying blink in low. That said, “acceptable” is NOT acceptable to Convoy and I’m working with Simon on getting this issue resolved and moving forward to bring more awesomeness to the budget light world that this forum was founded on.
Cheers :wink:
If you bought a new C8 and didn’t like the menu/UI, then you could always swap the driver for a new one from MTN Elec that has the simpler Guppydrv for like 5 bucks. A driver swap in the C8 is very easy, you only have to solder 2 wires on the LED.
Thanks a lot guys! That was very helpful. I may in fact pick this one up in another week or 2. I just ordered the XT12GT about 30 minutes ago so I would love to do a comparison with it and my old chinese xm-l t6 C8 as well as the UT02 and TM03 I just ordered last week. Just for fun, I know it’s not a thrower but it is about the same size.
I think you mean group.
If talking to me, I meant mode, fast clicking does not change the mode group, just the mode. To change the mode group you have to enter the menu.
Thank you Tom E for your discription in post #676. Wish I had read it before I ripped my SOIC8 clip apart and rewired it cause it wouldn’t connect to the ATiny.
After cutting the trace flashing a new firmware was no problem.
Instead of buying another driver you can buy programming equipment below 7$
Download the hex files from firmware site and flash is easy
Or modify an exiting firmware, like for other mode spacing
Is aliexpress the best place to buy convoy?
I’m in a hard decision now. Buy a C8 host and put in TA driver with OP reflector and XP-L2 now.
Or wait for the L2 little brother L1 which is not even has a separate thread. :cry:
The L1 is most likely a long way from being released, so it is more about how long you want to wait.
You are right. I think If I order and get the XP-L2-s my hand will shake over the Buy button for the host :smiley:
